Fluid Mechanics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Density and specific volume of air varies with elevation above sea level.
Air - Density vs. Pressure and Temperatures
Air - Dynamic and Kinematic Viscosity
Air - Prandtl Number
Air - Specific Heat vs. Temperature at Constant Pressure
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
Thermal properties of air at different temperatures - density, viscosity, critical temperature and pressure, triple point, enthalpi and entropi, thermal conductivity and diffusivity and more.
Air Duct Components - Minor Dynamic Loss Coefficients
Minor loss (pressure or head loss) coefficients for air duct components.
Archimedes' Law
Forces acting on bodies submerged in fluids.
Baume's Hydrometer
Liquid density with Degree Baume vs. Specific Gravity.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Bernoulli Equation
Conservation of energy in a non-viscous, incompressible fluid at steady flow.
Bulk Modulus and Fluid Elasticity
Introduction to - and definition of - Bulk Modulus Elasticity commonly used to characterize the compressibility of fluids.
Buoyancy
Buoyancy is the resultant force acting on a submerged body.
Capillarity
Capillarity - or capillary action - is the ability of a narrow tube to draw a liquid upwards against the force of gravity.
Carbon Dioxide - Dynamic and Kinematic Viscosity vs. Temperature and Pressure
Online calculator, figures and table showing dynamic and kinematic viscosity of carbon dioxide, CO2, at varying temperature and pressure - Imperial and SI Units.
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Carbon Dioxide - Thermophysical Properties
Carbon Dioxide Concentration in Rooms Occupied with People
Carbon dioxide concentration in a room may indicate air quality and ventilation system efficiency.
Carbon Monoxide - Density and Specific Weight vs. Temperature and Pressure
Online calculator, figures and tables showing density and specific weight of carbon monoxide, CO, at varying temperature and pressure - Imperial and SI Units.
Cauchy Number
Introduction to the Cauchy Number.
Cavitation
Cavitation occurs in fluid flow systems where the local static pressures are below the fluids vapor pressure.
Cavitation Number
An introduction and definition of the Cavitation Number.
Stability - the center of gravity vs. the center of buoyancy.
Chezys Conduit Flow Equation
Calculating volume flow and velcity in open conduits.
Colebrook Equation
Compressible Gas Flow - Entropy
Calculating the entropy in a compressible gas flow.
Compression and Expansion of Gases
Isothermal and isentropic gas compression and expansion processes.
Conservation of Mass
The Law of Conservation of Mass states that mass can neither be created or destroyed.
Darcy-Weisbach Equation - Major Pressure and Head Loss due to Friction
An introduction to density, specific weight and specific gravity.
Drag Coefficient
The drag coefficient quantifies the drag or resistance of an object in a fluid environment.
Dynamic (Absolute) Viscosity - Converting Chart
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Dynamic Pressure
Dynamic pressure is the kinetic energy per unit volume of a fluid in movement.
Energy and Hydraulic Grade Line
The hydraulic grade line and the energy line are graphical presentations of the Bernoulli equation.
Equations in Fluid Mechanics
Equations used in fluid mechanics - like Bernoulli, conservation of energy, conservation of mass, pressure, Navier-Stokes, ideal gas law, Euler equations, Laplace equations, Darcy-Weisbach Equation and more.
Equivalent Length vs. Minor Pressure Head Loss in Pipe and Duct Components
Minor pressure and head loss in pipes vs. equivalent length in tubes and duct systems.
Ethane - Dynamic and Kinematic Viscosity
Online calculator, figures and tables showing dynamic and kinematic viscosity of ethane, C2H6, at varying temperature and pressure - Imperial and SI Units
Ethanol - Thermophysical properties
Chemical, physical and thermal properties of ethanol (also called alcohol or ethyl alcohol). Phase diagram included.
Euler Number
Introduction to the Euler Number used in fluid mechanics.
Flow Coefficient Cv vs. Flow Factor Kv
Comparing flow coefficients Cv to flow factors Kv.
Flow Section Channels - Geometric Relationships
Geometric relationships like area, wetted perimeter and hydraulic diameter.
Fluid Flow - Entrance Length and Developed Flow
The entrance length is the length in a tube or duct after an obstruction - until the flow velocity profile is fully developed.
Fluid Flow - Equation of Continuity
The Equation of Continuity is a statement of mass conservation.
Convert rectangular and oval duct geometry to a equivalent circular diameter - online calculator with imperial and SI-units.
Fluid Flow - Euler Equations
The behavior of ideal compressible gas can be described with Euler equations.
Fluid Flow - Hydraulic Diameter
Calculate hydraulic diameter for pipes and ducts.
Fluid Flow Friction Loss - Hazen-Williams Coefficients
Hazen-Williams friction loss coefficients for commonly used piping materials.
Fluid Mechanics - Imperial and SI Units vs. Dimensions
Imperial (USCS) and SI dimensions and units terminology in fluid mechanics.
Friction Flow Coeficients from Moody Diagram
Online Moody friction flow factor calculator - as used in the Darcy-Weisbach major loss equation.
Froude Number
Introduction to the Froude Number.
Gas Mixtures - Properties
Gas mixtures and the ideal gas law, mass calculations, the individual gas constant and density.
Hazen-Williams Friction Loss Equation - calculating Head Loss in Water Pipes
Pressure loss nomogram for hot water steel pipes.
Hydraulic Force vs. Pascal's Law
Pascal's law and the hydraulic force acting in fluids.
Hydrocarbon Mixtures - Average Boiling Points vs. Gravity and Molecular Weights
Formulas and examples of calculation of boiling point of hydrocarbon mixtures from gravity and molecular weight.
Hydrocarbon Mixtures - Molecular Weight vs. Gravity and Average Boiling Point
Formulas and examples of calculation of average molecular weight of hydrocarbon mixtures from gravity and average boiling point, achieved from distillation data.
Hydrogen sulfide - Thermophysical Properties
Chemical, physical and thermal properties of hydrogen sulfide, H2S, also called hydrosulfuric acid, sewer gas and stink damp. Phase diagram included.
Hydrostatic Force acting on Submerged Surface
Calculate the thrust force acting on a submerged surface.
Ionic Compounds in Water - Solubility Guidelines
Guidelines or solubility rules to predict whether or not a given ionic compound is soluble in water at room temperature.
Isentropic Flow
Fluid flow with constant entropy is also called isentropic flow.
Jet Propulsion
Calculate the propulsive discharge force or thrust induced by an incompressible jet flow.
Kinematic Viscosity - Convert between Units
Convert between Centistokes, Saybolt and Redwood seconds.
Laminar Flow - Friction Coefficients
Calculate friction coefficients for laminar fluid flow.
Laminar, Transitional and Turbulent Flow
Heat transfer, pressure and head loss in a fluid varies with laminar, transitional or turbulent flow.
Laplace Equation
Important in fluid dynamics describing the behavior of gravitational and fluid potentials.
Lift and Drag
Lift and drag forces acting on a body like an air foil in a fluid flow.
Liquid Flow from Containers - Emptying Time
Calculate liquid velocity, volume flow and draining time when emptying a container for it's fluid.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
Mach Number
An introduction to the Mach Number.
Major Loss Online Calculator - the Darcy-Weisbach Friction Loss Equation
An online major loss calculator based on the Darcy-Weisbach friction loss equation.
Manning's Formula and Gravity Flow
Calculate cross-sectional average velocity flow in open channels.
Manning's Roughness Coefficients
Manning's roughness coefficients for some common materials.
Mass vs. Weight
The Mechanical Energy Equation compared to the Extended Bernoulli Equation.
Online calculator, figures and table showing thermal conductivity of methane, CH4, at temperatures ranging from -160 to 725 °C (-260 to 1300 °F) at atmospheric and higher pressure - Imperial and SI Units.
Methane - Thermophysical Properties
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Methanol - Specific Heat vs. Temperature and Pressure
Online calculator, figures and tables showing isobaric and isochoric specific heat of methanol, CH3OH, at varying temperature - Imperial and SI Units.
Methanol - Thermophysical Properties
Chemical, physical and thermal properties of methanol, CH3OH (also called carbinol, wood alcohol, hydroxy methyl and methyl alcohol). Phase diagram included.
Mixing Fluids
Final mass and temperature when mixing fluids.
Mixtures, Solutions and Suspensions
Mixtures vs. solutions vs. suspensions.
Moody Diagram
Calculate fluid flow friction coefficients from a Moody diagram.
Motor Oils - Dynamic Viscosities
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Navier-Stokes Equations
The Navier-Stokes equations are the fundamental partial differentials equations used to describe incompressible fluid flows.
Nitrogen - Density and Specific Weight vs. Temperature and Pressure
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Nitrogen - Dynamic and Kinematic Viscosity vs. Temperature and Pressure
Online calculator, figures and tables showing dynamic and kinematic viscosity of nitrogen, N2, at varying temperature and pressure - Imperial and SI Units.
Online calculator, figures and tables showing thermal conductivity of nitrogen, N2, at varying temperarure and pressure, SI and Imperial units.
Nitrogen - Thermal Diffusivity vs. Temperature and Pressure
Figures and tables showing thermal diffusivity of nitrogen at varying temperarure and pressure, SI and Imperial units.
Nozzles
Gas flow through nozzles and sonic chokes.
Oil Viscosity Converter
Convert between commonly used oil viscosity units.
Orifice, Nozzle and Venturi Flow Rate Meters
Petroleum Products - Average Boiling Points
Definition, explanation and examples of calculation of various types of average boiling point of petroleum products and other mixtures of hydrocarbons: VABP, MABP, WABP, CABP and MeABP.
Pipe and Duct Systems - Total Head Loss
Major and minor loss in pipes, tubes and duct systems.
Pipe and Tube System Components - Minor (Dynamic) Loss Coefficients
Minor loss coefficients for components used in pipe and tube systems.
Pipes - Fluid Flow Velocities
Calculate fluid velocity and volume flow in pipes and tubes.
Poiseuille's Formula
Calculate the volume flow discharged through a smooth-walled circular pipe.
Prandtl Number
A dimensionless number approximating the ratio of momentum diffusivity to thermal diffusivity.
Pressure
Pressure Coefficient
The Pressure Coefficient is the ratio of pressure forces to inertial forces.
Pressure Energy
Calculate the potential of pressure energy in a incompressible fluid.
Pressure Gradient Diagrams
Static pressure graphical presentation throughout a fluid flow system.
Pressure Loss in Pipes connected in Series or Parallel
Calculate pressure loss in pipes connected in series or parallel.
Propane - Specific Heat vs. Temperature and Pressure
Online calculators, figures and tables with specific heat, Cp and Cv, of gasous and liquid propane, C3H8 vs. temperature and pressure - Imperial and SI Units .
Propane - Thermal Diffusivity vs. Temperature and Pressure
Pumps - Affinity Laws
Turbo machines affinity laws can be used to calculate volume capacity, head or power consumption in centrifugal pumps when changing speed or wheel diameters.
Pumps vs. Compressors, Blowers and Fans
The difference between pumps, compressors, blowers and fans.
Reynolds Number
Solubility
The amount of a solute that can be dissolved in a solvent.
Solubility Product Constants
The equilibrium constant, Ksp, for aqueous solutions of ionic compounds at 25°C.
Speed of Sound Equations
Calculate the speed of sound (the sonic velocity) in gases, fluids or solids.
Static Pressure vs. Head
Stokes' Formula
Viscosity force acting on a smooth sphere.
Strouhal Number
Introduction to the Strouhal Number
Surface Tension
Surface tension of liquids like water, mercury, oils and more.
Technical Terms in Fluid Mechanics
Some commonly used technical terms in fluid mechanics.
The Ideal Gas Law
Toluene - Thermophysical Properties
Chemical, physical and thermal properties of toluene, also called methylbenzene, toluol and phenylmethane. Phase diagram included.
Calculate specific work done by pumps, fans, compressors or turbines.
U-Tube Differential Pressure Manometers
Inclined and vertical u-tube manometers used to measure differential pressure in flow meters like pitot tubes, orifices and nozzles.
Universal and Individual Gas Constants
Velocity Pressure Head
Dynamic pressure or velocity head.
Viscosity - Converter Chart
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
Water - Dynamic (Absolute) and Kinematic Viscosity vs. Temperature and Pressure
Water - Prandtl Number vs. Temperature and Pressure
Figures and tables with Prandtl Number of liquid and gaseous water at varying temperarure and pressure, SI and Imperial units.
Water - Speed of Sound vs. Temperature
Speed of sound in water at temperatures ranging 32 - 212oF (0 - 100oC) - Imperial and SI units.
Water Control Valves - Flow Factor Kv Diagram
Water Flow in Tubes - Reynolds Number
Reynolds number for clean cold water flow.
Weber Number
The Weber Number may be useful when analyzing fluid flows where there is an interface between two different fluids.
Wind Energy
Available wind energy.
Wind Power
Power generation from wind.
Wind Shear
Wind slowed down at surface by trees and obstructions.
Wind Turbine Power Calculator
Online wind turbine calculator.
