μ = absolute or dynamic viscosity [kg/(m s)], [lb m /(ft h)]
c p = specific heat [J/(kg K)], [Btu/(lb m o F)]
k = thermal conductivity [W/(m K)], [Btu/(h ft 2 o F/ft)]
Below, Prandtl numbers of propane at varying temperatures and saturation pressure, as well as 1, 10 and 100 bara (14.5, 145 and 1450 psia) are given in figures and tables .
See also other properties of Propane at varying temperature and pressure: Density and specific weight , Dynamic and Kinematic Viscosity , Specific heat (heat capacity) , Thermal conductivity and Thermal diffusivity , and Thermophysical properties at standard conditions ,
as well as Prandtl number of Air , Ammonia , Carbon dioxide , Methane , Nitrogen and Water .
Prandtl number of propane at atmospheric pressure, varying temperature given as °C or °F:
Prandtl number of propane at 1, 10 and 100 bara (14.5, 145 and 1450 psia), varying temperature given as °C or °F:
Prandtl number of propane at atmospheric pressure, temperature given as K, °C or °F:
State | Temperature | Prandtl number | Temperature | Prandtl number | |||
[K] | [°C] | [-] | [K] | [°F] | [-] | ||
Liquid | 123 | -150 | 13.7 | 116 | -250 | 17.0 | |
148 | -125 | 7.59 | 144 | -200 | 8.15 | ||
173 | -100 | 5.32 | 172 | -150 | 5.39 | ||
198 | -75 | 4.20 | 200 | -100 | 4.15 | ||
223 | -50 | 3.57 | 228 | -50 | 3.48 | ||
231 | -42 | 3.43 | 231 | -44 | 3.43 | ||
Gas | 231 | -42 | 0.784 | 231 | -44 | 0.784 | |
248 | -25 | 0.770 | 244 | -20 | 0.773 | ||
263 | -10 | 0.761 | 255 | 0 | 0.766 | ||
268 | -5 | 0.759 | 266 | 20 | 0.760 | ||
273 | 0 | 0.757 | 272 | 30 | 0.757 | ||
278 | 5 | 0.755 | 278 | 40 | 0.755 | ||
283 | 10 | 0.753 | 283 | 50 | 0.753 | ||
293 | 20 | 0.751 | 294 | 70 | 0.750 | ||
298 | 25 | 0.750 | 300 | 80 | 0.749 | ||
303 | 30 | 0.749 | 305 | 90 | 0.748 | ||
323 | 50 | 0.746 | 311 | 100 | 0.747 | ||
348 | 75 | 0.745 | 339 | 150 | 0.745 | ||
373 | 100 | 0.744 | 366 | 200 | 0.744 | ||
398 | 125 | 0.744 | 394 | 250 | 0.744 | ||
423 | 150 | 0.743 | 422 | 300 | 0.743 | ||
448 | 175 | 0.740 | 478 | 400 | 0.736 | ||
473 | 200 | 0.737 | 533 | 500 | 0.723 | ||
523 | 250 | 0.726 | 589 | 600 | 0.706 | ||
573 | 300 | 0.711 | 644 | 700 | 0.686 | ||
623 | 350 | 0.694 | 700 | 800 | 0.665 | ||
673 | 400 | 0.675 | 755 | 900 | 0.644 | ||
773 | 500 | 0.637 | 811 | 1000 | 0.622 |
Prandtl number of propane at given temperatures and saturation pressure as well as 1, 10 and 100 bara (14.5, 145 and 1450 psia):
State | Temperature | Pressure | Prandtl number | |||
[K] | [°C] | [°F] | [bara] | [psia] | [-] | |
Liquid at equilibrium | 100 | -173 | -280 | 2.5E-07 | 3.7E-06 | 35.37 |
130 | -143 | -226 | 0.000176 | 0.00255 | 11.19 | |
160 | -113 | -172 | 0.00850 | 0.1233 | 6.270 | |
190 | -83.2 | -118 | 0.1055 | 1.530 | 4.495 | |
220 | -53.2 | -63.7 | 0.6058 | 8.787 | 3.643 | |
250 | -23.2 | -9.7 | 2.180 | 31.62 | 3.179 | |
280 | 6.9 | 44.3 | 5.817 | 84.37 | 2.920 | |
310 | 36.9 | 98.3 | 12.73 | 184.6 | 2.790 | |
320 | 46.9 | 116 | 15.99 | 231.9 | 2.770 | |
340 | 66.9 | 152 | 24.32 | 352.7 | 2.848 | |
355 | 81.9 | 179 | 32.43 | 470.4 | 3.259 | |
360 | 86.9 | 188 | 35.55 | 515.6 | 3.548 | |
Gas at equilibrium | 100 | -173 | -280 | 2.5E-07 | 3.7E-06 | 1.154 |
130 | -143 | -226 | 0.000176 | 0.00255 | 0.9481 | |
160 | -113 | -172 | 0.00850 | 0.1233 | 0.8499 | |
190 | -83.2 | -118 | 0.1055 | 1.530 | 0.8002 | |
220 | -53.2 | -63.7 | 0.6058 | 8.787 | 0.7840 | |
250 | -23.2 | -9.7 | 2.180 | 31.62 | 0.7956 | |
280 | 6.9 | 44.3 | 5.817 | 84.37 | 0.8357 | |
310 | 36.9 | 98.3 | 12.73 | 184.6 | 0.9249 | |
320 | 46.9 | 116 | 15.99 | 231.9 | 0.9789 | |
340 | 66.9 | 152 | 24.32 | 352.7 | 1.188 | |
355 | 81.9 | 179 | 32.43 | 470.4 | 1.732 | |
360 | 86.9 | 188 | 35.55 | 515.6 | 2.300 | |
Liquid | 85.53 | -187.62 | -305.72 | 1 | 14.5 | 99.44 |
100 | -173.15 | -279.67 | 1 | 14.5 | 35.88 | |
120 | -153.15 | -243.67 | 1 | 14.5 | 15.11 | |
140 | -133.15 | -207.67 | 1 | 14.5 | 8.891 | |
160 | -113.15 | -171.67 | 1 | 14.5 | 6.290 | |
180 | -93.15 | -135.67 | 1 | 14.5 | 4.942 | |
200 | -73.15 | -99.67 | 1 | 14.5 | 4.145 | |
220 | -53.15 | -63.67 | 1 | 14.5 | 3.633 | |
230.74 | -42.41 | -44.34 | 1 | 14.5 | 3.433 | |
Gas | 230.74 | -42.41 | -44.34 | 1 | 14.5 | 0.7857 |
240 | -33.2 | -27.67 | 1 | 14.5 | 0.7760 | |
260 | -13.2 | 8.33 | 1 | 14.5 | 0.7621 | |
280 | 6.9 | 44.33 | 1 | 14.5 | 0.7534 | |
300 | 26.9 | 80.33 | 1 | 14.5 | 0.7492 | |
320 | 46.9 | 116 | 1 | 14.5 | 0.7467 | |
340 | 66.9 | 152 | 1 | 14.5 | 0.7458 | |
360 | 86.9 | 188 | 1 | 14.5 | 0.7453 | |
400 | 127 | 260 | 1 | 14.5 | 0.7437 | |
500 | 227 | 440 | 1 | 14.5 | 0.7301 | |
600 | 327 | 620 | 1 | 14.5 | 0.7024 | |
700 | 427 | 800 | 1 | 14.5 | 0.6658 | |
800 | 527 | 980 | 1 | 14.5 | 0.6252 | |
900 | 627 | 1160 | 1 | 14.5 | 0.5840 | |
1000 | 727 | 1340 | 1 | 14.5 | 0.5434 | |
Liquid | 85.62 | -187.53 | -305.55 | 10 | 145 | 99.81 |
100 | -173 | -280 | 10 | 145 | 36.19 | |
120 | -153 | -244 | 10 | 145 | 15.21 | |
140 | -133 | -208 | 10 | 145 | 8.941 | |
160 | -113 | -172 | 10 | 145 | 6.318 | |
180 | -93.2 | -136 | 10 | 145 | 4.958 | |
200 | -73.2 | -99.7 | 10 | 145 | 4.156 | |
220 | -53.2 | -63.7 | 10 | 145 | 3.641 | |
240 | -33.2 | -27.7 | 10 | 145 | 3.300 | |
260 | -13.2 | 8.3 | 10 | 145 | 3.064 | |
280 | 6.9 | 44.3 | 10 | 145 | 2.909 | |
300.09 | 26.94 | 80.49 | 10 | 145 | 2.811 | |
Gas | 300.09 | 26.94 | 80.49 | 10 | 145 | 0.8851 |
320 | 46.9 | 116 | 10 | 145 | 0.8299 | |
340 | 66.9 | 152 | 10 | 145 | 0.8001 | |
360 | 86.9 | 188 | 10 | 145 | 0.7824 | |
400 | 127 | 260 | 10 | 145 | 0.7619 | |
500 | 227 | 440 | 10 | 145 | 0.7321 | |
600 | 327 | 620 | 10 | 145 | 0.6999 | |
700 | 427 | 800 | 10 | 145 | 0.6626 | |
800 | 527 | 980 | 10 | 145 | 0.6218 | |
900 | 627 | 1160 | 10 | 145 | 0.5810 | |
1000 | 727 | 1340 | 10 | 145 | 0.5407 | |
Liquid | 100 | -173 | -280 | 50 | 725 | 37.10 |
200 | -73.2 | -99.7 | 50 | 725 | 4.216 | |
300 | 26.9 | 80.3 | 50 | 725 | 2.802 | |
Supercritical phase | 400 | 127 | 260 | 50 | 725 | 1.305 |
500 | 227 | 440 | 50 | 725 | 0.8190 | |
Liquid | 86.45 | -187 | -304 | 100 | 1450 | 103.18 |
100 | -173 | -280 | 100 | 1450 | 39.46 | |
120 | -153 | -244 | 100 | 1450 | 16.28 | |
140 | -133 | -208 | 100 | 1450 | 9.433 | |
160 | -113 | -172 | 100 | 1450 | 6.596 | |
180 | -93.2 | -136 | 100 | 1450 | 5.139 | |
200 | -73.2 | -99.7 | 100 | 1450 | 4.282 | |
220 | -53.2 | -63.7 | 100 | 1450 | 3.735 | |
240 | -33.2 | -27.7 | 100 | 1450 | 3.367 | |
260 | -13.2 | 8.3 | 100 | 1450 | 3.112 | |
280 | 6.9 | 44.3 | 100 | 1450 | 2.934 | |
300 | 26.9 | 80.3 | 100 | 1450 | 2.798 | |
320 | 46.9 | 116 | 100 | 1450 | 2.691 | |
340 | 66.9 | 152 | 100 | 1450 | 2.597 | |
360 | 86.9 | 188 | 100 | 1450 | 2.504 | |
Supercritical phase | 400 | 127 | 260 | 100 | 1450 | 2.282 |
500 | 227 | 440 | 100 | 1450 | 1.085 | |
600 | 327 | 620 | 100 | 1450 | 0.8466 | |
700 | 427 | 800 | 100 | 1450 | 0.7417 | |
800 | 527 | 980 | 100 | 1450 | 0.6694 | |
900 | 627 | 1160 | 100 | 1450 | 0.6098 | |
1000 | 727 | 1340 | 100 | 1450 | 0.5586 |
Heat vs. work vs. energy.
Nomenclature rules for different groups of organic compounds and functional groups, together with examples of use of the rules.
A dimensionless number approximating the ratio of momentum diffusivity to thermal diffusivity.
Latent heat with vaporized propane.
Online calculators, figures and tables with specific heat, Cp and Cv, of gasous and liquid propane, C3H8 vs. temperature and pressure - Imperial and SI Units .
Vapor pressure vs. temperature.
Energy content and specific gravity of propane air mixtures.
Sizing of low pressure propane gas pipe lines - Imperial units.
Figures and tables with Prandtl Number of liquid and gaseous water at varying temperarure and pressure, SI and Imperial units.
