Prandtl Number
The Prandtl Number is a dimensionless number approximating the ratio of momentum diffusivity (kinematic viscosity) to thermal diffusivity - and can be expressed as
Pr = v / α                                     (1)
Pr = Prandtl's number
v = momentum diffusivity (m2/s)
α = thermal diffusivity (m2/s)
The Prandtl number can alternatively be expressed as
Pr = μ cp / k                                    (2)
μ = absolute or dynamic viscosity (kg/m s, lbm/(ft h))
cp = specific heat (J/kg K, Btu/lbmoF)
k = thermal conductivity (W/m K, Btu/(h ft2oF/ft))
The Prandtl Number is often used in heat transfer and free and forced convection calculations. It depends on the fluid properties.
  • gases - Pr ranges 0.7 - 1.0
  • dry air
  • water - Pr ranges 1 - 10
  • liquid metals - Pr ranges 0.001 - 0.03
  • oils - Pr ranges 50 - 2000
Example - Calculation of a Prandtl Number
μ = 15 (cP)
cp = 0.50 Btu/lbmoF
k = 0.06 (Btu/(h ft2oF/ft)
Dynamic viscosity can be converted from cP to lbm/(ft h) as
μ = 15 (cP) ( 2.4191 (lbm/(ft hr)) / (1 cP))
= 36.3 lb/(ft hr)
The Prandtl Number can be calculated as
Pr = 36.3 ( lb/(ft hr)) 0.50 Btu/lbmoF / 0.06 (Btu/(h ft2oF/ft)
= 302
Fluid Mechanics
Air Properties - Imperial Units
Thermodynamic properties of air at low pressures - imperial units.
Air Properties - SI Units
Ideal gas properties of air at low pressure - SI units.
Carbon Dioxide - Liquid Properties
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Dimensionless Numbers
Physical and chemical dimensionless quantities - Reynolds number, Euler, Nusselt, and Prandtl number - and many more.
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Laminar vs. Turbulent Flow - Reynolds Number Explained with Calculator
