The Prandtl Number - Pr - is a dimensionless number approximating the ratio of momentum diffusivity (kinematic viscosity) to thermal diffusivity - and is often used in heat transfer and free and forced convection calculations.
The Prandtl number can for calculations be expressed as
Pr = μ cp / k (1)
μ = absolute or dynamic viscosity (kg/(m s)), (lbm/(ft h))
cp = specific heat (J/(kg K)), (Btu/lbmoF)
k = thermal conductivity (W/(m K)), (Btu/(h ft2oF/ft))
Below, Prandtl numbers of nitrogen at varying temperatures and saturation pressure, as well as 1, 10 and 100 bara (14.5, 145 and 1450 psia) are given in figures and tables.
See also other properties of Nitrogen at varying temperature and pressure : Density and specific weight, Dynamic and kinematic viscosity, Specific heat (Heat capacity), Thermal conductivity and thermal diffusivity, and thermophysical properties at standard conditions,
as well as Prandtl number of Air, Ammonia, Carbon dioxide, Methane, Propane and Water .
Prandtl number of nitrogen at gas-liquid equilibrium pressure, varying temperature given as °C or °F:
Prandtl number of nitrogen at 1, 10 and 100 bara (14.5, 145 and 1450 psia), varying temperature given as °C or °F:
Prandtl number of nitrogen at atmospheric pressure, temperature given as K, °C or °F:
Temperature | Prandtl number | Temperature | Prandtl number | |||
(K) | (°C) | (-) | (K) | (°F) | (-) | |
78 | -195 | 0.847 | 78 | -320 | 0.849 | |
98 | -175 | 0.799 | 89 | -300 | 0.818 | |
123 | -150 | 0.769 | 116 | -250 | 0.775 | |
148 | -125 | 0.755 | 144 | -200 | 0.757 | |
173 | -100 | 0.746 | 172 | -150 | 0.746 | |
198 | -75 | 0.738 | 200 | -100 | 0.737 | |
223 | -50 | 0.731 | 228 | -50 | 0.730 | |
231 | -42 | 0.729 | 231 | -44 | 0.729 | |
248 | -25 | 0.726 | 244 | -20 | 0.726 | |
263 | -10 | 0.723 | 255 | 0 | 0.724 | |
268 | -5 | 0.722 | 266 | 20 | 0.723 | |
278 | 5 | 0.721 | 278 | 40 | 0.721 | |
283 | 10 | 0.720 | 283 | 50 | 0.720 | |
293 | 20 | 0.719 | 294 | 70 | 0.719 | |
298 | 25 | 0.718 | 300 | 80 | 0.718 | |
303 | 30 | 0.718 | 305 | 90 | 0.717 | |
323 | 50 | 0.714 | 311 | 100 | 0.716 | |
348 | 75 | 0.712 | 339 | 150 | 0.714 | |
373 | 100 | 0.710 | 366 | 200 | 0.710 | |
398 | 125 | 0.707 | 394 | 250 | 0.708 | |
423 | 150 | 0.706 | 422 | 300 | 0.706 | |
448 | 175 | 0.705 | 478 | 400 | 0.705 | |
473 | 200 | 0.705 | 533 | 500 | 0.706 | |
573 | 300 | 0.708 | 644 | 700 | 0.712 | |
623 | 350 | 0.711 | 700 | 800 | 0.717 | |
673 | 400 | 0.714 | 755 | 900 | 0.721 | |
773 | 500 | 0.723 | 811 | 1000 | 0.726 |
Prandtl number of nitrogen at given temperatures and pressures:
State | Temperature | Pressure | Prandtl number | |||
(K) | (°C) | (°F) | (bara) | (psia) | (-) | |
Liquid at equilibrium |
63.15 | -210.0 | -346.0 | 0.125 | 1.82 | 3.598 |
69 | -204 | -335 | 0.332 | 4.82 | 2.876 | |
75 | -198 | -325 | 0.760 | 11.0 | 2.402 | |
79 | -194 | -317 | 1.22 | 17.8 | 2.183 | |
85 | -188 | -307 | 2.29 | 33.2 | 1.956 | |
89 | -184 | -299 | 3.31 | 47.9 | 1.857 | |
95 | -178 | -289 | 5.41 | 78.4 | 1.771 | |
99 | -174 | -281 | 7.26 | 105 | 1.762 | |
105 | -168 | -271 | 10.8 | 157 | 1.793 | |
109 | -164 | -263 | 13.8 | 201 | 1.878 | |
115 | -158 | -253 | 19.4 | 281 | 2.170 | |
121 | -152 | -242 | 26.4 | 383 | 3.113 | |
Gas at equilibrium |
63.15 | -210.0 | -346.0 | 0.125 | 1.82 | 0.8240 |
69 | -204 | -335 | 0.332 | 4.82 | 0.8295 | |
75 | -198 | -325 | 0.760 | 11.0 | 0.8433 | |
79 | -194 | -317 | 1.22 | 17.8 | 0.8578 | |
85 | -188 | -307 | 2.29 | 33.2 | 0.8887 | |
89 | -184 | -299 | 3.31 | 47.9 | 0.9168 | |
95 | -178 | -289 | 5.41 | 78.4 | 0.9738 | |
99 | -174 | -281 | 7.26 | 105 | 1.025 | |
105 | -168 | -271 | 10.8 | 157 | 1.136 | |
109 | -164 | -263 | 13.8 | 201 | 1.249 | |
115 | -158 | -253 | 19.4 | 281 | 1.565 | |
121 | -152 | -242 | 26.4 | 383 | 2.553 | |
Liquid | 63.17 | -210.0 | -346.0 | 1 | 14.5 | 3.596 |
77.24 | -195.9 | -320.6 | 1 | 14.5 | 2.272 | |
Gas | 77.24 | -195.9 | -320.6 | 1 | 14.5 | 0.8508 |
80 | -193 | -316 | 1 | 14.5 | 0.8401 | |
100 | -173 | -280 | 1 | 14.5 | 0.7944 | |
120 | -153 | -244 | 1 | 14.5 | 0.7732 | |
140 | -133 | -208 | 1 | 14.5 | 0.7593 | |
160 | -113 | -172 | 1 | 14.5 | 0.7503 | |
180 | -93.2 | -136 | 1 | 14.5 | 0.7430 | |
200 | -73.2 | -100 | 1 | 14.5 | 0.7366 | |
220 | -53.2 | -63.7 | 1 | 14.5 | 0.7322 | |
240 | -33.2 | -27.7 | 1 | 14.5 | 0.7277 | |
260 | -13.2 | 8.3 | 1 | 14.5 | 0.7241 | |
280 | 6.9 | 44.3 | 1 | 14.5 | 0.7203 | |
300 | 26.9 | 80.3 | 1 | 14.5 | 0.7171 | |
320 | 46.9 | 116 | 1 | 14.5 | 0.7152 | |
340 | 66.9 | 152 | 1 | 14.5 | 0.7123 | |
360 | 86.9 | 188 | 1 | 14.5 | 0.7109 | |
400 | 127 | 260 | 1 | 14.5 | 0.7074 | |
500 | 227 | 440 | 1 | 14.5 | 0.7049 | |
600 | 327 | 620 | 1 | 14.5 | 0.7092 | |
700 | 427 | 800 | 1 | 14.5 | 0.7165 | |
800 | 527 | 980 | 1 | 14.5 | 0.7254 | |
900 | 627 | 1160 | 1 | 14.5 | 0.7343 | |
1000 | 727 | 1340 | 1 | 14.5 | 0.7417 | |
Liquid | 63.37 | -210 | -346 | 10 | 145 | 3.583 |
80 | -193 | -316 | 10 | 145 | 2.143 | |
100 | -173 | -280 | 10 | 145 | 1.747 | |
103.8 | -169.4 | -273 | 10 | 145 | 1.777 | |
Gas | 103.8 | -169.4 | -273 | 10 | 145 | 1.109 |
140.0 | -133.2 | -208 | 10 | 145 | 0.8276 | |
160 | -113 | -172 | 10 | 145 | 0.7918 | |
180 | -93.2 | -136 | 10 | 145 | 0.7715 | |
200 | -73.2 | -100 | 10 | 145 | 0.7574 | |
240 | -33.2 | -28 | 10 | 145 | 0.7391 | |
300 | 26.9 | 80.3 | 10 | 145 | 0.7234 | |
400 | 127 | 260 | 10 | 145 | 0.7097 | |
500 | 227 | 440 | 10 | 145 | 0.7067 | |
600 | 327 | 620 | 10 | 145 | 0.7098 | |
800 | 527 | 980 | 10 | 145 | 0.7258 | |
1100 | 827 | 1520 | 10 | 145 | 0.7485 | |
1600 | 1327 | 2420 | 10 | 145 | 0.7658 | |
Liquid | 100 | -173 | -280 | 50 | 725 | 1.670 |
Supercritical phase |
600 | 327 | 620 | 50 | 725 | 0.7113 |
1100 | 827 | 1520 | 50 | 725 | 0.7480 | |
1600 | 1327 | 2420 | 50 | 725 | 0.7652 | |
Liquid | 65.32 | -208 | -342 | 100 | 1450 | 3.466 |
80 | -193 | -316 | 100 | 1450 | 2.202 | |
100 | -173 | -280 | 100 | 1450 | 1.634 | |
Supercritical phase | 200 | -73.2 | -100 | 100 | 1450 | 0.9808 |
300 | 26.9 | 80.3 | 100 | 1450 | 0.7660 | |
400 | 127 | 260 | 100 | 1450 | 0.7237 | |
500 | 227 | 440 | 100 | 1450 | 0.7115 | |
600 | 327 | 620 | 100 | 1450 | 0.7114 | |
1100 | 827 | 1520 | 100 | 1450 | 0.7468 | |
1600 | 1327 | 2420 | 100 | 1450 | 0.7630 |
• Thermodynamics
Air - Prandtl Number
Conductive Heat Transfer
Cryogenic Fluids and Liquefied Gas Properties
Cryogenic properties as density, boiling points and heat of evaporation for fluids like hydrogen, methane, oxygen, nitrogen, fluorine and helium.
Heat, Work and Energy
Heat vs. work vs. energy.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Nitrogen - Enthalpy, Internal Energy and Entropy vs. Temperature
Enthalpy, internal energy and entropy of Nitrogen as an ideal gas.
Nitrogen - Dynamic and Kinematic Viscosity vs. Temperature and Pressure
Online calculator, figures and tables showing dynamic and kinematic viscosity of nitrogen, N2, at varying temperature and pressure - Imperial and SI Units.
Online calculator, figures and tables showing thermal conductivity of nitrogen, N2, at varying temperarure and pressure, SI and Imperial units.
Nitrogen - Thermal Diffusivity vs. Temperature and Pressure
Figures and tables showing thermal diffusivity of nitrogen at varying temperarure and pressure, SI and Imperial units.
Nitrogen Gas - Specific Heat vs. Temperature
Specific heat of Nitrogen Gas - N2 - at temperatures ranging 175 - 6000 K
Prandtl Number
A dimensionless number approximating the ratio of momentum diffusivity to thermal diffusivity.
Water - Prandtl Number vs. Temperature and Pressure
Figures and tables with Prandtl Number of liquid and gaseous water at varying temperarure and pressure, SI and Imperial units.
