Nitrogen - Enthalpy, Internal Energy and Entropy vs. Temperature
- Enthalpy
- Internal Energy
- Absolute Entropy at standard reference pressure
for Nitrogen - N2 - for temperatures ranging 0 - 3000 K, are indicated in the diagram below.
Download and print Nitrogen Gas Enthalpy, Internal Energy and Entropy Chart
• Gases and Compressed Air
• Thermodynamics
Helium - Thermophysical Properties
Chemical, Physical and Thermal Properties of Helium - He.
Humid Air and the Ideal Gas Law
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Individual & Universal Gas Constants: Definitions, Values, and Applications
Mole and the Avagadro's Number
The mole is the SI base unit for an amount of a substance.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Nitrogen - Thermal Diffusivity vs. Temperature and Pressure
Figures and tables showing thermal diffusivity of nitrogen at varying temperarure and pressure, SI and Imperial units.
Nitrogen Gas - Specific Heat vs. Temperature
Specific heat of Nitrogen Gas - N2 - at temperatures ranging 175 - 6000 K
Nitrogen Oxides (NOx) Emission from Fuels
Emission of Nitrogen Oxides - NOx - with combustion of fuels like oil, coal, propane and more.
Oxygen - Enthalpy, Internal Energy and Entropy vs. Temperature
Enthalpy, internal energy and entropy of oxygen as an ideal gas.
The Ideal Gas Law
