- T -
(K)
The values above apply to undissociated states. At high temperatures above 1500 K dissociation becomes appreciable and pressure is a significant variable.
See also other properties of Nitrogen at varying temperature and pressure : Density and specific weight , Dynamic and kinematic viscosity , Prandtl number , Specific heat (Heat capacity) , Thermal conductivity and thermal diffusivity , and thermophysical properties at standard conditions ,
as well as Specific heat of Air - at Constant Pressure and Varying Temperature , Air - at Constant Temperature and Varying Pressure , Ammonia , Butane , Carbon dioxide , Carbon monoxide , Ethane , Ethanol , Ethylene , Hydrogen , Methane , Methanol , Oxygen , Propane and Water .
Enthalpy, internal energy and entropy of Nitrogen as an ideal gas.
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Figures and tables showing thermal diffusivity of nitrogen at varying temperarure and pressure, SI and Imperial units.
