Specific heat (C) is the amount of heat required to change the temperature of a mass unit of a substance by one degree.
- Isobaric specific heat (Cp) is used for ethanol in a constant pressure (ΔP = 0) system.
- I sochoric specific heat (Cv) is used for ethanol in a constant-volume , (= isovolumetric or isometric ) closed system.
At ambient pressure and temperature the isobaric specific heat, CP, of liquid ethanol is 2.57 (kJ/kg K) or 0.614 (Btu/lb °F) = (cal/g K), while the isochoric specific heat, CV, is 2.18 (kJ/kg K) or 0.520 (Btu/lb °F) = (cal/g K).
However, the specific heat - CP and CV - will vary with temperature. This may influence on the accuracy of ethanol conditioning and industrial ethanol handling process calculations. When calculating mass and volume flow of ethanol in heated or cooled systems with high accuracy - the specific heat (= heat capacity) should be corrected according values in the figures and table below, or found by use of the calculator.
- Specific heat unit conversion
Online Liquid Ethanol Specific Heat Calculator
The calculator below can be used to estimate the specific heat of liquid ethanol at constant volum(CV) or constant pressure(CP) and at given temperature. For practical purpose the specific heat of liquid ethanol is constant with varying pressure up to critical point (241°C, 61.5 bara / 465°F, 892 psia).
The output specific heat is given as kJ/(kmol*K), kJ/(kg*K), kWh/(kg*K), kcal/(kg*K), Btu(IT)/(mol*°R) and Btu(IT)/(lbm *°R)
See also other properties of Ethanol at varying temperature and pressure : Density and specific weight and Dynamic and kinematic viscosity, and Thermophysical properties at standard conditions,
as well as Specific heat (Heat capacity) of Air - at Constant Pressure and Varying Temperature, Air - at Constant Temperature and Varying Pressure, Ammonia, Butane, Carbon dioxide, Carbon monoxide, Ethane, Ethylene, Hydrogen, Methane, Methanol, Nitrogen, Oxygen, Propane and Water .
Isobaric specific heat, CP, of ethanol at given temperatures and pressure s:
For full table with Imperial units - rotate the screen!
| State | Temperature | Pressure | Specific heat at constant pressure, CP (isobaric) | Cp/Cv | ||||||||
| (K) | (°C) | (°F) | (MPa) | (bara) | (psia) | (kJ/mol K) | (kJ/kg K) | (kWh/(kg K)) | (kcal(IT)/(kg K)), (Btu(IT)/lb °F) | (Btu(IT)/(mol*°R)) | (-) | |
| Liquid | 250 | -23.2 | -9.7 | 0.000270 | 0.00270 | 0.0392 | 0.09361 | 2.032 | 0.000564 | 0.4853 | 0.04929 | 1.22 |
| 280 | 6.9 | 44.3 | 0.00258 | 0.0258 | 0.375 | 0.1083 | 2.351 | 0.000653 | 0.5614 | 0.05702 | 1.18 | |
| 298.2 | 25.0 | 77.0 | 0.0080 | 0.080 | 1.16 | 0.1184 | 2.570 | 0.000714 | 0.6138 | 0.06234 | 1.18 | |
| 310 | 36.9 | 98.3 | 0.0153 | 0.153 | 2.22 | 0.1252 | 2.719 | 0.000755 | 0.6493 | 0.06595 | 1.17 | |
| 340 | 66.9 | 152 | 0.0635 | 0.635 | 9.22 | 0.1412 | 3.064 | 0.000851 | 0.7318 | 0.07432 | 1.19 | |
| 370 | 96.9 | 206 | 0.2021 | 2.021 | 29.30 | 0.1554 | 3.374 | 0.000937 | 0.8058 | 0.08184 | 1.22 | |
| 400 | 127 | 260 | 0.5245 | 5.245 | 76.07 | 0.1688 | 3.665 | 0.00102 | 0.8753 | 0.08890 | 1.26 | |
| 423.9 | 151 | 303 | 1.000 | 10.00 | 145.0 | 0.1802 | 3.910 | 0.00109 | 0.9340 | 0.09486 | 1.31 | |
| 430 | 157 | 314 | 1.165 | 11.65 | 169.0 | 0.1834 | 3.981 | 0.00111 | 0.9509 | 0.09658 | 1.33 | |
| 460 | 187 | 368 | 2.292 | 22.92 | 332.4 | 0.2050 | 4.451 | 0.00124 | 1.063 | 0.1080 | 1.46 | |
| 490 | 217 | 422 | 4.095 | 40.95 | 594.0 | 0.2651 | 5.754 | 0.00160 | 1.374 | 0.1396 | 1.86 | |
| 501.4 | 228 | 443 | 5.000 | 50.00 | 725.2 | 0.3515 | 7.630 | 0.00212 | 1.822 | 0.1851 | 2.45 | |
| Gas | 250 | -23.2 | -9.7 | 0.000270 | 0.00270 | 0.0392 | 0.06722 | 1.459 | 0.000405 | 0.3485 | 0.03539 | 1.14 |
| 280 | 6.9 | 44.3 | 0.00258 | 0.0258 | 0.375 | 0.07115 | 1.544 | 0.000429 | 0.3689 | 0.03746 | 1.13 | |
| 298.2 | 25.0 | 77.0 | 0.0080 | 0.0800 | 1.16 | 0.07380 | 1.602 | 0.000445 | 0.3826 | 0.03886 | 1.13 | |
| 310 | 36.9 | 98.3 | 0.0153 | 0.153 | 2.22 | 0.07546 | 1.638 | 0.000455 | 0.3912 | 0.03974 | 1.13 | |
| 340 | 66.9 | 152 | 0.0635 | 0.635 | 9.22 | 0.08074 | 1.753 | 0.000487 | 0.4186 | 0.04251 | 1.13 | |
| 370 | 96.9 | 206 | 0.2021 | 2.021 | 29.30 | 0.08806 | 1.911 | 0.000531 | 0.4565 | 0.04637 | 1.15 | |
| 400 | 127 | 260 | 0.5245 | 5.245 | 76.07 | 0.09894 | 2.148 | 0.000597 | 0.5129 | 0.05210 | 1.18 | |
| 423.9 | 151 | 303 | 1.000 | 10.00 | 145.0 | 0.1118 | 2.428 | 0.000674 | 0.5798 | 0.05889 | 1.24 | |
| 430 | 157 | 314 | 1.165 | 11.65 | 169.0 | 0.1161 | 2.520 | 0.000700 | 0.6019 | 0.06113 | 1.26 | |
| 460 | 187 | 368 | 2.292 | 22.92 | 332.4 | 0.1473 | 3.197 | 0.000888 | 0.7635 | 0.07755 | 1.43 | |
| 490 | 217 | 422 | 4.095 | 40.95 | 594.0 | 0.2320 | 5.036 | 0.00140 | 1.203 | 0.1222 | 1.98 | |
| 501.4 | 228 | 443 | 5.000 | 50.00 | 725.2 | 0.3410 | 7.402 | 0.00206 | 1.768 | 0.1796 | 2.75 | |
| Liquid | 300 | 26.9 | 80.3 | 0.1 | 1 | 14.5 | 0.1196 | 2.597 | 0.000721 | 0.6202 | 0.06299 | 1.17 |
| 351.1 | 77.9 | 172 | 0.1 | 1 | 14.5 | 0.1466 | 3.182 | 0.000884 | 0.7599 | 0.07718 | 1.20 | |
| Gas | 351.1 | 77.9 | 172 | 0.1 | 1 | 14.5 | 0.08313 | 1.804 | 0.000501 | 0.4310 | 0.04377 | 1.14 |
| 400 | 127 | 260 | 0.1 | 1 | 14.5 | 0.09000 | 1.954 | 0.000543 | 0.4666 | 0.04739 | 1.12 | |
| 500 | 227 | 440 | 0.1 | 1 | 14.5 | 0.1016 | 2.206 | 0.000613 | 0.5268 | 0.05351 | 1.09 | |
| 600 | 327 | 620 | 0.1 | 1 | 14.5 | 0.1125 | 2.442 | 0.000678 | 0.5834 | 0.05925 | 1.08 | |
| Liquid | 300 | 26.9 | 80.3 | 1 | 10 | 145 | 0.1195 | 2.595 | 0.000721 | 0.6198 | 0.06294 | 1.17 |
| 400 | 127 | 260 | 1 | 10 | 145 | 0.1686 | 3.659 | 0.001016 | 0.8740 | 0.08876 | 1.26 | |
| 423.9 | 151 | 303 | 1 | 10 | 145 | 0.1802 | 3.910 | 0.001086 | 0.9340 | 0.09486 | 1.31 | |
| Gas | 423.9 | 151 | 303 | 1 | 10 | 145 | 0.1118 | 2.428 | 0.000674 | 0.5798 | 0.05889 | 1.24 |
| 500 | 227 | 440 | 1 | 10 | 145 | 0.1101 | 2.389 | 0.000664 | 0.5707 | 0.05796 | 1.14 | |
| 600 | 327 | 620 | 1 | 10 | 145 | 0.1161 | 2.519 | 0.000700 | 0.6017 | 0.06111 | 1.10 | |
| Liquid | 300 | 26.9 | 80.3 | 5 | 50 | 725 | 0.1192 | 2.588 | 0.000719 | 0.6181 | 0.06278 | 1.17 |
| 400 | 127 | 260 | 5 | 50 | 725 | 0.1666 | 3.616 | 0.00100 | 0.8636 | 0.08771 | 1.25 | |
| 501.4 | 228 | 443 | 5 | 50 | 725 | 0.3515 | 7.630 | 0.00212 | 1.822 | 0.1851 | 2.45 | |
| Gas | 501.4 | 228 | 443 | 5 | 50 | 725 | 0.3410 | 7.402 | 0.00206 | 1.768 | 0.1796 | 2.75 |
| 600 | 327 | 620 | 5 | 50 | 725 | 0.1366 | 2.965 | 0.000824 | 0.7082 | 0.07192 | 1.20 | |
| Liquid | 300 | 26.9 | 80.3 | 10 | 100 | 1450 | 0.1189 | 2.580 | 0.000717 | 0.6162 | 0.06258 | 1.17 |
| Supercritical phase |
400 | 127 | 260 | 10 | 100 | 1450 | 0.1646 | 3.572 | 0.000992 | 0.8532 | 0.08665 | 1.24 |
| 500 | 227 | 440 | 10 | 100 | 1450 | 0.2220 | 4.820 | 0.00134 | 1.151 | 0.1169 | 1.58 | |
| 600 | 327 | 620 | 10 | 100 | 1450 | 0.1874 | 4.069 | 0.00113 | 0.9718 | 0.09870 | 1.49 | |
| Liquid | 300 | 26.9 | 80.3 | 100 | 1000 | 14500 | 0.1157 | 2.512 | 0.000698 | 0.5999 | 0.06093 | 1.14 |
400 | 127 | 260 | 100 | 1000 | 14500 | 0.1508 | 3.274 | 0.000909 | 0.7819 | 0.07941 | 1.17 |
| 500 | 227 | 440 | 100 | 1000 | 14500 | 0.1643 | 3.567 | 0.000991 | 0.8520 | 0.08653 | 1.24 | |
| 600 | 327 | 620 | 100 | 1000 | 14500 | 0.1655 | 3.593 | 0.000998 | 0.8582 | 0.08716 | 1.32 | |
300 | 26.9 | 80.3 | 200 | 2000 | 29000 | 0.1150 | 2.495 | 0.000693 | 0.5960 | 0.06053 | 1.13 |
| 400 | 127 | 260 | 200 | 2000 | 29000 | 0.1454 | 3.156 | 0.000877 | 0.7538 | 0.07656 | 1.15 | |
| 500 | 227 | 440 | 200 | 2000 | 29000 | 0.1562 | 3.391 | 0.000942 | 0.8100 | 0.08226 | 1.21 | |
| 600 | 327 | 620 | 200 | 2000 | 29000 | 0.1557 | 3.379 | 0.000939 | 0.8070 | 0.08196 | 1.29 | |
Isochoric specific heat, CV, of ethanol at given temperatures and pressure s:
| State | Temperature | Pressure | Specific heat at constant volume, CV (isochoric) | Cp/Cv | ||||||||
Liquid at |
250 | -23.2 | -9.7 | 0.000270 | 0.00270 | 0.0392 | 0.07666 | 1.664 | 0.000462 | 0.3974 | 0.04036 | 1.22 |
| 280 | 6.9 | 44.3 | 0.00258 | 0.0258 | 0.375 | 0.09165 | 1.989 | 0.000553 | 0.4752 | 0.04826 | 1.18 | |
| 298.2 | 25.0 | 77.0 | 0.0080 | 0.080 | 1.16 | 0.1003 | 2.178 | 0.000605 | 0.5202 | 0.05283 | 1.18 | |
| 310 | 36.9 | 98.3 | 0.0153 | 0.153 | 2.22 | 0.1067 | 2.316 | 0.000643 | 0.5532 | 0.05618 | 1.17 | |
| 340 | 66.9 | 152 | 0.0635 | 0.635 | 9.22 | 0.1189 | 2.582 | 0.000717 | 0.6166 | 0.06262 | 1.19 | |
| 370 | 96.9 | 206 | 0.2021 | 2.021 | 29.30 | 0.1279 | 2.777 | 0.000771 | 0.6632 | 0.06736 | 1.22 | |
| 400 | 127 | 260 | 0.5245 | 5.245 | 76.07 | 0.1341 | 2.910 | 0.000808 | 0.6950 | 0.07059 | 1.26 | |
| 423.9 | 151 | 303 | 1.000 | 10.00 | 145.0 | 0.1373 | 2.981 | 0.000828 | 0.7119 | 0.07231 | 1.31 | |
| 430 | 157 | 314 | 1.165 | 11.65 | 169.0 | 0.1380 | 2.995 | 0.000832 | 0.7154 | 0.07265 | 1.33 | |
| 460 | 187 | 368 | 2.292 | 22.92 | 332.4 | 0.1404 | 3.048 | 0.000847 | 0.7280 | 0.07393 | 1.46 | |
| 490 | 217 | 422 | 4.095 | 40.95 | 594.0 | 0.1423 | 3.090 | 0.000858 | 0.7380 | 0.07495 | 1.86 | |
| 501.4 | 228 | 443 | 5.000 | 50.00 | 725.2 | 0.1434 | 3.113 | 0.000865 | 0.7435 | 0.07551 | 2.45 | |
| Gas at equilibrium |
250 | -23.2 | -9.7 | 0.000270 | 0.00270 | 0.0392 | 0.05889 | 1.278 | 0.000355 | 0.3053 | 0.03101 | 1.14 |
| 280 | 6.9 | 44.3 | 0.00258 | 0.0258 | 0.375 | 0.06275 | 1.362 | 0.000378 | 0.3253 | 0.03304 | 1.13 | |
| 298.2 | 25.0 | 77.0 | 0.0080 | 0.080 | 1.16 | 0.06531 | 1.418 | 0.000394 | 0.3386 | 0.03439 | 1.13 | |
| 310 | 36.9 | 98.3 | 0.0153 | 0.153 | 2.22 | 0.06682 | 1.450 | 0.000403 | 0.3464 | 0.03518 | 1.13 | |
| 340 | 66.9 | 152 | 0.0635 | 0.635 | 9.22 | 0.07134 | 1.548 | 0.000430 | 0.3698 | 0.03756 | 1.13 | |
| 370 | 96.9 | 206 | 0.2021 | 2.021 | 29.30 | 0.07684 | 1.668 | 0.000463 | 0.3984 | 0.04046 | 1.15 | |
| 400 | 127 | 260 | 0.5245 | 5.245 | 76.07 | 0.08377 | 1.818 | 0.000505 | 0.4343 | 0.04411 | 1.18 | |
| 423.9 | 151 | 303 | 1.000 | 10.00 | 145.0 | 0.09052 | 1.965 | 0.000546 | 0.4693 | 0.04766 | 1.24 | |
| 430 | 157 | 314 | 1.165 | 11.65 | 169.0 | 0.09245 | 2.007 | 0.000557 | 0.4793 | 0.04868 | 1.26 | |
| 460 | 187 | 368 | 2.292 | 22.92 | 332.4 | 0.1032 | 2.241 | 0.000622 | 0.5352 | 0.05436 | 1.43 | |
| 490 | 217 | 422 | 4.095 | 40.95 | 594.0 | 0.1171 | 2.542 | 0.000706 | 0.6071 | 0.06165 | 1.98 | |
| 501.4 | 228 | 443 | 5.000 | 50.00 | 725.2 | 0.1239 | 2.689 | 0.000747 | 0.6423 | 0.06524 | 2.75 | |
| Liquid | 300 | 26.9 | 80.3 | 0.1 | 1 | 14.5 | 0.1019 | 2.213 | 0.000615 | 0.5285 | 0.05367 | 1.17 |
| 351.1 | 77.9 | 172 | 0.1 | 1 | 14.5 | 0.1226 | 2.661 | 0.000739 | 0.6357 | 0.06456 | 1.20 | |
| Gas | 351.1 | 77.9 | 172 | 0.1 | 1 | 14.5 | 0.07322 | 1.589 | 0.000441 | 0.3796 | 0.03856 | 1.14 |
| 400 | 127 | 260 | 0.1 | 1 | 14.5 | 0.08064 | 1.750 | 0.000486 | 0.4181 | 0.04246 | 1.12 | |
| 500 | 227 | 440 | 0.1 | 1 | 14.5 | 0.09291 | 2.017 | 0.000560 | 0.4817 | 0.04892 | 1.09 | |
| 600 | 327 | 620 | 0.1 | 1 | 14.5 | 0.10403 | 2.258 | 0.000627 | 0.5393 | 0.05478 | 1.08 | |
| Liquid | 300 | 26.9 | 80.3 | 1 | 10 | 145 | 0.1019 | 2.212 | 0.000614 | 0.5284 | 0.05366 | 1.17 |
| 400 | 127 | 260 | 1 | 10 | 145 | 0.1340 | 2.909 | 0.000808 | 0.6947 | 0.07056 | 1.26 | |
| 423.9 | 151 | 303 | 1 | 10 | 145 | 0.1373 | 2.981 | 0.000828 | 0.7119 | 0.07231 | 1.31 | |
| Gas | 423.9 | 151 | 303 | 1 | 10 | 145 | 0.09052 | 1.965 | 0.000546 | 0.4693 | 0.04766 | 1.24 |
| 500 | 227 | 440 | 1 | 10 | 145 | 0.09695 | 2.105 | 0.000585 | 0.5027 | 0.05105 | 1.14 | |
| 600 | 327 | 620 | 1 | 10 | 145 | 0.10581 | 2.297 | 0.000638 | 0.5486 | 0.05572 | 1.10 | |
| Liquid | 300 | 26.9 | 80.3 | 5 | 50 | 725 | 0.1019 | 2.211 | 0.000614 | 0.5280 | 0.05363 | 1.17 |
| 400 | 127 | 260 | 5 | 50 | 725 | 0.1336 | 2.900 | 0.000806 | 0.6926 | 0.07034 | 1.25 | |
| 501.4 | 228 | 443 | 5 | 50 | 725 | 0.1434 | 3.113 | 0.000865 | 0.7435 | 0.07551 | 2.45 | |
| Gas | 501.4 | 228 | 443 | 5 | 50 | 725 | 0.1239 | 2.689 | 0.000747 | 0.6423 | 0.06524 | 2.75 |
| 600 | 327 | 620 | 5 | 50 | 725 | 0.1142 | 2.479 | 0.000689 | 0.5920 | 0.06013 | 1.20 | |
| Liquid | 300 | 26.9 | 80.3 | 10 | 100 | 1450 | 0.1018 | 2.210 | 0.000614 | 0.5277 | 0.05360 | 1.17 |
400 | 127 | 260 | 10 | 100 | 1450 | 0.1331 | 2.890 | 0.000803 | 0.6902 | 0.07010 | 1.24 |
| 500 | 227 | 440 | 10 | 100 | 1450 | 0.1403 | 3.046 | 0.000846 | 0.7274 | 0.07388 | 1.58 | |
| 600 | 327 | 620 | 10 | 100 | 1450 | 0.1260 | 2.735 | 0.000760 | 0.6532 | 0.06634 | 1.49 | |
| Liquid | 300 | 26.9 | 80.3 | 100 | 1000 | 14500 | 0.1015 | 2.203 | 0.000612 | 0.5262 | 0.05344 | 1.14 |
400 | 127 | 260 | 100 | 1000 | 14500 | 0.1290 | 2.800 | 0.000778 | 0.6689 | 0.06793 | 1.17 |
| 500 | 227 | 440 | 100 | 1000 | 14500 | 0.1322 | 2.870 | 0.000797 | 0.6854 | 0.06962 | 1.24 | |
| 600 | 327 | 620 | 100 | 1000 | 14500 | 0.1258 | 2.730 | 0.000758 | 0.6520 | 0.06621 | 1.32 | |
300 | 26.9 | 80.3 | 200 | 2000 | 29000 | 0.1020 | 2.213 | 0.000615 | 0.5286 | 0.05369 | 1.13 |
| 400 | 127 | 260 | 200 | 2000 | 29000 | 0.1268 | 2.752 | 0.000764 | 0.6573 | 0.06676 | 1.15 | |
| 500 | 227 | 440 | 200 | 2000 | 29000 | 0.1287 | 2.793 | 0.000776 | 0.6671 | 0.06776 | 1.21 | |
| 600 | 327 | 620 | 200 | 2000 | 29000 | 0.1207 | 2.619 | 0.000728 | 0.6256 | 0.06353 | 1.29 | |
british thermal unit(International table) = (Btu(IT)), degree celcius = (°C), degree fahrenheit = (°F), degree kelvin = (K), degree rankin = (°R), joule = (J), kilocalorie(International table) = (kcal(IT)), kilogram = (kg), kilojoule = (kJ), kilowatthour = (kWh), mole = (mol), pound =(lb)
K in the units can be replaced by °C, and vise versa. °R in the units can be replaced by °F, and vise versa.
- 1 Btu/(lb °F) = 1 Btu/(lb °R) = 1 kcal(IT)/(kg °C) = 1 kcal(IT)/(kg K) = 4186.8 J/(kg K) = 0.81647 kcal(IT)/(lb °F) = 1.163×10-3 kWh/(kg K)
- 1 J/(kg K) = 1 J/(kg °C) = 2.3885×10-4 kcal(IT)/(kg oC) = 2.3885×10-4 Btu/(lb °F) = 1.9501×10-4 kcal(IT)/(lb °F)
- 1 kcal(IT)/(kg °C) = 1 Btu/(lb °F) = 4186.8 J/(kg K) = 0.81647 kcal(IT)/(lb °F) = 1.163×10-3 kWh/(kg K)
- 1 kcal(IT)/(lb °F) = 1.2248 Btu/(lb °F) = 1.2248 kcal(IT)/(kg °C) = 5127.9 J/(kg K)
- 1 kJ/kgK = 1 kJ/(kg °C) = 1000 J/(kg K) = 1000 J/(kg °C) = 0.23885 kcal(IT)/(kg °C) = 0.23885 Btu/(lb °F) = 0.19501 kcal(IT)/(lb °F) = 2.7778×10-4 kWh/(kg K)
- 1 kWh/(kg K) = 0.85985 kcal(IT)/(kg °C) = 0.85985 Btu/(lb °F) = 3.6 kJ/kgK
- 1 mol of air = 28.96546 g
• Thermodynamics
Bio Ethanol Production - Raw Materials
Raw materials used for Ethanol Bio-fuel production.
Combustion Heat
Ethanol - Thermophysical properties
Chemical, physical and thermal properties of ethanol (also called alcohol or ethyl alcohol). Phase diagram included.
Ethanol Freeze Protected Water Solutions
Freezing temperature and flash points for ethanol based water solutions or brines.
Ethanol Water Mixtures - Densities vs. Temperature
Density of Ethyl Alcohol aqueous solutions.
Freeze Protection of Water based Heat Transfer Fluids
Comparing antifreezes used in water based heat transfer fluids or brines.
Liquids - Latent Heat of Evaporation
Latent heat of vaporization for fluids like alcohol, ether, nitrogen, water and more.
Methanol - Thermophysical Properties vs. Temperature
Thermophysical properties of methanol.
Methanol Freeze Protected Heat Transfer Liquids
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
Specific Heat Capacity of Air: Isobaric and Isochoric Heat Capacities at Various Temperatures and Pressures
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
