Specific heat (C) is the amount of heat required to change the temperature of a mass unit of a substance by one degree.
  • Isobaric specific heat (Cp) is used for substances in a constant pressure (ΔP = 0) system.
  • I sochoric specific heat (Cv) is used for substances in a constant-volume , (= isovolumetric or isometric ) closed system.
At ambient pressure and temperature the isobaric specific heat, CP, of gaseous butane is 1.73 kJ/kg K or 0.414 Btu/lb °F = cal/g K, while the isochoric specific heat, CV, is 1.57 kJ/kg K or 0.374 Btu/lb °F = cal/g K.
However,  the specific heat  - CP and CV - will vary with temperature. This may influence on the accuracy of butane conditioning and industrial butane handling process calculations. When calculating mass and volume flow of butane in heated or cooled systems with high accuracy - the specific heat should be corrected according values in the figures and table below, or found by use of the calculator.
Online Butane Specific Heat Calculator
The calculator below can be used to estimate the specific heat of butane at constant volum(CV) or constant pressure(CP) and at given temperature and atmospheric pressure. For practical purpose the specific heat of liquid butane at a given temperature is constant with varying pressure up to 50°C /100°F .
Boiling point of propane is -0.8°C / 30.5°F, and thus, butane is present as liquid below this temperature at atmospheric pressure.
The output specific heat is given as kJ/(kmol*K), kJ/(kg*K), kWh/(kg*K), kcal/(kg*K), Btu(IT)/(mol*°R) and Btu(IT)/(lbm *°R)
See also other properties of butane at varying temperature and pressure : Density and specific weight, Dynamic and Kinematic Viscosity and Thermal Conductivity, and Thermophysical properties at standard conditions,
as well as Specific heat of Air - at Constant Pressure and Varying Temperature, Air - at Constant Temperature and Varying Pressure, Ammonia, Carbon dioxide, Carbon monoxide, Ethane, Ethanol, Ethylene, Hydrogen, Methane, Methanol, Nitrogen, Oxygen, Propane and Water .
Isobaric specifc heat, CP, of butane with varying temperature and equilibrium pressure, given as °C and °F:
Isochoric specific heat, CV, of butane with varying temperature and equilibrium pressure, given as °C and °F:
Isobaric specific heat, CP, of butane with varing temperature and pressure, given as °C and °F:
Isochoric specific heat, CV, of butane with varing temperature and pressure, given as °C and °F:
Isobaric specific heat, CP, of butane at given temperatures and pressure s:
For full table with Imperial values - rotate the screen!
State Temperature Pressure Specific heat at constant pressure, CP (isobaric) Cp/Cv
(K) (°C) (°F) (bara) (psia) (kJ/mol K) (kJ/kg K) (Wh/(kg K)) (kcal(IT)/(kg K)),
(Btu(IT)/lb °F)
(Btu(IT)/(mol*°R)) (-)
Liquid at
equilibrium
134.9 -138.25 -216.85 6.7E-06 9.7E-05 0.1147 1.973 0.5481 0.4712 0.06038 1.37
150 -123 -190 8.6E-05 1.2E-03 0.1154 1.986 0.5517 0.4743 0.06078 1.38
200 -73 -100 0.0194 0.281 0.1198 2.062 0.5728 0.4925 0.06311 1.40
220 -53 -64 0.0781 1.13 0.1228 2.113 0.5869 0.5047 0.06467 1.40
240 -33.2 -28 0.241 3.49 0.1265 2.176 0.6044 0.5197 0.06660 1.41
260 -13.2 8.3 0.610 8.84 0.1310 2.254 0.6261 0.5384 0.06898 1.41
280 6.9 44.3 1.33 19.3 0.1363 2.345 0.6514 0.5601 0.07177 1.41
300 26.9 80.3 2.58 37.4 0.1425 2.451 0.6808 0.5854 0.07501 1.42
320 46.9 116 4.56 66.2 0.1498 2.577 0.7158 0.6155 0.07887 1.43
340 66.9 152 7.52 109 0.1586 2.729 0.7581 0.6518 0.08352 1.45
360 86.9 188 11.7 170 0.1701 2.926 0.8128 0.6989 0.08955 1.49
380 106.9 224 17.4 252 0.1872 3.221 0.8947 0.7693 0.09858 1.56
400 126.9 260 25.0 362 0.2231 3.838 1.066 0.9167 0.1175 1.77
420 146.9 296 34.9 506 0.5145 8.852 2.459 2.114 0.2709 3.76
Gas at
equilibrium
134.9 -138.25 -216.85 6.7E-06 9.7E-05 0.06428 1.106 0.3072 0.2642 0.03385 1.15
150 -123 -190 8.6E-05 1.2E-03 0.06731 1.158 0.3217 0.2766 0.03544 1.14
200 -73 -100 0.0194 0.281 0.07666 1.319 0.3664 0.3150 0.04037 1.12
220 -53 -64 0.0781 1.13 0.08091 1.392 0.3867 0.3325 0.04260 1.12
240 -33.2 -28 0.241 3.49 0.08579 1.476 0.4100 0.3525 0.04517 1.12
260 -13.2 8.3 0.610 8.84 0.09143 1.573 0.4369 0.3757 0.04814 1.12
280 6.9 44.3 1.33 19.3 0.09788 1.684 0.4678 0.4022 0.05154 1.12
300 26.9 80.3 2.58 37.4 0.1053 1.811 0.5031 0.4325 0.05543 1.13
320 46.9 116 4.56 66.2 0.1139 1.960 0.5444 0.4681 0.05999 1.15
340 66.9 152 7.52 109 0.1245 2.142 0.5950 0.5116 0.06556 1.18
360 86.9 188 11.7 170 0.1383 2.379 0.6608 0.5682 0.07281 1.23
380 107 224 17.4 252 0.1601 2.754 0.7650 0.6578 0.08429 1.34
400 127 260 25.0 362 0.2106 3.623 1.006 0.8653 0.1109 1.64
420 147 296 34.9 506 0.6231 10.72 2.978 2.56042 0.3281 4.39
Liquid 150 -123 -190 1 14.5 0.1154 1.986 0.5517 0.4744 0.06079 1.38
200 -73.2 -100 1 14.5 0.1199 2.062 0.5728 0.4925 0.06311 1.40
250 -23.2 -9.7 1 14.5 0.1286 2.213 0.6148 0.5286 0.06773 1.41
272.31 -0.84 30.49 1 14.5 0.1342 2.308 0.6411 0.5513 0.07064 1.41
Gas 272.31 -0.8 30.5 1 14.5 0.0953 1.639 0.4553 0.3915 0.05016 1.12
300 26.9 80.3 1 14.5 0.1010 1.738 0.4828 0.4152 0.05320 1.10
350 76.9 170 1 14.5 0.1130 1.944 0.5400 0.4643 0.05950 1.09
400 127 260 1 14.5 0.1255 2.158 0.5996 0.5155 0.06606 1.08
450 177 350 1 14.5 0.1376 2.367 0.6574 0.5652 0.07243 1.07
500 227 440 1 14.5 0.1490 2.563 0.7120 0.6122 0.07844 1.06
550 277 530 1 14.5 0.1596 2.746 0.7628 0.6559 0.08404 1.06
Liquid 150 -123 -190 10 145 0.1154 1.985 0.5515 0.4742 0.06076 1.38
200 -73.2 -100 10 145 0.1198 2.061 0.5724 0.4922 0.06307 1.40
250 -23.2 -9.7 10 145 0.1285 2.210 0.6139 0.5278 0.06764 1.40
300 26.9 80.3 10 145 0.1421 2.445 0.6791 0.5839 0.07482 1.41
350 76.9 170 10 145 0.1638 2.818 0.7827 0.6730 0.08624 1.47
352.62 79.47 175.05 10 145 0.1654 2.846 0.7905 0.6797 0.08709 1.47
Gas 352.62 79.47 175.05 10 145 0.1326 2.282 0.6338 0.5450 0.06983 1.21
400 127 260 10 145 0.1341 2.307 0.6409 0.5511 0.07061 1.12
450 177 350 10 145 0.1425 2.452 0.6810 0.5856 0.07503 1.09
500 227 440 10 145 0.1522 2.619 0.7274 0.6255 0.08015 1.08
550 277 530 10 145 0.1619 2.785 0.7737 0.6653 0.08524 1.07
Liquid 150 -123 -190 50 725 0.1153 1.983 0.5508 0.4736 0.06069 1.37
200 -73.2 -100 50 725 0.1194 2.055 0.5708 0.4908 0.06289 1.39
250 -23.2 -9.7 50 725 0.1277 2.198 0.6105 0.5249 0.06726 1.39
300 26.9 80.3 50 725 0.1403 2.415 0.6707 0.5767 0.07390 1.39
350 76.9 170 50 725 0.1580 2.718 0.7550 0.6492 0.08319 1.41
400 127 260 50 725 0.1892 3.255 0.9043 0.7775 0.09963 1.52
Supercritical
phase
450 177 350 50 725 0.3508 6.036 1.677 1.4416 0.18472 2.46
500 227 440 50 725 0.1848 3.180 0.8833 0.7595 0.09732 1.27
550 277 530 50 725 0.1780 3.063 0.8509 0.7316 0.09375 1.15
Liquid 150 -123 -190 100 1450 0.1151 1.980 0.5500 0.4729 0.06060 1.36
200 -73.2 -100 100 1450 0.1191 2.048 0.5690 0.4893 0.06269 1.38
250 -23.2 -9.7 100 1450 0.1270 2.185 0.6068 0.5218 0.06686 1.38
300 26.9 80.3 100 1450 0.1387 2.386 0.6628 0.5699 0.07302 1.37
350 76.9 170 100 1450 0.1537 2.645 0.7348 0.6318 0.08095 1.37
400 127 260 100 1450 0.1729 2.975 0.8265 0.7106 0.09106 1.399
Supercritical
phase
450 177 350 100 1450 0.2009 3.457 0.9603 0.8257 0.1058 1.477
500 227 440 100 1450 0.2234 3.844 1.068 0.9182 0.1176 1.511
550 277 530 100 1450 0.2049 3.525 0.9791 0.8418 0.1079 1.308
Liquid 150 -123 -190 300 4351 0.1145 1.971 0.5474 0.4706 0.06031 1.34
200 -73.2 -100 300 4351 0.1180 2.030 0.5638 0.4847 0.06211 1.36
250 -23.2 -9.7 300 4351 0.1249 2.149 0.5970 0.5133 0.06577 1.35
300 26.9 80.3 300 4351 0.1349 2.320 0.6445 0.5542 0.07101 1.32
350 76.9 170 300 4351 0.1465 2.521 0.7003 0.6022 0.07716 1.30
400 127 260 300 4351 0.1587 2.731 0.7586 0.6523 0.08358 1.28
Supercritical
phase
450 177 350 300 4351 0.1705 2.934 0.8150 0.7008 0.08979 1.26
500 227 440 300 4351 0.1812 3.118 0.8662 0.7448 0.09543 1.24
550 277 530 300 4351 0.1904 3.276 0.9101 0.7825 0.1003 1.22
Liquid 150 -123 -190 650 9427 0.1139 1.960 0.5445 0.4681 0.05999 1.31
200 -73.2 -100 650 9427 0.1169 2.011 0.5587 0.4804 0.06155 1.32
250 -23.2 -9.7 650 9427 0.1232 2.119 0.5887 0.5062 0.06486 1.31
300 26.9 80.3 650 9427 0.1322 2.275 0.6318 0.5433 0.06961 1.28
350 76.9 170 650 9427 0.1427 2.455 0.6819 0.5863 0.07512 1.25
400 127 260 650 9427 0.1535 2.641 0.7337 0.6308 0.08083 1.22
Supercritical
phase
450 177 350 650 9427 0.1640 2.822 0.7839 0.6740 0.08637 1.20
500 227 440 650 9427 0.1739 2.992 0.8311 0.7146 0.09156 1.18
550 277 530 650 9427 0.1830 3.148 0.8746 0.7520 0.09635 1.17
Isochoric specific heat, CV, of butane at given temperatures and pressure s:
Butane - Isochoric Specific Heat, CV
State Temperature Pressure Specific heat at constant volume, CV (isochoric) Cp/Cv
(K) (°C) (°F) (bara) (psia) (kJ/mol K) (kJ/kg K) (kWh/(kg K)) (kcal(IT)/(kg K)),
(Btu(IT)/lb °F)
Liquid at
equilibrium
134.9 -138.25 -216.85 6.7E-06 9.7E-05 0.08375 1.441 0.4003 0.3442 0.04410 1.37
150 -123 -190 8.6E-05 1.2E-03 0.08381 1.442 0.4006 0.3444 0.04413 1.38
200 -73 -100 0.0194 0.281 0.08561 1.473 0.4092 0.3518 0.04508 1.40
220 -53 -64 0.0781 1.13 0.08747 1.505 0.4181 0.3595 0.04606 1.40
240 -33.2 -28 0.241 3.49 0.08997 1.548 0.4300 0.3697 0.04738 1.41
260 -13.2 8.3 0.610 8.84 0.09305 1.601 0.4447 0.3824 0.04900 1.41
280 6.9 44.3 1.33 19.3 0.09660 1.662 0.4617 0.3970 0.05086 1.41
300 26.9 80.3 2.58 37.4 0.1005 1.729 0.4803 0.4130 0.05292 1.42
320 46.9 116 4.56 66.2 0.1048 1.803 0.5008 0.4306 0.05518 1.43
340 66.9 152 7.52 109 0.1093 1.881 0.5225 0.4493 0.05757 1.45
360 86.9 188 11.7 170 0.1142 1.965 0.5458 0.4693 0.06014 1.49
380 106.9 224 17.4 252 0.1197 2.059 0.5719 0.4918 0.06302 1.56
400 126.9 260 25.0 362 0.1263 2.173 0.6036 0.5190 0.06650 1.77
420 146.9 296 34.9 506 0.1370 2.357 0.6547 0.5630 0.07214 3.76
Gas at
equilibrium
134.9 -138.25 -216.85 6.7E-06 9.7E-05 0.05599 0.9634 0.2676 0.2301 0.02948 1.15
150 -123 -190 8.6E-05 1.2E-03 0.05899 1.015 0.2819 0.2424 0.03106 1.14
200 -73 -100 0.0194 0.281 0.06824 1.174 0.3261 0.2804 0.03593 1.12
220 -53 -64 0.0781 1.13 0.07230 1.244 0.3456 0.2971 0.03807 1.12
240 -33.2 -28 0.241 3.49 0.07684 1.322 0.3672 0.3158 0.04046 1.12
260 -13.2 8.3 0.610 8.84 0.08184 1.408 0.3911 0.3363 0.04309 1.12
280 6.9 44.3 1.33 19.3 0.08724 1.501 0.4169 0.3585 0.04594 1.12
300 26.9 80.3 2.58 37.4 0.09311 1.602 0.4450 0.3826 0.04903 1.13
320 46.9 116 4.56 66.2 0.09927 1.708 0.4744 0.4079 0.05227 1.15
340 66.9 152 7.52 109 0.1058 1.820 0.5056 0.4347 0.05570 1.18
360 86.9 188 11.7 170 0.1125 1.935 0.5375 0.4622 0.05922 1.23
380 107 224 17.4 252 0.1196 2.058 0.5717 0.4915 0.06298 1.34
400 127 260 25.0 362 0.1285 2.210 0.6139 0.5278 0.06764 1.64
420 147 296 34.9 506 0.1421 2.444 0.6789 0.5837 0.07480 4.39
Liquid 150 -123 -190 1 14.5 0.08384 1.442 0.4007 0.3445 0.04415 1.38
200 -73.2 -100 1 14.5 0.08563 1.473 0.4093 0.3519 0.04509 1.40
250 -23.2 -9.7 1 14.5 0.09143 1.573 0.4370 0.3757 0.04814 1.41
272.31 -0.84 30.49 1 14.5 0.09516 1.637 0.4548 0.3910 0.05011 1.41
Gas 272.31 -0.8 30.5 1 14.5 0.08513 1.465 0.4069 0.3498 0.04483 1.12
300 26.9 80.3 1 14.5 0.09150 1.574 0.4373 0.3760 0.04818 1.10
350 76.9 170 1 14.5 0.1040 1.789 0.4970 0.4273 0.05476 1.09
400 127 260 1 14.5 0.1167 2.008 0.5577 0.4795 0.06144 1.08
450 177 350 1 14.5 0.1289 2.218 0.6162 0.5298 0.06789 1.07
500 227 440 1 14.5 0.1404 2.416 0.6711 0.5771 0.07394 1.06
550 277 530 1 14.5 0.1511 2.600 0.7222 0.6210 0.07957 1.06
Liquid
150 -123 -190 10 145 0.08389 1.443 0.4009 0.3447 0.04417 1.38
200 -73.2 -100 10 145 0.08568 1.474 0.4095 0.3521 0.04511 1.40
250 -23.2 -9.7 10 145 0.09148 1.574 0.4372 0.3759 0.04817 1.40
300 26.9 80.3 10 145 0.1005 1.730 0.4805 0.4132 0.05294 1.41
350 76.9 170 10 145 0.1117 1.922 0.5340 0.4591 0.05883 1.47
352.62 79.47 175.05 10 145 0.1124 1.933 0.5370 0.4618 0.05917 1.47
Gas 352.62 79.47 175.05 10 145 0.1100 1.892 0.5256 0.4519 0.05791 1.21
400 127 260 10 145 0.1193 2.052 0.5701 0.4902 0.06281 1.12
450 177 350 10 145 0.1304 2.243 0.6230 0.5357 0.06864 1.09
500 227 440 10 145 0.1413 2.431 0.6754 0.5807 0.07441 1.08
550 277 530 10 145 0.1517 2.610 0.7251 0.6234 0.07988 1.07
Liquid 150 -123 -190 50 725 0.08411 1.447 0.4020 0.3456 0.04429 1.37
200 -73.2 -100 50 725 0.08587 1.477 0.4104 0.3529 0.04522 1.39
250 -23.2 -9.7 50 725 0.09167 1.577 0.4381 0.3767 0.04827 1.39
300 26.9 80.3 50 725 0.1007 1.733 0.4814 0.4139 0.05303 1.39
350 76.9 170 50 725 0.1117 1.922 0.5338 0.4590 0.05882 1.41
400 127 260 50 725 0.1244 2.139 0.5943 0.5110 0.06548 1.52
Supercritical
phase
450 177 350 50 725 0.1423 2.449 0.6803 0.5849 0.07495 2.46
500 227 440 50 725 0.1461 2.514 0.6983 0.6004 0.07694 1.27
550 277 530 50 725 0.1549 2.665 0.7402 0.6365 0.08155 1.15
Liquid 150 -123 -190 100 1450 0.08437 1.452 0.4032 0.3467 0.04443 1.36
200 -73.2 -100 100 1450 0.08611 1.482 0.4115 0.3539 0.04534 1.38
250 -23.2 -9.7 100 1450 0.09192 1.581 0.4393 0.3777 0.04840 1.38
300 26.9 80.3 100 1450 0.1010 1.737 0.4825 0.4149 0.05316 1.37
350 76.9 170 100 1450 0.1118 1.924 0.5344 0.4595 0.05888 1.37
400 127 260 100 1450 0.1236 2.126 0.5906 0.5078 0.06507 1.399
Supercritical
phase
450 177 350 100 1450 0.1361 2.341 0.6503 0.5591 0.07164 1.477
500 227 440 100 1450 0.1478 2.544 0.7066 0.6075 0.07785 1.511
550 277 530 100 1450 0.1566 2.695 0.7485 0.6436 0.08247 1.308
Liquid 150 -123 -190 300 4351 0.08535 1.468 0.4079 0.3507 0.04494 1.34
200 -73.2 -100 300 4351 0.08700 1.497 0.4158 0.3575 0.04581 1.36
250 -23.2 -9.7 300 4351 0.09282 1.597 0.4436 0.3814 0.04888 1.35
300 26.9 80.3 300 4351 0.1019 1.753 0.4869 0.4186 0.05364 1.32
350 76.9 170 300 4351 0.1127 1.938 0.5384 0.4629 0.05932 1.30
400 127 260 300 4351 0.1240 2.133 0.5926 0.5095 0.06529 1.28
Supercritical
phase
450 177 350 300 4351 0.1352 2.326 0.6461 0.5555 0.07119 1.26
500 227 440 300 4351 0.1459 2.510 0.6973 0.5996 0.07682 1.24
550 277 530 300 4351 0.1559 2.683 0.7453 0.6408 0.08211 1.22
Liquid 150 -123 -190 650 9427 0.08678 1.493 0.4147 0.3566 0.04569 1.31
200 -73.2 -100 650 9427 0.08835 1.520 0.4223 0.3631 0.04652 1.32
250 -23.2 -9.7 650 9427 0.09421 1.621 0.4503 0.3872 0.04961 1.31
300 26.9 80.3 650 9427 0.1033 1.777 0.4936 0.4245 0.05439 1.28
350 76.9 170 650 9427 0.1141 1.962 0.5451 0.4687 0.06006 1.25
400 127 260 650 9427 0.1254 2.157 0.5991 0.5151 0.06601 1.22
Supercritical
phase
450 177 350 650 9427 0.1365 2.348 0.6523 0.5608 0.07186 1.20
500 227 440 650 9427 0.1471 2.531 0.7030 0.6044 0.07745 1.18
550 277 530 650 9427 0.1571 2.702 0.7506 0.6454 0.08270 1.17
Unit conversion:
Specific heat unit converter
british thermal unit(International table) = (Btu(IT)), degree celcius = (°C), degree fahrenheit = (°F), degree kelvin = (K), degree rankin = (°R), joule = (J), kilocalorie(International table) = (kcal(IT)), kilogram = (kg), kilojoule = (kJ), kilowatthour = (kWh), mole = (mol), pound =(lb)
K in the units can be replaced by °C, and vise versa. °R in the units can be replaced by °F, and vise versa.
  • 1 Btu/(lb °F) = 1 Btu/(lb °R) = 1 kcal(IT)/(kg °C) = 1 kcal(IT)/(kg K) = 4186.8 J/(kg K) = 0.81647 kcal(IT)/(lb °F) = 1.163×10-3 kWh/(kg K)
  • 1 J/(kg K) = 1 J/(kg °C) = 2.3885×10-4 kcal(IT)/(kg oC) = 2.3885×10-4 Btu/(lb °F) = 1.9501×10-4 kcal(IT)/(lb °F)
  • 1 kcal(IT)/(kg °C) = 1 Btu/(lb °F) = 4186.8 J/(kg K) = 0.81647 kcal(IT)/(lb °F) = 1.163×10-3 kWh/(kg K)
  • 1 kcal(IT)/(lb °F) = 1.2248 Btu/(lb °F) = 1.2248 kcal(IT)/(kg °C) = 5127.9 J/(kg K)
  • 1 kJ/kgK = 1 kJ/(kg °C) = 1000 J/(kg K) = 1000 J/(kg °C) = 0.23885 kcal(IT)/(kg °C) = 0.23885 Btu/(lb °F) = 0.19501 kcal(IT)/(lb °F) = 2.7778×10-4 kWh/(kg K)
  • 1 kWh/(kg K) = 0.85985 kcal(IT)/(kg °C) = 0.85985 Btu/(lb °F) = 3.6 kJ/kgK
  • 1 mol of air = 28.96546 g
Fluid Mechanics
Material Properties
Thermodynamics
Butane - Thermophysical Properties
Chemical, physical and thermal properties of n-Butane.
Carbon Dioxide - Specific Heat of Gas vs. Temperature
Specific heat of Carbon Dioxide gas - CO2 - temperatures ranging 175 - 6000 K.
Carbon Monoxide Gas - CO - Specific Heat vs. Temperature
Carbon Monoxide Gas - CO - specific heat of at temperatures ranging 175 - 6000 K.
Ethane Gas - Specific Heat vs. Temperature
Specific heat of Ethane Gas - C2H6 - for temperatures ranging 250 - 900 K.
Ethylene Gas - Specific Heat vs. Temperature
Specific heat of Ethylene Gas - C2H4 - temperatures ranging 175 - 900 K.
Heat Capacity
Hydrogen - Specific Heat
Specific heat of Hydrogen Gas - H2 - at temperatures ranging 175 - 6000 K.
Methane Gas - Specific Heat vs. Temperature
Specific heat of Methane Gas - CH4 - at temperatures ranging 200 - 1100 K.
Nitrogen Gas - Specific Heat vs. Temperature
Specific heat of Nitrogen Gas - N2 - at temperatures ranging 175 - 6000 K
Specific heat of Oxygen Gas - O2 - at temperatures ranging 175 - 6000 K.
Propane - Specific Heat vs. Temperature and Pressure
Online calculators, figures and tables with specific heat, Cp and Cv, of gasous and liquid propane, C3H8 vs. temperature and pressure - Imperial and SI Units .
Specific Heat Capacity of Air: Isobaric and Isochoric Heat Capacities at Various Temperatures and Pressures
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
Water Vapor - Specific Heat vs. Temperature
Specific heat of Water Vapor - H2O - at temperatures ranging 175 - 6000 K.
