The output dynamic viscosity is given as Pa*s, N*s/m 2 , cP, mPa*s, lb f *s/ft 2 and lb m /(ft*h),
while the kinematic viscosity is given as cSt, m 2 /s, and ft 2 /s
See also other properties of Butane at varying temperature and pressure: Density and specific weight , Specific Heat (Heat Capacity) and Thermal conductivity , and Thermophysical properties at standard conditions ,
as well as dynamic and kinematic viscosity of air , ammonia , benzene , carbon dioxide , ethane , ethanol , ethylene , methane , methanol , nitrogen , oxygen , propane and water .
Dynamic and kinematic viscosity of gaseous butane at atmospheric pressure and varying temperature:
Dynamic and kinematic viscosity of liquid butane at atmospheric pressure and varying temperature:
Dynamic viscosity of butane at varying temperature and 1, 10, 50 and 100 bara (14.5, 145, 725 and 1450 psia):
Kinematic viscosity of butane at varying temperature and 1, 10, 50 and 100 bara (14.5, 145, 725 and 1450 psia):
Dynamic viscosity of butane at gas-liquid equilibrium pressure:
Kinematic viscosity of butane at gas-liquid equilibrium pressure:
Dynamic (absolute) and kinematic viscosity of butane at given temperatures and pressures, SI and Imperial units:
State | Temperature | Pressure | Dynamic (Absolute) Viscosity | Kinematic Viscosity | ||||||||
[K] | [°C] | [°F] | [bara] | [psia] | [μPa s] | [cP] | [x10 -6 lb f s/ft 2 ] | [x10 -6 lb m /ft s] | [lb m /ft h] | [cSt], [x10 -6 m 2 /s] | [x10 -6 ft 2 /s] | |
Liquid at equilibrium | 134.9 | -138.25 | -216.85 | 6.7E-06 | 9.7E-05 | 2304 | 2.304 | 48.12 | 1548 | 5.574 | 3.13 | 33.7 |
150 | -123 | -190 | 8.6E-05 | 1.2E-03 | 1370 | 1.370 | 28.61 | 920.6 | 3.314 | 1.90 | 20.5 | |
200 | -73 | -100 | 0.0194 | 0.281 | 496.5 | 0.4965 | 10.37 | 333.6 | 1.201 | 0.737 | 7.93 | |
220 | -53 | -64 | 0.0781 | 1.13 | 373.4 | 0.3734 | 7.799 | 250.9 | 0.9033 | 0.570 | 6.14 | |
240 | -33.2 | -28 | 0.241 | 3.49 | 290.9 | 0.2909 | 6.076 | 195.5 | 0.7037 | 0.458 | 4.93 | |
260 | -13.2 | 8.3 | 0.610 | 8.84 | 232.3 | 0.2323 | 4.852 | 156.1 | 0.5620 | 0.378 | 4.07 | |
280 | 6.9 | 44.3 | 1.33 | 19.3 | 189.0 | 0.1890 | 3.947 | 127.0 | 0.4572 | 0.319 | 3.43 | |
300 | 26.9 | 80.3 | 2.58 | 37.4 | 155.6 | 0.1556 | 3.250 | 104.6 | 0.3764 | 0.273 | 2.93 | |
320 | 46.9 | 116 | 4.56 | 66.2 | 129.1 | 0.1291 | 2.696 | 86.75 | 0.3123 | 0.236 | 2.54 | |
340 | 66.9 | 152 | 7.52 | 109 | 107.2 | 0.1072 | 2.239 | 72.04 | 0.2593 | 0.206 | 2.22 | |
360 | 86.9 | 188 | 11.7 | 170 | 88.54 | 0.08854 | 1.849 | 59.50 | 0.2142 | 0.181 | 1.95 | |
380 | 106.9 | 224 | 17.4 | 252 | 71.86 | 0.07186 | 1.501 | 48.29 | 0.1738 | 0.158 | 1.70 | |
400 | 126.9 | 260 | 25.0 | 362 | 55.96 | 0.05596 | 1.169 | 37.60 | 0.1354 | 0.137 | 1.47 | |
420 | 146.9 | 296 | 34.9 | 506 | 37.39 | 0.03739 | 0.7809 | 25.12 | 0.09045 | 0.114 | 1.23 | |
425.13 | 151.98 | 305.56 | 38.0 | 551 | 23.90 | 0.02390 | 0.4992 | 16.06 | 0.05782 | 0.105 | 1.13 | |
Gas at equilibrium | 134.9 | -138.25 | -216.85 | 6.7E-06 | 9.7E-05 | 3.321 | 0.00332 | 0.06936 | 2.232 | 0.00803 | 96261 | 1036142 |
150 | -123 | -190 | 8.6E-05 | 1.2E-03 | 3.709 | 0.00371 | 0.07746 | 2.492 | 0.00897 | 9284 | 99933 | |
200 | -73 | -100 | 0.0194 | 0.281 | 4.979 | 0.00498 | 0.1040 | 3.346 | 0.01204 | 73.3 | 789 | |
220 | -53 | -64 | 0.0781 | 1.13 | 5.477 | 0.00548 | 0.1144 | 3.680 | 0.01325 | 21.9 | 236 | |
240 | -33.2 | -28 | 0.241 | 3.49 | 5.966 | 0.00597 | 0.1246 | 4.009 | 0.01443 | 8.38 | 90.2 | |
260 | -13.2 | 8.3 | 0.610 | 8.84 | 6.450 | 0.00645 | 0.1347 | 4.334 | 0.01560 | 3.82 | 41.1 | |
280 | 6.9 | 44.3 | 1.33 | 19.3 | 6.935 | 0.00694 | 0.1448 | 4.660 | 0.01678 | 1.99 | 21.4 | |
300 | 26.9 | 80.3 | 2.58 | 37.4 | 7.436 | 0.00744 | 0.1553 | 4.997 | 0.01799 | 1.14 | 12.3 | |
320 | 46.9 | 116 | 4.56 | 66.2 | 7.978 | 0.00798 | 0.1666 | 5.361 | 0.01930 | 0.707 | 7.61 | |
340 | 66.9 | 152 | 7.52 | 109 | 8.601 | 0.00860 | 0.1796 | 5.780 | 0.02081 | 0.464 | 5.00 | |
360 | 86.9 | 188 | 11.7 | 170 | 9.369 | 0.00937 | 0.1957 | 6.296 | 0.02266 | 0.319 | 3.44 | |
380 | 107 | 224 | 17.4 | 252 | 10.41 | 0.01041 | 0.2174 | 6.995 | 0.02518 | 0.227 | 2.44 | |
400 | 127 | 260 | 25.0 | 362 | 12.03 | 0.01203 | 0.2513 | 8.084 | 0.02910 | 0.165 | 1.77 | |
420 | 147 | 296 | 34.9 | 506 | 15.96 | 0.01596 | 0.3333 | 10.72 | 0.03861 | 0.118 | 1.27 | |
Liquid | 150 | -123 | -190 | 1 | 14.5 | 1371 | 1.371 | 28.63 | 921.2 | 3.316 | 1.90 | 20.5 |
200 | -73.2 | -100 | 1 | 14.5 | 496.9 | 0.4969 | 10.38 | 333.9 | 1.202 | 0.737 | 7.94 | |
250 | -23.2 | -9.7 | 1 | 14.5 | 259.4 | 0.2594 | 5.418 | 174.3 | 0.6276 | 0.415 | 4.47 | |
272.31 | -0.8 | 30.5 | 1 | 14.5 | 204.2 | 0.2042 | 4.265 | 137.2 | 0.4940 | 0.339 | 3.65 | |
Gas | 272.31 | -0.8 | 30.5 | 1 | 14.5 | 6.748 | 0.00675 | 0.1409 | 4.534 | 0.01632 | 2.521 | 27.14 |
300 | 26.9 | 80.3 | 1 | 14.5 | 7.452 | 0.00745 | 0.1556 | 5.008 | 0.01803 | 3.11 | 33.43 | |
350 | 76.9 | 170 | 1 | 14.5 | 8.691 | 0.00869 | 0.1815 | 5.840 | 0.02102 | 4.28 | 46.03 | |
400 | 127 | 260 | 1 | 14.5 | 9.899 | 0.00990 | 0.2067 | 6.652 | 0.02395 | 5.60 | 60.30 | |
450 | 177 | 350 | 1 | 14.5 | 11.08 | 0.01108 | 0.2315 | 7.447 | 0.02681 | 7.08 | 76.23 | |
500 | 227 | 440 | 1 | 14.5 | 12.25 | 0.01225 | 0.2558 | 8.230 | 0.02963 | 8.72 | 93.82 | |
550 | 277 | 530 | 1 | 14.5 | 13.40 | 0.01340 | 0.2798 | 9.001 | 0.03240 | 10.502 | 113.04 | |
Liquid | 150 | -123 | -190 | 10 | 145 | 1381 | 1.381 | 28.85 | 928.2 | 3.341 | 1.91 | 20.6 |
200 | -73.2 | -100 | 10 | 145 | 500.6 | 0.5006 | 10.45 | 336.4 | 1.211 | 0.742 | 7.99 | |
250 | -23.2 | -9.7 | 10 | 145 | 261.8 | 0.2618 | 5.468 | 175.9 | 0.6333 | 0.418 | 4.50 | |
300 | 26.9 | 80.3 | 10 | 145 | 157.3 | 0.1573 | 3.285 | 105.7 | 0.3805 | 0.275 | 2.96 | |
350 | 76.9 | 170 | 10 | 145 | 97.70 | 0.09770 | 2.040 | 65.65 | 0.2363 | 0.193 | 2.08 | |
352.62 | 79.5 | 175 | 10 | 145 | 95.14 | 0.09514 | 1.987 | 63.93 | 0.2301 | 0.190 | 2.04 | |
Gas | 352.62 | 79.5 | 175 | 10 | 145 | 9.063 | 0.00906 | 0.1893 | 6.090 | 0.02192 | 0.365 | 3.93 |
400 | 127 | 260 | 10 | 145 | 10.16 | 0.01016 | 0.2121 | 6.825 | 0.02457 | 0.511 | 5.50 | |
450 | 177 | 350 | 10 | 145 | 11.32 | 0.01132 | 0.2365 | 7.609 | 0.02739 | 0.673 | 7.24 | |
500 | 227 | 440 | 10 | 145 | 12.48 | 0.01248 | 0.2605 | 8.383 | 0.03018 | 0.846 | 9.11 | |
550 | 277 | 530 | 10 | 145 | 13.61 | 0.01361 | 0.2843 | 9.146 | 0.03293 | 1.03 | 11.11 | |
Liquid | 150 | -123 | -190 | 50 | 725 | 1428 | 1.428 | 29.83 | 959.7 | 3.455 | 1.97 | 21.3 |
200 | -73.2 | -100 | 50 | 725 | 516.9 | 0.5169 | 10.80 | 347.3 | 1.250 | 0.763 | 8.21 | |
250 | -23.2 | -9.7 | 50 | 725 | 272.3 | 0.2723 | 5.687 | 183.0 | 0.6587 | 0.432 | 4.65 | |
300 | 26.9 | 80.3 | 50 | 725 | 166.0 | 0.1660 | 3.466 | 111.5 | 0.4015 | 0.287 | 3.09 | |
350 | 76.9 | 170 | 50 | 725 | 106.8 | 0.1068 | 2.230 | 71.74 | 0.2583 | 0.206 | 2.22 | |
400 | 127 | 260 | 50 | 725 | 65.43 | 0.06543 | 1.366 | 43.96 | 0.1583 | 0.150 | 1.61 | |
Supercritical phase | 450 | 177 | 350 | 50 | 725 | 19.32 | 0.01932 | 0.4035 | 12.98 | 0.04674 | 0.107 | 1.15 |
500 | 227 | 440 | 50 | 725 | 14.78 | 0.01478 | 0.3086 | 9.928 | 0.03574 | 0.149 | 1.60 | |
550 | 277 | 530 | 50 | 725 | 14.93 | 0.01493 | 0.3118 | 10.03 | 0.03611 | 0.191 | 2.06 | |
Liquid | 150 | -123 | -190 | 100 | 1450 | 1488 | 1.488 | 31.08 | 1000 | 3.600 | 2.05 | 22.1 |
200 | -73.2 | -100 | 100 | 1450 | 537.3 | 0.5373 | 11.22 | 361.0 | 1.300 | 0.790 | 8.50 | |
250 | -23.2 | -9.7 | 100 | 1450 | 285.2 | 0.2852 | 5.956 | 191.6 | 0.6899 | 0.449 | 4.84 | |
300 | 26.9 | 80.3 | 100 | 1450 | 176.3 | 0.1763 | 3.683 | 118.5 | 0.4266 | 0.301 | 3.24 | |
350 | 76.9 | 170 | 100 | 1450 | 116.8 | 0.1168 | 2.439 | 78.48 | 0.2825 | 0.220 | 2.36 | |
400 | 127 | 260 | 100 | 1450 | 77.78 | 0.07778 | 1.625 | 52.27 | 0.1882 | 0.167 | 1.79 | |
450 | 177 | 350 | 100 | 1450 | 48.33 | 0.04833 | 1.009 | 32.47 | 0.1169 | 0.127 | 1.36 | |
Supercritical phase | 500 | 227 | 440 | 100 | 1450 | 27.08 | 0.02708 | 0.5655 | 18.19 | 0.06550 | 0.101 | 1.09 |
550 | 277 | 530 | 100 | 1450 | 19.39 | 0.01939 | 0.4049 | 13.03 | 0.04690 | 0.103 | 1.11 | |
Liquid | 150 | -123 | -190 | 300 | 4351 | 1748 | 1.748 | 36.51 | 1175 | 4.229 | 2.38 | 25.6 |
200 | -73.2 | -100 | 300 | 4351 | 619.2 | 0.6192 | 12.93 | 416.1 | 1.498 | 0.895 | 9.63 | |
250 | -23.2 | -9.7 | 300 | 4351 | 335.1 | 0.3351 | 6.998 | 225.1 | 0.8105 | 0.515 | 5.54 | |
300 | 26.9 | 80.3 | 300 | 4351 | 214.5 | 0.2145 | 4.481 | 144.2 | 0.5190 | 0.352 | 3.79 | |
350 | 76.9 | 170 | 300 | 4351 | 150.5 | 0.1505 | 3.142 | 101.1 | 0.3640 | 0.265 | 2.86 | |
400 | 127 | 260 | 300 | 4351 | 110.9 | 0.1109 | 2.316 | 74.53 | 0.2683 | 0.212 | 2.28 | |
450 | 177 | 350 | 300 | 4351 | 83.81 | 0.08381 | 1.750 | 56.32 | 0.2027 | 0.175 | 1.89 | |
Supercritical phase | 500 | 227 | 440 | 300 | 4351 | 64.10 | 0.06410 | 1.339 | 43.07 | 0.1551 | 0.148 | 1.59 |
550 | 277 | 530 | 300 | 4351 | 49.56 | 0.04956 | 1.035 | 33.30 | 0.1199 | 0.127 | 1.37 | |
Liquid | 150 | -123 | -190 | 650 | 9427 | 2300 | 2.300 | 48.04 | 1546 | 5.565 | 3.08 | 33.2 |
200 | -73.2 | -100 | 650 | 9427 | 766.5 | 0.7665 | 16.01 | 515.0 | 1.854 | 1.08 | 11.6 | |
250 | -23.2 | -9.7 | 650 | 9427 | 419.1 | 0.4191 | 8.754 | 281.6 | 1.014 | 0.623 | 6.71 | |
300 | 26.9 | 80.3 | 650 | 9427 | 275.1 | 0.2751 | 5.746 | 184.9 | 0.6656 | 0.431 | 4.64 | |
350 | 76.9 | 170 | 650 | 9427 | 199.8 | 0.1998 | 4.172 | 134.2 | 0.4833 | 0.331 | 3.56 | |
400 | 127 | 260 | 650 | 9427 | 154.3 | 0.1543 | 3.222 | 103.7 | 0.3731 | 0.270 | 2.90 | |
450 | 177 | 350 | 650 | 9427 | 123.8 | 0.1238 | 2.585 | 83.17 | 0.2994 | 0.229 | 2.47 | |
Supercritical phase | 500 | 227 | 440 | 650 | 9427 | 101.8 | 0.1018 | 2.126 | 68.39 | 0.2462 | 0.200 | 2.15 |
550 | 277 | 530 | 650 | 9427 | 85.08 | 0.08508 | 1.777 | 57.17 | 0.2058 | 0.177 | 1.90 |
Viscosity Dynamic, Absolute
centipoise [cP], gram/(centimeter second) [g/(cm s)] = poise [P], kilogram/meter second [kg/m s]=newton second/square meter [N s/m 2 ]= pascal second [Pa s], pound/(foot hour) [lb/(ft h)], pound/(foot second) [lb/(ft s)], reyn [reyn]
Viscosity Kinematic
centistoke [cSt] = square millimeter/second [mm 2 /s], square foot/hour [ft 2 /h], square foot/second [ft 2 /s], square inch/second [in 2 /s], square meter/hour [m 2 /h], square meter/second [m 2 /s], stoke [St] = square centimeter/second [cm 2 /s]
Chemical, physical and thermal properties of n-Butane.
Online calculator, figures and table showing dynamic and kinematic viscosity of carbon dioxide, CO2, at varying temperature and pressure - Imperial and SI Units.
Online calculator, figures and tables showing dynamic and kinematic viscosity of ethane, C2H6, at varying temperature and pressure - Imperial and SI Units
Combustion values for fuel gases like natural gas, propane and butane - Btu per cubic feet.
Adiabatic flame temperatures for common fuel gases - propane, butane, acetylene and more - in air or oxygen atmospheres.
Gross heat and net heat values for gases like hydrogen, methane and more.
Vapor pressure vs. temperature for propane, n-butane, n-heptane and n-pentane hydrocarbons.
Online calculator, figures and tables showing dynamic and kinematic viscosity of nitrogen, N2, at varying temperature and pressure - Imperial and SI Units.
