Thermodynamics
1st Law of Thermodynamics
2nd Law of Thermodynamics
Entropy and disorder.
Absorbed Solar Radiation
Solar radiation absorbed by various materials.
Properties of alternative fuels like biodiesel, E85, CNG and more.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Bimetallic Strips
Heat and bending of bimetallic strips.
Carbon Dioxide - Dynamic and Kinematic Viscosity vs. Temperature and Pressure
Online calculator, figures and table showing dynamic and kinematic viscosity of carbon dioxide, CO2, at varying temperature and pressure - Imperial and SI Units.
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Carbon Dioxide - Thermophysical Properties
Carbon Monoxide - Density and Specific Weight vs. Temperature and Pressure
Online calculator, figures and tables showing density and specific weight of carbon monoxide, CO, at varying temperature and pressure - Imperial and SI Units.
Carnot Efficiency
Combustion Heat
Conductive Heat Transfer
Convective Heat Transfer
Cooling Mode - Heat Flux
Heat fluxes for various cooling or heat transfer modes.
Critical Points for some Substances
Critical points of some common substances like air, argon, helium and more
Dowtherm A
Physical properties of Dowtherm A.
Efficiency
Efficiency is the ratio useful energy output to energy input.
Energy
Energy is the capacity to do work.
Energy Accumulated in Heated Water - kWh
Energy Conversion Factors
Convert between energy units
Energy Storage Density
Energy density - by weight and volume - for some ways to store energy
Energy Transfer Equation
Fluid energy transfer.
Ethane - Dynamic and Kinematic Viscosity
Online calculator, figures and tables showing dynamic and kinematic viscosity of ethane, C2H6, at varying temperature and pressure - Imperial and SI Units
Ethanol - Thermophysical properties
Chemical, physical and thermal properties of ethanol (also called alcohol or ethyl alcohol). Phase diagram included.
Fluid Heat Transfer Coefficients in Heat Exchanger Surface Combinations
Food and Foodstuff - Specific Heat
Specific heat of common food and foodstuff like apples, bass, beef, pork and many more.
Freezing Mixtures and Cooling Agents
Freezing mixtures, cooling agents and freezing points.
Gases - Specific Heats and Individual Gas Constants
Heat Capacity
Typical heat exchanger materials and their thermal conductivities.
Heat Exchangers - Fouling and Reduced Heat Transfer
Heat-transfer in heat exchangers are reduced by fouling.
Heat Exchangers - Heat Transfer Coefficients
Overall heat transfer coefficients in common heat exchanger designs - tubular, plate or spiral.
Heat, Work and Energy
Heat vs. work vs. energy.
Heating Up Applications - Energy Required and Heat Transfer Rates
Energy required to heat up a substance.
High and Low Heat Values
The gross (high) and net (low) heating values.
Hydrogen sulfide - Thermophysical Properties
Chemical, physical and thermal properties of hydrogen sulfide, H2S, also called hydrosulfuric acid, sewer gas and stink damp. Phase diagram included.
Latent Heat of Melting for some common Materials
Linear Thermal Expansion
Liquids - Freezing and Melting Points
Common fluids and their freezing and melting points.
Liquids - Volumetric Expansion Coefficients
Volumetric - or cubical - expansion coefficients for common liquids.
Liquids and Fluids - Specific Heats
Metals - Specific Heats
Online calculator, figures and table showing thermal conductivity of methane, CH4, at temperatures ranging from -160 to 725 °C (-260 to 1300 °F) at atmospheric and higher pressure - Imperial and SI Units.
Methane - Thermophysical Properties
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Methanol - Specific Heat vs. Temperature and Pressure
Online calculator, figures and tables showing isobaric and isochoric specific heat of methanol, CH3OH, at varying temperature - Imperial and SI Units.
Methanol - Thermophysical Properties
Chemical, physical and thermal properties of methanol, CH3OH (also called carbinol, wood alcohol, hydroxy methyl and methyl alcohol). Phase diagram included.
Microwave Heating
Heating with microwaves.
Mixing Liquids and/or Solids - Final Temperatures
Calculate the final temperature when liquids or solids are mixed
Mollier Chart for Water - Imperial Units
Mollier chart for water in English Units
Mollier Chart for Water - Metric Units
Mollier chart for water in Metric Units
Nitrogen - Enthalpy, Internal Energy and Entropy vs. Temperature
Enthalpy, internal energy and entropy of Nitrogen as an ideal gas.
Nitrogen - Density and Specific Weight vs. Temperature and Pressure
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Nitrogen - Dynamic and Kinematic Viscosity vs. Temperature and Pressure
Online calculator, figures and tables showing dynamic and kinematic viscosity of nitrogen, N2, at varying temperature and pressure - Imperial and SI Units.
Online calculator, figures and tables showing thermal conductivity of nitrogen, N2, at varying temperarure and pressure, SI and Imperial units.
Nitrogen - Thermal Diffusivity vs. Temperature and Pressure
Figures and tables showing thermal diffusivity of nitrogen at varying temperarure and pressure, SI and Imperial units.
Overall Heat Transfer Coefficients
Power Plants - Performance Efficiencies
Power plants heat rates, thermal efficiencies, capacity factors, load factors, economic efficiencies, operational efficiencies and energy efficiencies.
Propane - Specific Heat vs. Temperature and Pressure
Online calculators, figures and tables with specific heat, Cp and Cv, of gasous and liquid propane, C3H8 vs. temperature and pressure - Imperial and SI Units .
Propane - Thermal Diffusivity vs. Temperature and Pressure
Property vs. State
The concept of properties and state.
Radiation - Surfaces Emissivity Coefficients
Radiation emissivity of common materials like water, ice, snow, grass and more.
Radiation Heat Transfer
Rankine Efficiency
The efficiency of the Rankine cycle.
Salt Hydrates - Melting points and Latent Energy
Melting points and latent energy of salt hydrates.
Solids - Specific Heats
Solids - Volume Temperature Expansion Coefficients
Cubical expansion coefficients for solids.
Thermal conductivity coefficients for insulation materials, aluminum, asphalt, brass, copper, steel, gases and more.
Specific Heat of common Substances
Standard State and Enthalpy of Formation, Gibbs Free Energy of Formation, Entropy and Heat Capacity
Definition and explanation of the terms standard state and standard enthalpy of formation, with listing of values for standard enthalpy and Gibbs free energy of formation, as well as standard entropy and molar heat capacity, of 370 inorganic compounds.
Standardized Enthalpies and Entropies
Standardized enthalpies and entropies for some common substances.
Storing Thermal Heat in Materials
Energy stored as sensible heat in materials.
Surface Emissivity Coefficients
Surface Radiation Absorptivity
Radiation surface absorptivity.
Symbols Used to Denote a Chemical Reactions and Process or Condition
Explanation of symbols used as subscripts or superscripts to tell more about the type of chemical reaction, process or condition.
Temperature
Thermal Conductivity - Unit Converting Table
Thermal Expansion - Linear Expansion Coefficients
Linear temperature expansion coefficients for common materials like aluminum, copper, glass, iron and many more.
Thermal Expansion - Superficial i.e. Area
Superficial i.e area temperature expansion - online calculator.
Thermal Transmittance vs. Thermal Resistance
The thermal transmittance U vs. the thermal resistance R.
Thermodynamic Key Values Internationally Agreed
Internationally agreed, internally consistent, values for the thermodynamic properties (standard enthalpy of formation, entropy and [H°(298)-H°(0)]) of key chemical substances.
Thermodynamic Terms - Functions and Relations
Third Law of Thermodynamics
The entropy of a substance is zero if the absolute temperature is zero.
Toluene - Thermophysical Properties
Chemical, physical and thermal properties of toluene, also called methylbenzene, toluol and phenylmethane. Phase diagram included.
Units of Heat - BTU, Calorie and Joule
The most common units of heat BTU - British Thermal Unit, Calorie and Joule.
WABT - Weighted Average Bed Temperature
Definition and examples of calculation of weighted average bed temperature in adiabatic reactors.
Water - Heat of Vaporization vs. Temperature
Ionization constant (= dissociation constant = self-ionization constant = ion product = autoprotolysis constant ) of water and heavy water, given as function of temperature (°C and °F) in figures and tables.
Water - Prandtl Number vs. Temperature and Pressure
Figures and tables with Prandtl Number of liquid and gaseous water at varying temperarure and pressure, SI and Imperial units.
Water - Specific Heat vs. Temperature
Water Boiling Points at Higher Pressures
Water-Steam Mollier Diagram
Work done by Force
Work done by a force acting on an object.
Zeroth Law of Temperature
The direction of heat flow.
