ρ = m / V (1)
γ = m g / V
= ρ g (2)
Tabulated values of toluene density and specific weight at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Online Toluene Density Calculator
The calculator below can be used to estimate the density and specific weight of liquid toluene at given temperature (maximum 307°C or 580 °F) and maximum 36 bara (500 psia).
Note! Toluene boiling point at atmospheric pressure is 110.6 °C (231.1°F), and hence, t oluene must be pressurized to remain liquid at higher temperatures than that.
See also toluene : Thermophysical properties at standard conditions, as well as density and specific weight of acetone, air, ammonia, argon, benzene, butane, carbon dioxide, carbon monoxide, ethane, ethanol, ethylene, helium, hydrogen, methane, methanol, nitrogen, oxygen, pentane, propane and water.
Density of t oluene along the boiling and condensation curve, SI and Imperial units:
The density of liquid toluene is nearly the same for all pressures up to 100 bara and 100 °C (212 °F), and the density of the liquid at equilibrium pressure can be used for most practical purposes.
Density of toluene at varying temperature and given pressures, SI and Imperial units:
Density and specific weight of toluene at given temperatures and pressures:
State | Temperature | Pressure | Density | Specific weight | |||||||
(K) | (°C) | (°F) | (bara) | (psia) | (mol/dm3) | (g/l), (kg/m3) | (lb/ft3) | (sl/ft3) | (N/m3) | (lbf/ft3) | |
Liquid at equilibrium | 178.00 | -95.15 | -139.27 | 3.94E-07 | 5.71E-06 | 10.58 | 974.8 | 60.86 | 1.891 | 9560 | 60.86 |
180 | -93.2 | -136 | 5.53E-07 | 8.03E-06 | 10.56 | 972.9 | 60.74 | 1.888 | 9541 | 60.74 | |
200 | -73.2 | -99.7 | 1.08E-05 | 1.57E-04 | 10.35 | 953.5 | 59.53 | 1.850 | 9351 | 59.53 | |
220 | -53.2 | -63.7 | 1.15E-04 | 0.00166 | 10.14 | 934.7 | 58.35 | 1.814 | 9166 | 58.35 | |
240 | -33.2 | -27.7 | 7.75E-04 | 0.0112 | 9.942 | 916.0 | 57.18 | 1.777 | 8983 | 57.18 | |
260 | -13.2 | 8.3 | 0.004 | 0.0541 | 9.741 | 897.5 | 56.03 | 1.741 | 8801 | 56.03 | |
280 | 6.9 | 44.3 | 0.014 | 0.201 | 9.540 | 879.0 | 54.88 | 1.706 | 8620 | 54.88 | |
300 | 26.9 | 80.3 | 0.042 | 0.606 | 9.339 | 860.4 | 53.72 | 1.670 | 8438 | 53.72 | |
320 | 46.9 | 116 | 0.107 | 1.56 | 9.135 | 841.7 | 52.54 | 1.633 | 8254 | 52.54 | |
340 | 66.9 | 152 | 0.242 | 3.51 | 8.928 | 822.6 | 51.35 | 1.596 | 8067 | 51.35 | |
360 | 86.9 | 188 | 0.490 | 7.10 | 8.716 | 803.1 | 50.13 | 1.558 | 7875 | 50.13 | |
380 | 107 | 224 | 0.910 | 13.2 | 8.498 | 783.0 | 48.88 | 1.519 | 7678 | 48.88 | |
383 | 110 | 230 | 1.00 | 14.5 | 8.461 | 779.6 | 48.67 | 1.513 | 7645 | 48.67 | |
400 | 127 | 260 | 1.57 | 22.8 | 8.272 | 762.2 | 47.58 | 1.479 | 7475 | 47.58 | |
420 | 147 | 296 | 2.56 | 37.2 | 8.037 | 740.5 | 46.23 | 1.437 | 7262 | 46.23 | |
440 | 167 | 332 | 3.97 | 57.6 | 7.789 | 717.6 | 44.80 | 1.392 | 7038 | 44.80 | |
460 | 187 | 368 | 5.90 | 85.5 | 7.525 | 693.3 | 43.28 | 1.345 | 6799 | 43.28 | |
480 | 207 | 404 | 8.46 | 123 | 7.239 | 667.0 | 41.64 | 1.294 | 6541 | 41.64 | |
500 | 227 | 440 | 11.8 | 171 | 6.926 | 638.1 | 39.84 | 1.238 | 6258 | 39.84 | |
520 | 247 | 476 | 16.0 | 232 | 6.572 | 605.5 | 37.80 | 1.175 | 5938 | 37.80 | |
540 | 267 | 512 | 21.2 | 308 | 6.156 | 567.2 | 35.41 | 1.101 | 5563 | 35.41 | |
560 | 287 | 548 | 27.7 | 402 | 5.633 | 519.1 | 32.40 | 1.007 | 5090 | 32.40 | |
580 | 307 | 584 | 35.7 | 518 | 4.851 | 447.0 | 27.90 | 0.8673 | 4383 | 27.90 | |
591.75 | 318.60 | 605.48 | 41.3 | 598 | 3.169 | 292.0 | 18.23 | 0.5665 | 2863 | 18.23 | |
Gas at equilibrium | 178.00 | -95.15 | -139.27 | 3.94E-07 | 5.71E-06 | 2.66E-08 | 2.45E-06 | 1.53E-07 | 4.76E-09 | 2.41E-05 | 1.53E-07 |
180.00 | -93.2 | -136 | 5.53E-07 | 8.03E-06 | 3.70E-08 | 3.41E-06 | 2.13E-07 | 6.61E-09 | 3.34E-05 | 2.13E-07 | |
200.00 | -73.2 | -99.7 | 1.08E-05 | 1.57E-04 | 6.51E-07 | 6.00E-05 | 3.75E-06 | 1.16E-07 | 5.89E-04 | 3.75E-06 | |
220.00 | -53.2 | -63.7 | 1.15E-04 | 0.00166 | 6.26E-06 | 5.77E-04 | 3.60E-05 | 1.12E-06 | 0.00566 | 3.60E-05 | |
240.00 | -33.2 | -27.7 | 7.75E-04 | 0.0112 | 3.89E-05 | 0.00358 | 2.24E-04 | 6.95E-06 | 0.03512 | 2.24E-04 | |
260.00 | -13.2 | 8.3 | 0.004 | 0.0541 | 1.73E-04 | 0.01591 | 9.93E-04 | 3.09E-05 | 0.1560 | 0.00099 | |
280.00 | 6.9 | 44.3 | 0.014 | 0.201 | 5.95E-04 | 0.05482 | 0.00342 | 1.06E-04 | 0.5376 | 0.00342 | |
300.00 | 26.9 | 80.3 | 0.042 | 0.606 | 0.00168 | 0.1549 | 0.00967 | 3.01E-04 | 1.519 | 0.00967 | |
320.00 | 46.9 | 116 | 0.107 | 1.56 | 0.00406 | 0.3745 | 0.02338 | 7.27E-04 | 3.672 | 0.02338 | |
340.00 | 66.9 | 152 | 0.242 | 3.51 | 0.00868 | 0.7995 | 0.04991 | 0.00155 | 7.840 | 0.04991 | |
360.00 | 86.9 | 188 | 0.490 | 7.10 | 0.01677 | 1.545 | 0.09646 | 0.00300 | 15.15 | 0.09646 | |
380.00 | 107 | 224 | 0.910 | 13.2 | 0.0299 | 2.757 | 0.1721 | 0.00535 | 27.04 | 0.1721 | |
400.00 | 127 | 260 | 1.57 | 22.8 | 0.0501 | 4.612 | 0.2879 | 0.00895 | 45.23 | 0.2879 | |
420.00 | 147 | 296 | 2.56 | 37.2 | 0.0795 | 7.327 | 0.4574 | 0.01422 | 71.86 | 0.4574 | |
440.00 | 167 | 332 | 3.97 | 57.6 | 0.1212 | 11.17 | 0.6973 | 0.02167 | 109.5 | 0.6973 | |
460.00 | 187 | 368 | 5.90 | 85.5 | 0.1789 | 16.48 | 1.029 | 0.03198 | 161.6 | 1.029 | |
480.00 | 207 | 404 | 8.46 | 123 | 0.2577 | 23.74 | 1.482 | 0.04607 | 232.8 | 1.482 | |
489.95 | 217 | 422 | 10.0 | 145 | 0.30691 | 28.28 | 1.765 | 0.05487 | 277.3 | 1.765 | |
500.00 | 227 | 440 | 11.8 | 171 | 0.3652 | 33.64 | 2.100 | 0.06528 | 329.9 | 2.100 | |
520.00 | 247 | 476 | 16.0 | 232 | 0.5137 | 47.33 | 2.955 | 0.09183 | 464.1 | 2.955 | |
540.00 | 267 | 512 | 21.2 | 308 | 0.7259 | 66.88 | 4.175 | 0.1298 | 655.9 | 4.175 | |
560.00 | 287 | 548 | 27.7 | 402 | 1.052 | 96.97 | 6.053 | 0.1881 | 950.9 | 6.053 | |
580.00 | 307 | 584 | 35.7 | 518 | 1.661 | 153.0 | 9.551 | 0.2969 | 1500 | 9.551 | |
Liquid | 200 | -73.2 | -99.7 | 1 | 14.5 | 10.35 | 953.6 | 59.53 | 1.850 | 9352 | 59.53 |
325 | 51.9 | 125 | 1 | 14.5 | 9.084 | 837.0 | 52.25 | 1.624 | 8208 | 52.25 | |
383.28 | 110.13 | 230.23 | 1 | 14.5 | 8.461 | 779.6 | 48.67 | 1.513 | 7645 | 48.67 | |
Gas | 383.28 | 110.13 | 230.23 | 1 | 14.5 | 0.03269 | 3.012 | 0.1880 | 0.00584 | 29.54 | 0.1880 |
450 | 177 | 350 | 1 | 14.5 | 0.02734 | 2.519 | 0.1573 | 0.00489 | 24.71 | 0.1573 | |
575 | 302 | 575 | 1 | 14.5 | 0.02111 | 1.945 | 0.1214 | 0.00377 | 19.08 | 0.1214 | |
700 | 427 | 800 | 1 | 14.5 | 0.01727 | 1.591 | 0.09934 | 0.00309 | 15.60 | 0.09934 | |
Liquid | 200 | -73.2 | -99.7 | 10 | 145 | 10.35 | 954.0 | 59.56 | 1.851 | 9356 | 59.56 |
325 | 51.9 | 125 | 10 | 145 | 9.093 | 837.8 | 52.30 | 1.626 | 8216 | 52.30 | |
450 | 177 | 350 | 10 | 145 | 7.673 | 707.0 | 44.14 | 1.372 | 6933 | 44.14 | |
489.95 | 216.80 | 422.24 | 10 | 145 | 7.088 | 653.0 | 40.77 | 1.267 | 6404 | 40.77 | |
489.95 | 216.80 | 422.24 | 10 | 145 | 0.3069 | 28.28 | 1.765 | 0.05487 | 277.3 | 1.765 | |
575 | 302 | 575 | 10 | 145 | 0.2337 | 21.53 | 1.344 | 0.04178 | 211.2 | 1.344 | |
700 | 427 | 800 | 10 | 145 | 0.1812 | 16.69 | 1.042 | 0.03239 | 163.7 | 1.042 | |
Liquid | 200 | -73.2 | -99.7 | 50 | 725 | 10.37 | 955.8 | 59.67 | 1.854 | 9373 | 59.67 |
325 | 51.9 | 125 | 50 | 725 | 9.133 | 841.5 | 52.53 | 1.633 | 8252 | 52.53 | |
450 | 177 | 350 | 50 | 725 | 7.777 | 716.5 | 44.73 | 1.390 | 7027 | 44.73 | |
575 | 302 | 575 | 50 | 725 | 5.605 | 516.4 | 32.24 | 1.002 | 5065 | 32.24 | |
Supercritical phase |
700 | 427 | 800 | 50 | 725 | 1.170 | 107.8 | 6.729 | 0.2091 | 1057 | 6.729 |
Liquid | 200 | -73.2 | -99.7 | 100 | 1450 | 10.40 | 958.0 | 59.80 | 1.859 | 9394 | 59.80 |
325 | 51.9 | 125 | 100 | 1450 | 9.180 | 845.8 | 52.80 | 1.641 | 8295 | 52.80 | |
450 | 177 | 350 | 100 | 1450 | 7.889 | 726.9 | 45.38 | 1.410 | 7128 | 45.38 | |
575 | 302 | 575 | 100 | 1450 | 6.186 | 569.9 | 35.58 | 1.106 | 5589 | 35.58 | |
700 | 427 | 800 | 100 | 1450 | 3.270 | 301.3 | 18.81 | 0.5846 | 2954 | 18.81 |
• Densities
• Thermodynamics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Carbon Monoxide - Density and Specific Weight vs. Temperature and Pressure
Online calculator, figures and tables showing density and specific weight of carbon monoxide, CO, at varying temperature and pressure - Imperial and SI Units.
Density Converter
Epoxy - Chemical Resistance
Chemical resistance of Epoxy to common products like Acetic acid, Alcohol, Diesel oil and more.
Liquids - Dielectric Constants
Dielectric constants or permittivities of some fluids or liquids.
Mass vs. Weight
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Polyester - Chemical Resistance
Chemical resistance of Polyester to products like Acetic acid, Diesel oil and others.
Polyurethane - Chemical Resistance
Chemical resistance of Polyurethane (PUR).
PP Polypropylene - Chemical Resistance
Chemical resistance of Polypropylene - PP - to acids, bases, organic substances and solvents.
Toluene - Thermophysical Properties
Chemical, physical and thermal properties of toluene, also called methylbenzene, toluol and phenylmethane. Phase diagram included.
Toluene Liquid - Thermal Properties vs. Temperature
Density, specific heat, thermal conductivity and more.
