ρ = m / V (1)
γ = (m g) / V
= ρ g (2)
Tabulated values of benzene density and specific weight at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Online Benzene Density Calculator
The calculator below can be used to estimate the density and specific weight of liquid benzene at given temperature (maximum 250°C or 620 °F) and maximum 28 bara (400 psia).
Note! Benzene boiling point at atmospheric pressure is 80 °C (176°F), and hence, benzene must be pressurized to remain liquid at higher temperatures than that.
Other properties of Benzene at varying temperature and pressure: : Dynamic and kinematic viscosity, and Thermophysical properties at standard conditions,
as well as density and specific weight o f acetone, air, ammonia, argon, butane, carbon dioxide, carbon monoxide, ethane, ethanol, ethylene, helium, hydrogen, methane, methanol, nitrogen, oxygen, pentane, propane, toluene and water . Density of crude oil , Density of fuel oils , Density of lubricating oil and Density of jet fuel as function of temperature.
Density of benzene along the boiling and condensation curve, SI and Imperial units:
The density of liquid benzene is nearly the same for all pressures up to 100 bara, and the density of the liquid at equilibrium pressure can be used for most practical purposes.
Density of benzene vapor (singel phase) at varying temperature and given pressures, SI and Imperial units:
Density and specific weight of benzene at given temperatures and pressures:
State | Temperature | Pressure | Density | Specific weight | ||||||||
(K) | (°C) | (°F) | (MPa) | (bara) | (psia) | (mol/dm3) | (g/l), (kg/m3) | (lb/ft3) | (sl/ft3) | (N/m3) | (lbf/ft3) | |
Liquid at equilibrium |
278.70 | 5.55 | 41.99 | 0.0048 | 0.0480 | 0.696 | 11.44 | 893.7 | 55.79 | 1.734 | 8764 | 55.8 |
280 | 6.9 | 44.3 | 0.0051 | 0.0515 | 0.747 | 11.42 | 892.4 | 55.71 | 1.731 | 8751 | 55.7 | |
295 | 21.9 | 71.3 | 0.0110 | 0.110 | 1.59 | 11.23 | 877.0 | 54.75 | 1.702 | 8600 | 54.7 | |
310 | 36.9 | 98.3 | 0.0214 | 0.214 | 3.10 | 11.02 | 861.1 | 53.76 | 1.671 | 8445 | 53.8 | |
325 | 51.9 | 125 | 0.0388 | 0.388 | 5.62 | 10.82 | 844.9 | 52.74 | 1.639 | 8285 | 52.7 | |
340 | 66.9 | 152 | 0.0661 | 0.661 | 9.59 | 10.61 | 828.4 | 51.71 | 1.607 | 8124 | 51.7 | |
370 | 96.9 | 206 | 0.165 | 1.6531 | 24.0 | 10.17 | 794.4 | 49.59 | 1.541 | 7790 | 49.6 | |
400 | 127 | 260 | 0.353 | 3.528 | 51.2 | 9.712 | 758.6 | 47.36 | 1.472 | 7440 | 47.4 | |
430 | 157 | 314 | 0.669 | 6.687 | 97.0 | 9.220 | 720.2 | 44.96 | 1.397 | 7063 | 45.0 | |
460 | 187 | 368 | 1.158 | 11.58 | 168 | 8.675 | 677.6 | 42.30 | 1.315 | 6645 | 42.3 | |
490 | 217 | 422 | 1.869 | 18.69 | 271 | 8.041 | 628.1 | 39.21 | 1.219 | 6159 | 39.2 | |
520 | 247 | 476 | 2.861 | 28.61 | 415 | 7.242 | 565.7 | 35.31 | 1.098 | 5547 | 35.3 | |
550 | 277 | 530 | 4.21 | 42.1 | 611 | 5.977 | 466.9 | 29.15 | 0.9059 | 4579 | 29.1 | |
562.05 | 288.9 | 552.0 | 4.90 | 49.0 | 711 | 3.956 | 309.0 | 19.29 | 0.5996 | 3030 | 19.3 | |
Gas at equilibrium |
278.7 | 5.55 | 41.99 | 0.0048 | 0.0480 | 0.696 | 0.00208 | 0.1623 | 0.01013 | 3.15E-04 | 1.59 | 0.0101 |
280 | 6.9 | 44.3 | 0.0051 | 0.0515 | 0.747 | 0.00222 | 0.1733 | 0.01082 | 3.36E-04 | 1.70 | 0.0108 | |
310 | 36.9 | 98.3 | 0.0214 | 0.214 | 3.10 | 0.00838 | 0.6546 | 0.04086 | 0.00127 | 6.42 | 0.0409 | |
340 | 66.9 | 152 | 0.0661 | 0.661 | 9.59 | 0.02397 | 1.872 | 0.1169 | 0.00363 | 18.4 | 0.117 | |
370 | 96.9 | 206 | 0.165 | 1.6531 | 24.0 | 0.05636 | 4.402 | 0.2748 | 0.00854 | 43.2 | 0.275 | |
400 | 127 | 260 | 0.353 | 3.528 | 51.2 | 0.1153 | 9.003 | 0.5621 | 0.01747 | 88.3 | 0.562 | |
430 | 157 | 314 | 0.669 | 6.687 | 97.0 | 0.2136 | 16.69 | 1.042 | 0.03238 | 164 | 1.04 | |
460 | 187 | 368 | 1.158 | 11.58 | 168 | 0.3706 | 28.95 | 1.807 | 0.05617 | 284 | 1.81 | |
490 | 217 | 422 | 1.869 | 18.69 | 271 | 0.6193 | 48.38 | 3.020 | 0.09386 | 474 | 3.02 | |
520 | 247 | 476 | 2.861 | 28.61 | 415 | 1.035 | 80.84 | 5.047 | 0.1569 | 793 | 5.05 | |
550 | 277 | 530 | 4.21 | 42.1 | 611 | 1.924 | 150.3 | 9.383 | 0.2916 | 1474 | 9.38 | |
Liquid | 300 | 26.9 | 80.3 | 0.1 | 1 | 14.5 | 11.161 | 871.8 | 54.43 | 1.692 | 8550 | 54.4 |
350 | 76.9 | 170 | 0.1 | 1 | 14.5 | 10.462 | 817.2 | 51.02 | 1.586 | 8014 | 51.0 | |
352.81 | 79.7 | 175.4 | 0.1 | 1 | 14.5 | 10.421 | 814.0 | 50.82 | 1.579 | 7983 | 50.8 | |
Gas | 352.81 | 79.7 | 175.4 | 0.1 | 1 | 14.5 | 0.03523 | 2.752 | 0.1718 | 0.005340 | 27.0 | 0.172 |
400 | 127 | 260 | 0.1 | 1 | 14.5 | 0.03071 | 2.399 | 0.1498 | 0.004655 | 23.5 | 0.150 | |
450 | 177 | 350 | 0.1 | 1 | 14.5 | 0.02711 | 2.118 | 0.1322 | 0.004109 | 20.8 | 0.132 | |
500 | 227 | 440 | 0.1 | 1 | 14.5 | 0.02430 | 1.898 | 0.1185 | 0.003683 | 18.6 | 0.118 | |
550 | 277 | 530 | 0.1 | 1 | 14.5 | 0.02203 | 1.721 | 0.1074 | 0.003339 | 16.9 | 0.107 | |
600 | 327 | 620 | 0.1 | 1 | 14.5 | 0.02016 | 1.575 | 0.0983 | 0.003056 | 15.4 | 0.0983 | |
Liquid | 300 | 26.9 | 80.3 | 1 | 10 | 145 | 11.17 | 872.5 | 54.47 | 1.693 | 8556 | 54.5 |
350 | 76.9 | 170 | 1 | 10 | 145 | 10.48 | 818.3 | 51.08 | 1.588 | 8025 | 51.1 | |
400 | 127 | 260 | 1 | 10 | 145 | 9.728 | 759.9 | 47.44 | 1.474 | 7452 | 47.4 | |
450 | 177 | 350 | 1 | 10 | 145 | 8.866 | 692.5 | 43.23 | 1.344 | 6791 | 43.2 | |
451.58 | 178.4 | 353.2 | 1 | 10 | 145 | 8.835 | 690.1 | 43.08 | 1.339 | 6768 | 43.1 | |
Gas | 451.58 | 178.4 | 353.2 | 1 | 10 | 145 | 0.3191 | 24.9 | 1.556 | 0.04836 | 244 | 1.56 |
500 | 227 | 440 | 1 | 10 | 145 | 0.2703 | 21.1 | 1.318 | 0.04096 | 207 | 1.32 | |
550 | 277 | 530 | 1 | 10 | 145 | 0.2373 | 18.5 | 1.157 | 0.03596 | 182 | 1.16 | |
600 | 327 | 620 | 1 | 10 | 145 | 0.2130 | 16.6 | 1.039 | 0.03228 | 163 | 1.04 | |
Liquid | 300 | 26.9 | 80.3 | 5 | 50 | 725 | 11.21 | 875.9 | 54.68 | 1.699 | 8589 | 54.7 |
350 | 76.9 | 170 | 5 | 50 | 725 | 10.54 | 823.1 | 51.38 | 1.597 | 8072 | 51.4 | |
400 | 127 | 260 | 5 | 50 | 725 | 9.821 | 767.1 | 47.89 | 1.488 | 7523 | 47.9 | |
450 | 177 | 350 | 5 | 50 | 725 | 9.024 | 704.9 | 44.00 | 1.368 | 6913 | 44.0 | |
500 | 227 | 440 | 5 | 50 | 725 | 8.042 | 628.2 | 39.21 | 1.219 | 6160 | 39.2 | |
550 | 277 | 530 | 5 | 50 | 725 | 6.408 | 500.5 | 31.25 | 0.9711 | 4908 | 31.2 | |
Supercritical phase |
600 | 327 | 620 | 5 | 50 | 725 | 1.554 | 121.4 | 7.578 | 0.2355 | 1190 | 7.58 |
Liquid | 300 | 26.9 | 80.3 | 10 | 100 | 1450 | 11.26 | 879.8 | 54.92 | 1.707 | 8628 | 54.9 |
350 | 76.9 | 170 | 10 | 100 | 1450 | 10.61 | 828.6 | 51.73 | 1.608 | 8126 | 51.7 | |
400 | 127 | 260 | 10 | 100 | 1450 | 9.926 | 775.3 | 48.40 | 1.504 | 7603 | 48.4 | |
450 | 177 | 350 | 10 | 100 | 1450 | 9.189 | 717.7 | 44.81 | 1.393 | 7039 | 44.8 | |
500 | 227 | 440 | 10 | 100 | 1450 | 8.342 | 651.6 | 40.68 | 1.264 | 6390 | 40.7 | |
550 | 277 | 530 | 10 | 100 | 1450 | 7.276 | 568.4 | 35.48 | 1.103 | 5574 | 35.5 | |
600 | 327 | 620 | 10 | 100 | 1450 | 5.711 | 446.1 | 27.85 | 0.8656 | 4375 | 27.8 |
• Densities
• Thermodynamics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Benzene Gas - Specific Heat vs. Temperature
Specific heat of Benzene Gas - C6H6 - at temperatures ranging 250 - 900 K.
Benzene Liquid - Thermal Properties
Properties like density, specific heat, thermal conductivity, dynamic viscosity and Prandtl number.
Density Converter
Hydrocarbons - Physical Data
Mass vs. Weight
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
