ρ = m / V (1)
γ = m g / V
= ρ g (2)
Tabulated values of methane density and specific weight at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Online Methane Density Calculator
The calculator below can be used to estimate the density and specific weight of gaseous methane at given temperature and pressure.
Choose the actual pressure:
Density and specific weight of methane at given temperatures and pressures:
For full table with Density and Specific Weight- rotate the screen!
| (K) | (°C) | (°F) | (MPa) | (bara) | (psia) | (mol/dm3) | (g/l), (kg/m3) | (lbm/ft3) | (sl/ft3 ×10-3) | (N/m3) | (lbf/ft3) | |
| Liquid | 100 | -173 | -280 | 0.1 | 1 | 14.5 | 27.36 | 438.9 | 27.40 | 851.6 | 4304 | 27.40 |
| 111.51 | -161.6 | -259.0 | 0.1 | 1 | 14.5 | 26.34 | 422.6 | 26.38 | 819.9 | 4144 | 26.38 | |
| Gas | 111.51 | -161.6 | -259.0 | 0.1 | 1 | 14.5 | 0.1119 | 1.795 | 0.1120 | 3.482 | 17.60 | 0.1120 |
| 140 | -133 | -208 | 0.1 | 1 | 14.5 | 0.08746 | 1.403 | 0.08759 | 2.722 | 13.76 | 0.08759 | |
| 180 | -93.2 | -136 | 0.1 | 1 | 14.5 | 0.06738 | 1.081 | 0.06748 | 2.097 | 10.60 | 0.06748 | |
| 200 | -73.2 | -99.7 | 0.1 | 1 | 14.5 | 0.06052 | 0.9708 | 0.06061 | 1.884 | 9.521 | 0.06061 | |
| 220 | -53.2 | -63.7 | 0.1 | 1 | 14.5 | 0.05493 | 0.8812 | 0.05501 | 1.710 | 8.642 | 0.05501 | |
| 240 | -33.2 | -27.7 | 0.1 | 1 | 14.5 | 0.05030 | 0.8069 | 0.05037 | 1.566 | 7.913 | 0.05037 | |
| 260 | -13.2 | 8.3 | 0.1 | 1 | 14.5 | 0.04639 | 0.7442 | 0.04646 | 1.444 | 7.298 | 0.04646 | |
| 280 | 6.9 | 44.3 | 0.1 | 1 | 14.5 | 0.04305 | 0.6906 | 0.04311 | 1.340 | 6.772 | 0.04311 | |
| 300 | 26.9 | 80.3 | 0.1 | 1 | 14.5 | 0.04016 | 0.6442 | 0.04022 | 1.250 | 6.318 | 0.04022 | |
| 320 | 46.9 | 116 | 0.1 | 1 | 14.5 | 0.03764 | 0.6038 | 0.03769 | 1.172 | 5.921 | 0.03769 | |
| 340 | 66.9 | 152 | 0.1 | 1 | 14.5 | 0.03541 | 0.5681 | 0.03547 | 1.102 | 5.571 | 0.03547 | |
| 360 | 86.9 | 188 | 0.1 | 1 | 14.5 | 0.03344 | 0.5364 | 0.03349 | 1.041 | 5.260 | 0.03349 | |
| 400 | 127 | 260 | 0.1 | 1 | 14.5 | 0.03008 | 0.4826 | 0.03013 | 0.9364 | 4.732 | 0.03013 | |
| 500 | 227 | 440 | 0.1 | 1 | 14.5 | 0.02406 | 0.3859 | 0.02409 | 0.7488 | 3.784 | 0.02409 | |
| 600 | 327 | 620 | 0.1 | 1 | 14.5 | 0.02004 | 0.3215 | 0.02007 | 0.6238 | 3.153 | 0.02007 | |
| 700 | 427 | 800 | 0.1 | 1 | 14.5 | 0.01718 | 0.2756 | 0.01721 | 0.5348 | 2.703 | 0.01721 | |
| 800 | 527 | 980 | 0.1 | 1 | 14.5 | 0.01503 | 0.2411 | 0.01505 | 0.4678 | 2.364 | 0.01505 | |
| 900 | 627 | 1160 | 0.1 | 1 | 14.5 | 0.01336 | 0.2143 | 0.01338 | 0.4158 | 2.102 | 0.01338 | |
| 1000 | 727 | 1340 | 0.1 | 1 | 14.5 | 0.01202 | 0.1929 | 0.01204 | 0.3743 | 1.892 | 0.01204 | |
| Liquid | 100 | -173 | -280 | 1 | 10 | 145 | 27.40 | 439.6 | 27.44 | 853.0 | 4311 | 27.44 |
| 149.14 | -124.0 | -191.2 | 1 | 10 | 145 | 22.42 | 359.6 | 22.45 | 697.7 | 3526 | 22.45 | |
| Gas | 149.14 | -124.0 | -191.2 | 1 | 10 | 145 | 0.9785 | 15.70 | 0.9800 | 30.46 | 153.9 | 0.9800 |
| 160 | -113 | -172 | 1 | 10 | 145 | 0.8708 | 13.97 | 0.8721 | 27.11 | 137.0 | 0.8721 | |
| 180 | -93.2 | -136 | 1 | 10 | 145 | 0.7362 | 11.81 | 0.7373 | 22.92 | 115.8 | 0.7373 | |
| 200 | -73.2 | -99.7 | 1 | 10 | 145 | 0.6436 | 10.33 | 0.6446 | 20.03 | 101.3 | 0.6446 | |
| 220 | -53.2 | -63.7 | 1 | 10 | 145 | 0.5745 | 9.217 | 0.5754 | 17.88 | 90.39 | 0.5754 | |
| 240 | -33.2 | -27.7 | 1 | 10 | 145 | 0.5201 | 8.344 | 0.5209 | 16.19 | 81.83 | 0.5209 | |
| 260 | -13.2 | 8.3 | 1 | 10 | 145 | 0.4759 | 7.634 | 0.4766 | 14.81 | 74.86 | 0.4766 | |
| 280 | 6.9 | 44.3 | 1 | 10 | 145 | 0.4390 | 7.043 | 0.4397 | 13.67 | 69.07 | 0.4397 | |
| 300 | 26.9 | 80.3 | 1 | 10 | 145 | 0.4078 | 6.541 | 0.4084 | 12.69 | 64.15 | 0.4084 | |
| 320 | 46.9 | 116 | 1 | 10 | 145 | 0.3809 | 6.110 | 0.3814 | 11.86 | 59.92 | 0.3814 | |
| 340 | 66.9 | 152 | 1 | 10 | 145 | 0.3574 | 5.733 | 0.3579 | 11.12 | 56.22 | 0.3579 | |
| 360 | 86.9 | 188 | 1 | 10 | 145 | 0.3367 | 5.402 | 0.3372 | 10.48 | 52.98 | 0.3372 | |
| 400 | 127 | 260 | 1 | 10 | 145 | 0.3021 | 4.845 | 0.3025 | 9.402 | 47.52 | 0.3025 | |
| 500 | 227 | 440 | 1 | 10 | 145 | 0.2406 | 3.859 | 0.2409 | 7.488 | 37.85 | 0.2409 | |
| 600 | 327 | 620 | 1 | 10 | 145 | 0.2001 | 3.210 | 0.2004 | 6.229 | 31.48 | 0.2004 | |
| Liquid | 100 | -173 | -280 | 5 | 50 | 725 | 27.59 | 442.5 | 27.63 | 858.7 | 4340 | 27.63 |
| Supercritical phase |
200 | -73.2 | -99.7 | 5 | 50 | 725 | 5.471 | 87.76 | 5.479 | 170.3 | 860.6 | 5.479 |
| 250 | -23.2 | -9.7 | 5 | 50 | 725 | 3.117 | 50.00 | 3.121 | 97.02 | 490.3 | 3.121 | |
| 300 | 26.9 | 80.3 | 5 | 50 | 725 | 2.180 | 34.97 | 2.183 | 67.85 | 342.9 | 2.183 | |
| 350 | 76.9 | 170 | 5 | 50 | 725 | 1.745 | 28.00 | 1.748 | 54.33 | 274.6 | 1.748 | |
| 400 | 127 | 260 | 5 | 50 | 725 | 1.533 | 24.60 | 1.536 | 47.73 | 241.2 | 1.536 | |
| 500 | 227 | 440 | 5 | 50 | 725 | 1.201 | 19.27 | 1.203 | 37.39 | 189.0 | 1.203 | |
| 600 | 327 | 620 | 5 | 50 | 725 | 0.9928 | 15.93 | 0.9943 | 30.90 | 156.2 | 0.9943 | |
| Liquid | 100 | -173 | -280 | 10 | 100 | 1450 | 27.80 | 446.0 | 27.84 | 865.4 | 4374 | 27.84 |
200 | -73.2 | -100 | 10 | 100 | 1450 | 16.59 | 266.2 | 16.62 | 516.5 | 2610 | 16.62 |
| 240 | -33.2 | -27.7 | 10 | 100 | 1450 | 8.004 | 128.4 | 8.016 | 249.1 | 1259 | 8.016 | |
| 260 | -13.2 | 8.3 | 10 | 100 | 1450 | 6.296 | 101.0 | 6.305 | 196.0 | 990.5 | 6.305 | |
| 280 | 6.9 | 44.3 | 10 | 100 | 1450 | 5.330 | 85.51 | 5.338 | 165.9 | 838.6 | 5.338 | |
| 300 | 26.9 | 80.3 | 10 | 100 | 1450 | 4.686 | 75.17 | 4.693 | 145.9 | 737.2 | 4.693 | |
| 320 | 46.9 | 116 | 10 | 100 | 1450 | 4.214 | 67.61 | 4.221 | 131.2 | 663.0 | 4.221 | |
| 340 | 66.9 | 152 | 10 | 100 | 1450 | 3.849 | 61.75 | 3.855 | 119.8 | 605.6 | 3.855 | |
| 360 | 86.9 | 188 | 10 | 100 | 1450 | 3.554 | 57.01 | 3.559 | 110.6 | 559.1 | 3.559 | |
| 400 | 127 | 260 | 10 | 100 | 1450 | 3.100 | 49.73 | 3.105 | 96.50 | 487.7 | 3.105 | |
| 500 | 227 | 440 | 10 | 100 | 1450 | 2.389 | 38.32 | 2.392 | 74.35 | 375.8 | 2.392 | |
| 600 | 327 | 620 | 10 | 100 | 1450 | 1.962 | 31.47 | 1.965 | 61.07 | 308.6 | 1.965 | |
200 | -73.2 | -100 | 100 | 1000 | 14500 | 25.50 | 409.0 | 25.53 | 793.6 | 4011 | 25.53 |
| 300 | 26.9 | 80.3 | 100 | 1000 | 14500 | 21.27 | 341.1 | 21.30 | 661.9 | 3346 | 21.30 | |
| 400 | 127 | 260 | 100 | 1000 | 14500 | 17.88 | 286.8 | 17.91 | 556.6 | 2813 | 17.91 | |
| 500 | 227 | 440 | 100 | 1000 | 14500 | 15.31 | 245.5 | 15.33 | 476.4 | 2408 | 15.33 | |
| 600 | 327 | 620 | 100 | 1000 | 14500 | 13.36 | 214.3 | 13.38 | 415.8 | 2101 | 13.38 | |
• Densities
• Thermodynamics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Density Converter
Mass vs. Weight
Methane (CH₄): Thermophysical Properties and Phase Diagram
Methane - Liquid vs. Gaseous Units
Convert between liquid and gaseous LNG and Methane units.
Online calculator, figures and table showing thermal conductivity of methane, CH4, at temperatures ranging from -160 to 725 °C (-260 to 1300 °F) at atmospheric and higher pressure - Imperial and SI Units.
Methane Gas - Specific Heat vs. Temperature
Specific heat of Methane Gas - CH4 - at temperatures ranging 200 - 1100 K.
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
