Methane - Liquid vs. Gaseous Units
Commonly used units to measure Natural Gas or Methane - LNG - volume and weight:
Multiply with
ToFrom
1 thermie 1061 therm 1061 bbl liquid1 m3 gas 1091 m3 liquid1 ft3 1061 ft3 liquid1 long ton liquid
long ton liquid 74.12 1868 0.0664 704374 0.4177 19.91 0.011826 1
ft3 liquid 6268 157985 5.615 59.56 106 35.315 1599 1 84.56
ft3 gas 3.92 106 98.79 106 3512 37.25 109 22090 106 625.43 52886
m3 liquid 177.44 4472 0.159 1.686 106 1 45.27 0.0283 2.394
m3 gas 105228 2.652 106 94.27 109 593 26847 16.789 1419.7
bbl liquid 1116.2 28132 1 10.61 106 6.29 284.785 0.1781 15.06
therm 39669 106 35.54 0.377 109 223.55 10121 6.329 535.2
th 106 25.207 106 859.8 9.503 109 5635.2 255115 159.54 13491
  • ft3 measured at 60oF and 14.696 lbf/in2
  • m3 measured at 0oC and 760 mmHg
Example - Converting 10 m3 methane liquid to m3 gas
From the table above - multiply (m3 liquid) with 593 to calculate (m3 gas) - as
qgas = 593 (10 m3 liquid)
        = 5930 (m3 gas)
Combustion
Gases and Compressed Air
Online calculator, figures and table showing thermal conductivity of methane, CH4, at temperatures ranging from -160 to 725 °C (-260 to 1300 °F) at atmospheric and higher pressure - Imperial and SI Units.
Methane - Thermophysical Properties
Natural Gas - Equipment Consumption
Natural gas consumption for equipment like boiling pans, ovens, cookers, kettles and more.
Natural Gas Piping - Sizing vs. Capacity
Sizing natural gas pipes - pressures above 5 psi (35 kPa).
