Air Conditioning
Using steam to humidify air.
Air Conditioner Efficiency
The ratio between heat removed and power (watt) used - EER and SEER.
Air Conditioning - Cooling of Air and Condensate Generated
Water may condensate when air is cooled in air conditioning systems.
Air Cooling of Storage Roooms
Heat removed from storage rooms with cooled air.
Ammonia and health symptoms - smell and threat to life.
Thermodynamic properties of saturated and superheated ammonia R-717 like specific volume, enthalpy and entropy.
Antifreeze - Ethylene Glycol Volume vs. Temperature Rating
Freeze protecting of cooling systems - temperature rating vs. required amount of antifreeze.
Antifreeze - Ethylene Glycol vs. Propylene Glycol
Comparing ethylene glycol and propylene glycol antifreeze properties.
ASTM B280 Copper Tube for Air Conditioning and Refrigeration (ACR) - Dimensions and Working Pressures
Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
Calculating Cooling Loads
Calculating chiller and cooling tower refrigeration loads - in tons.
Chilled Water Systems
Chilled water system equations - evaporator and condenser flow rates.
Cooling and Heating - Performance and Efficiency Terminology
Performance and efficiency terminology related to heat pumps and air condition systems.
Cooling and Heating Equations
Cooling Load - Convert between kW/ton to COP or EER
Convert between cooling load units like kW/ton, COP and EER.
Cooling Load - Latent and Sensible Heat
Latent and sensible cooling loads to consider when designing HVAC systems.
Cooling Power vs. Airflow and Duct Sizes
Typical relations between cooling power (tons cooling), air flow and duct size
Dehumidifiers
Classification of dehumidifiers.
Equivalent Diameter - Rectangular vs. Circular HVAC Ducts
Rectangular equivalent diameter for air flows between 100 - 50000 cfm.
Ethylene Glycol Heat-Transfer Fluid Properties
Freeze Protection of Water based Heat Transfer Fluids
Comparing antifreezes used in water based heat transfer fluids or brines.
Fruits and Vegetables - Optimal Storage Conditions
Optimal temperature and humidity conditions for common fruits and vegetables.
Heat Emission from Animals
Heat energy produced by animals.
Heat Gain from Electrical Motors in Continuous Operation
Amount of heat transferred from electrical motor to ambient room vs. locations of fan and motor.
Heat Gain from Lights
Heat contributed by lights may have major impact on air-condition systems.
Heat Index
Equivalent heat index vs. air temperature and relative humidity - in degrees Fahrenheit and Celsius.
Heat Loss from Electrical Equipment
Heat loss from electrical equipment like switch-gear, transformers and variable frequency drives.
Heat Pumps - Performance and Efficiency Ratings
Performance and efficiency rating of heat pumps.
Human Heat Gain
Heat gain from persons in air conditioned spaces - in btu/hr.
Indoor Comfort Temperatures vs. Outdoor Temperatures
Recommended indoor comfort temperatures vs. outdoor temperatures.
Indoor Conditions - Summer or Winter
Recommended indoor design conditions summer or winter.
Industrial Product and Production Processes - Climate Conditions
Recommended indoor temperature and humidity for common industrial products and production processes.
Lights vs. Power Installation
Lights vs. power installations in common types of buildings and rooms.
Metabolic Heat Gain from Persons
Human metabolic heat gain in air conditioned rooms.
Net Refrigeration Effect
The quantity of heat absorbed from a refrigerated space.
Outdoor Temperatures and Relative Humidity - US Winter and Summer Conditions
Outdoor summer and winter design temperatures and relative humidity for US states and cities.
R-12 Dichlorodifluoromethane - Properties
Thermodynamic properties of saturated and superheated Dichlorodifluoromethane (CF2Cl2), like specific volume, enthalpy and entropy.
R22 Refrigerant - Properties
Properties of Refrigerant R22 Dichlorodifluoromethane - saturated liquid and saturated vapor - imperial and metric units.
Refrigerant Compressors - Evaporation Temperature, Condensating Temperature and Capacity
Evaporation temperature, condensing temperature and refrigerant compressor capacity.
Refrigerant R134a - Properties
Thermodynamic properties of refrigerant R-134a.
Refrigerant R22 - Thermodynamic Properties
Thermodynamic properties of R22, like vapor volume, enthalpy and entropy at pressures from 30 to 260 psia.
Refrigerants
Commonly used refrigerants - the methane series, ethane series, propane series, cyclic organic compounds, zeotropic blends, azeotropic blends and organic compounds.
Refrigerants - Color Codes
Common refrigerants and their color codes.
Refrigerants - Environmental Properties
Refrigerants - Ozone Depletion (ODP) and Global Warming Potential (GWP).
Physical and environmental properties of some common refrigerants.
Refrigerants - Pressure vs. Temperature Charts
Temperature and pressure chart for refrigerants R22, R410A, R12, R134A, R401A, R409A, R502, R404A, R507A, R408A and R402A.
Refrigerants - Saturation Pressures vs. Temperatures
Temperature and pressure diagram for constant boiling refrigerants - imperial and SI units.
Refrigeration Formulas
Calculate compression work, coefficients of performance and more.
Refrigeration Machinery - Required Ventilation
Ventilation required for refrigeration machinery and compressors in hot areas.
Relative Humidity in Production and Process Environments
Recommended relative humidity in production and process environments - like libraries, breweries, storages and more.
Sensible Heat Ratio - SHR
The ratio Sensible Heat (or Cooling) Load to the Total Heat (or Cooling) Load.
Solar Heat Transmission and Type of Glass
Relative solar heat transmission through different types of glass windows
Solar Heat Transmission through Windows
Solar heat gain through windows with roller shades, vertical blinds and Venetian blinds
Ventilation and Air Conditioning Equipment - Area Required
Required size of ventilation and air conditioning rooms according DIN 1946.
Water Evaporator and Condenser Equations
Air conditioner heat loads and evaporator and condenser water flow rates.
