Air humidity can be estimated by measuring
- dry bulb temperature, and
- wet bulb temperature
Dry Bulb Temperature - Tdb - can be measured with a simple thermometer as shown above.
Wet Bulb Temperature - Twb - can be measured with a standard thermometer with some wet clothing, cotton or similar, around the bulb. Note that continuously air flow around the thermometer is important to evaporate water from the wet clothing and achieve a correct wet bulb temperature.
Sufficient air movement can be achieved with a sling thermometer or similar.
Relative humidity can be estimated from the tables below or alternatively from a psyhrometric or a Mollier diagram.
Example - The State of Air in the Mollier Diagram
If the dry bulb temperature of air is 19 oC and the web bulb temperature is 12 oC - then the state of air can be visualized in the Mollier diagram as indicated below.
- the relative humidity is approximately 42%
- the humidity ratio is approximately 0.0057 kgh2o/kgdry_air
Relative Humidity - Temperature in Celsius
The table below can be used to estimate the relative humidity of air if dry and wet bulb temperatures are known.
Tdb - Twb (oC) | Relative Humidity - RH (%) | |||||||
Dry Bulb Temperature - Tdb (oC) | ||||||||
15 | 18 | 20 | 22 | 25 | 27 | 30 | 33 | |
1 | 90 | 91 | 91 | 92 | 92 | 92 | 93 | 93 |
2 | 80 | 82 | 83 | 84 | 85 | 85 | 86 | 87 |
3 | 71 | 73 | 75 | 76 | 77 | 78 | 79 | 80 |
4 | 62 | 65 | 67 | 68 | 70 | 71 | 73 | 74 |
5 | 53 | 57 | 59 | 61 | 64 | 65 | 67 | 69 |
6 | 44 | 49 | 52 | 54 | 57 | 59 | 61 | 63 |
7 | 36 | 42 | 45 | 47 | 51 | 53 | 55 | 58 |
8 | 28 | 34 | 38 | 41 | 45 | 47 | 50 | 53 |
9 | 21 | 27 | 31 | 34 | 39 | 41 | 45 | 48 |
10 | 13 | 20 | 25 | 28 | 33 | 36 | 40 | 43 |
Example - Relative Humidity
If the dry bulb temperature of air is 18 oC and the web bulb temperature is 12 oC - then the difference between them is 6 oC. By using the table above
- the relative humidity is approximately 49%
Example - the State of Air in the Psychrometric Chart
The state of air with dry bulb temperature 75 oF and wet bulb temperature 62.5 oF can be visualized in the psychrometric chart as indicated below.
- the relative humidity is approximately 50%
- the humidity ratio is approximately 65 grainsh2o/lbdry_air
Relative Humidity - Temperature in Fahrenheit
Tdb - Twb (oF) | Relative Humidity - RH (%) | |||||||
Dry Bulb Temperature - Tdb (oF) | ||||||||
60 | 64 | 68 | 72 | 76 | 80 | 84 | 88 | |
1 | 94 | 95 | 95 | 95 | 96 | 96 | 96 | 96 |
2 | 90 | 90 | 90 | 91 | 91 | 92 | 92 | 92 |
3 | 84 | 85 | 85 | 86 | 87 | 88 | 88 | 89 |
4 | 78 | 80 | 81 | 82 | 83 | 84 | 84 | 85 |
5 | 73 | 75 | 76 | 78 | 79 | 80 | 80 | 81 |
6 | 68 | 70 | 72 | 73 | 75 | 76 | 77 | 78 |
7 | 63 | 66 | 67 | 69 | 71 | 72 | 73 | 74 |
8 | 58 | 61 | 63 | 65 | 67 | 68 | 70 | 71 |
9 | 54 | 57 | 59 | 61 | 63 | 65 | 66 | 68 |
10 | 49 | 52 | 55 | 57 | 59 | 61 | 63 | 6 |
• Air Conditioning Systems
• Air Psychrometrics
• Process Control Systems
Instrumentation, design and documentation of process control systems.
Air - Humidity Ratio
Air - Psychrometric Chart for Standard Atmospheric Conditions - Imperial Units
Psychrometric chart to analyze air properties, including temperature, humidity, enthalpy, and dew point at barometric pressure 29.921 inches of Mercury and temperature ranging 20oF to 120oF.
Dehumidifiers
Classification of dehumidifiers.
Discomfort Index
Comfort vs. dry bulb, wet bulb and dew point temperature.
Dry Bulb, Wet Bulb and Dew Point Temperatures
Dry Bulb, Wet Bulb and Dew Point temperatures can be used to determine the state of humid air.
Humid Air - Heating
Humid Air and the Ideal Gas Law
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Mixing of Humid Air
Moist Air - Degree of Saturation
Humidity ratio of moist air to humidity ratio of saturated moist air.
Moist Air - Density vs. Pressure
Density of moist air vs. pressure ranging 75 - 1000 mmHg.
Moist Air - Enthalpy
Moist Air - Partial Pressure and Daltons Law
The pressure in a mixture of dry air and water vapor - humid or moist air - can be estimated by using Daltons Law of partial pressures.
Moist Air - Properties
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Moist Air - Psychrometric Table for Pressure 29.92 inHg
Dry and wet bulb temperatures, saturation pressure, water vapor weight, specific volume, heat and more.
Moist Air - Psychrometric Terms
Dry and wet bulb temperature, specific volume, relative humidity, enthalpy and more.
Moist Air - Relative Humidity
Relative humidity in moist air is the ratio of partial vapor pressure to air pressure.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Moist Air - Transforming the Mollier Diagram to a Psychrometric Chart - or vice versa
The relationship between the psycrometric chart and the Mollier diagram.
Moist Air - Water Vapor and Saturation Pressure
Saturation pressure of water vapor in moist air vs. temperature.
Temperature Sensors - Comparing Types
Comparing advantages and disadvantages of thermocouples, RTDs and thermistors temperature sensors.
Thermocouples
Thermocouples - types, principles and temperature ranges.
Wet Bulb Globe Temperature (WBGT)
The Wet Bulb Globe Temperature can be used to measure the general Heat-Stress index.
