Moist Air - Partial Pressure and Daltons Law
Daltons Law states that
- the total pressure of a mixture of gases is equal to the sum of the partial pressures of the constituent gases
The partial pressure is the pressure each gas would exert if it alone occupied the volume of the mixture.
Daltons Law of partial pressure for moist air can be expressed as
p = pa + pw (1)
p = total pressure of air (Pa, N/m2)
pa = partial pressure dry air (Pa, N/m2)
pw = partial pressure water vapor (Pa, N/m2)
With the partial pressure for dry air and water vapor (1) can be modified to:
p = ρa 286.9 T + ρw 455 T (2)
ρa = density of air (kg/m3)
ρw = density of water vapor (kg/m3)
• Air Psychrometrics
Air and Steam Mixtures
Air in the steam will lower the surface temperatures in heat exchangers - and less heat will be transferred.
Humid Air and the Ideal Gas Law
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Moist Air - Degree of Saturation
Humidity ratio of moist air to humidity ratio of saturated moist air.
Moist Air - Density vs. Pressure
Density of moist air vs. pressure ranging 75 - 1000 mmHg.
Moist Air - Enthalpy
Moist Air - Properties
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Moist Air - Relative Humidity
Relative humidity in moist air is the ratio of partial vapor pressure to air pressure.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Moist Air - Water Vapor and Saturation Pressure
Saturation pressure of water vapor in moist air vs. temperature.
Moist Air - Weight of Water Vapor
Weight of water vapor in air
