Components in Dry Air
Air is a mixture of several gases, where the two most dominant components in dry air are 21 vol% oxygen and 78 vol% nitrogen . Oxygen has a molar mass of 15.9994 g/mol and nitrogen has a molar mass of 14.0067 g/mol. Since both of these elements are diatomic in air - O2 and N2, the molar mass of oxygen gas is 32 g/mol and the molar mass of nitrogen gas is 28 g/mol.
The average molar mass is equal to the sum of the mole fractions of each gas multiplied by the molar mass of that particular gas:
Mmixture = x1 M1 +......+ xn Mn (1)
xi = mole fractions of each gas
Mi = the molar mass of each gas
The molar mass of dry air is 28.9647 g/mol. Composition and content of each gas in air is given in the figures and the table below.
See also Air Density at varying pressure, Density and specific weight at varying temperature, Diffusion Coefficients for Gases in Air, Dynamic (absolute) and kinematic viscosity, Prandtl Number, Specific heat at varying temperature and Specific heat at varying pressure, Thermal Conductivity, Thermal Diffusivity, Properties at gas-liquid equilibrium conditions and Air properties, for other properties of air.
Air is usually modeled as a uniform (no variation or fluctuation) gas with properties averaged from the individual components.
| Components in dry air | Volume ratio = Molar ratio compared to dry air | Molar mass | Molar mass in air | Atmospheric boiling point | |||||
| Name | Formula | (mol/molair ) | (vol%) | (g/mol), (kg/kmol) | (g/molair ), (kg/kmolair ) | (wt%) | (K) | (°C) | (°F) |
| Nitrogen | N2 | 0.78084 | 78.084 | 28.013 | 21.872266 | 75.511 | 77.4 | -195.8 | -320.4 |
| Oxygen | O2 | 0.20946 | 20.946 | 31.999 | 6.701942 | 23.14 | 90.2 | -183.0 | -297.3 |
| Argon | Ar | 0.00934 | 0.934 | 39.948 | 0.373025 | 1.29 | 87.3 | -185.8 | -302.5 |
| Carbon dioxide1) | CO2 | 0.000412 | 0.0412 | 44.010 | 0.018132 | 0.063 | 194.7 | -78.5 | -109.2 |
| Neon | Ne | 0.00001818 | 0.001818 | 20.180 | 0.000367 | 0.0013 | 27.2 | -246.0 | -410.7 |
| Helium | He | 0.00000524 | 0.000524 | 4.003 | 0.000021 | 0.00007 | 4.2 | -269.0 | -452.1 |
| Methane | CH4 | 0.00000179 | 0.000179 | 16.042 | 0.000029 | 0.00010 | 111.7 | -161.5 | -258.7 |
| Krypton | Kr | 0.0000010 | 0.0001 | 83.798 | 0.000084 | 0.00029 | 119.8 | -153.4 | -244.0 |
| Hydrogen | H2 | 0.0000005 | 0.00005 | 2.016 | 0.000001 | 0.000003 | 20.3 | -252.9 | -423.1 |
| Xenon | Xe | 0.00000009 | 0.000009 | 131.293 | 0.000012 | 0.00004 | 165.1 | -108.1 | -162.5 |
| Average molar mass of air | 28.9647 | ||||||||
1) According NASA CO2level in 1960 aprox. 320 ppm, 1970 aprox. 328 ppm, 1980 aprox. 341 ppm, 1990 aprox. 356 ppm, 2000 aprox. 372 ppm, 2010 aprox. 390 ppm and 2020 aprox. 412 ppm
- The water or vapor content in air varies. The maximum moisture carrying capacity of air depends primarily on temperature
- The composition of air is unchanged until elevation of approximately 10.000 m
- The average air temperature diminishes at the rate of 0.6 oC for each 100 m vertical height
- "One Standard Atmosphere" is defined as the pressure equivalent to that exerted by a 760 mm column of mercury at 0 oC sea level and at standard gravity (32.174 ft/sec2)
Other components in air
- Sulfur dioxide - SO2 - 1.0 parts/million (ppm)
- Nitrous oxide - N2O - 0.5 parts/million (ppm)
- Ozone - O3 - 0 to 0.07 parts/million (ppm)
- Nitrogen dioxide - NO2 - 0.02 parts/million (ppm)
- Iodine - I2 - 0.01 parts/million (ppm)
- Carbon monoxide - CO - 0 to trace (ppm)
- Ammonia - NH3 - 0 to trace (ppm)
Common Pressure Units frequently used as alternative to " one Atmosphere"
- 76 Centimeters (760 mm) of Mercury
- 29.921 Inches of Mercury
- 10.332 Meters of Water
- 406.78 Inches of Water
- 33.899 Feet of Water
- 14.696 Pound-Force per Square Inch
- 2116.2 Pounds-Force per Square Foot
- 1.033 Kilograms-Force per Square Centimeter
- 101.33 kiloPascal
• Air Psychrometrics
• Gases and Compressed Air
Air - Humidity Ratio
Air - Prandtl Number
Air - Specific Heat Ratio
Specific Heat Ratio of air at temperatures ranging -40 - 1000 degC (-40 - 1500 degF) at standard atmospheric pressure - Imperial and SI Units.
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Air Conditioning - Cooling of Air and Condensate Generated
Water may condensate when air is cooled in air conditioning systems.
Air Properties: Temperature, Pressure & Density Data
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Pressure loss in compressed air pipe lines.
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Humid Air and the Ideal Gas Law
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Moist Air - Mole Fraction of Water Vapor
Mole fraction of water vapor is the ratio of water molecules to air and water molecules.
Moist Air - Partial Pressure and Daltons Law
The pressure in a mixture of dry air and water vapor - humid or moist air - can be estimated by using Daltons Law of partial pressures.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Moist Air - Weight of Water Vapor
Weight of water vapor in air
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Nitrogen - Enthalpy, Internal Energy and Entropy vs. Temperature
Enthalpy, internal energy and entropy of Nitrogen as an ideal gas.
Nitrogen - Thermal Diffusivity vs. Temperature and Pressure
Figures and tables showing thermal diffusivity of nitrogen at varying temperarure and pressure, SI and Imperial units.
Nitrogen Gas - Specific Heat vs. Temperature
Specific heat of Nitrogen Gas - N2 - at temperatures ranging 175 - 6000 K
Oxygen - Enthalpy, Internal Energy and Entropy vs. Temperature
Enthalpy, internal energy and entropy of oxygen as an ideal gas.
Specific heat of Oxygen Gas - O2 - at temperatures ranging 175 - 6000 K.
Solubility of Air in Water
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
Specific Heat Capacity of Air: Isobaric and Isochoric Heat Capacities at Various Temperatures and Pressures
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
U.S. Standard Atmosphere: Temperature, Pressure, and Air Properties vs. Altitude
Properties of the US standard atmosphere ranging -5000 to 250000 ft altitude.
