Thermal conductivity is a material property that describes ability to conduct heat . Thermal conductivity can be defined as
" the quantity of heat transmitted through a unit thickness of a material - in a direction normal to a surface of unit area - due to a unit temperature gradient under steady state conditions".
Thermal conductivity most common units are W/(m K) in the SI system and Btu/(h ft °F) in the Imperial system.
Tabulated values and thermal conductivity units conversion are given below the figures.
Online Air Thermal Conductivity Calculator
The calculator below can be used to calculate the air thermal conductivity at given temperatures and pressure.
The output conductivity is given as mW/(m K), Btu(IT)/(h ft °F) and kcal(IT)/(h m K).
Choose the actual pressure:
See also other properties of Air at varying temperature and pressure: Density and specific weight at varying temperature, Density at varying pressure, Diffusion Coefficients for Gases in Air, Prandtl Number, Specific heat at varying temperature and Specific heat at varying pressure, Thermal Diffusivity, Properties at gas-liquid equilibrium conditions and Air thermophysical properties at standard conditions and Composition and molecular weight,
as well as thermal conductivity o f ammonia, butane, carbon dioxide, ethane, ethylene, hydrogen, methane, nitrogen, propane and water.
See also Conductive Heat Transfer Calculator
Air thermal conductivity at atmospheric pressure and temperatures given in °C:
| Temperature | Thermal conductivity | ||
| (°C) | (mW/m K) | (kcal(IT)/(h m K)) | (Btu(IT)/(h ft °F)) |
| -190 | 7.82 | 0.00672 | 0.00452 |
| -150 | 11.69 | 0.01005 | 0.00675 |
| -100 | 16.20 | 0.01393 | 0.00936 |
| -75 | 18.34 | 0.01577 | 0.01060 |
| -50 | 20.41 | 0.01755 | 0.01179 |
| -25 | 22.41 | 0.01927 | 0.01295 |
| -15 | 23.20 | 0.01995 | 0.01340 |
| -10 | 23.59 | 0.02028 | 0.01363 |
| -5 | 23.97 | 0.02061 | 0.01385 |
| 0 | 24.36 | 0.02094 | 0.01407 |
| 5 | 24.74 | 0.02127 | 0.01429 |
| 10 | 25.12 | 0.02160 | 0.01451 |
| 15 | 25.50 | 0.02192 | 0.01473 |
| 20 | 25.87 | 0.02225 | 0.01495 |
| 25 | 26.24 | 0.02257 | 0.01516 |
| 30 | 26.62 | 0.02289 | 0.01538 |
| 40 | 27.35 | 0.02352 | 0.01580 |
| 50 | 28.08 | 0.02415 | 0.01623 |
| 60 | 28.80 | 0.02477 | 0.01664 |
| 80 | 30.23 | 0.02599 | 0.01746 |
| 100 | 31.62 | 0.02719 | 0.01827 |
| 125 | 33.33 | 0.02866 | 0.01926 |
| 150 | 35.00 | 0.03010 | 0.02022 |
| 175 | 36.64 | 0.03151 | 0.02117 |
| 200 | 38.25 | 0.03289 | 0.02210 |
| 225 | 39.83 | 0.03425 | 0.02301 |
| 300 | 44.41 | 0.03819 | 0.02566 |
| 412 | 50.92 | 0.04378 | 0.02942 |
| 500 | 55.79 | 0.04797 | 0.03224 |
| 600 | 61.14 | 0.05257 | 0.03533 |
| 700 | 66.32 | 0.05702 | 0.03832 |
| 800 | 71.35 | 0.06135 | 0.04122 |
| 900 | 76.26 | 0.06557 | 0.04406 |
| 1000 | 81.08 | 0.06971 | 0.04685 |
| 1100 | 85.83 | 0.07380 | 0.04959 |
Air thermal conductivity at atmospheric pressure and temperatures given in °F:
| (°F) | (Btu(IT)/(h ft °F)) | (kcal(IT)/(h m K)) | (mW/m K) |
| -300 | 0.00484 | 0.00720 | 8.37 |
| -200 | 0.00788 | 0.01172 | 13.63 |
| -100 | 0.01068 | 0.01589 | 18.48 |
| -50 | 0.01200 | 0.01786 | 20.77 |
| -20 | 0.01277 | 0.01901 | 22.10 |
| 0 | 0.01328 | 0.01976 | 22.98 |
| 10 | 0.01353 | 0.02013 | 23.41 |
| 20 | 0.01378 | 0.02050 | 23.84 |
| 30 | 0.01402 | 0.02087 | 24.27 |
| 40 | 0.01427 | 0.02123 | 24.70 |
| 50 | 0.01451 | 0.02160 | 25.12 |
| 60 | 0.01476 | 0.02196 | 25.54 |
| 70 | 0.01500 | 0.02232 | 25.95 |
| 80 | 0.01524 | 0.02267 | 26.37 |
| 100 | 0.01571 | 0.02338 | 27.19 |
| 120 | 0.01618 | 0.02408 | 28.00 |
| 140 | 0.01664 | 0.02477 | 28.80 |
| 160 | 0.01710 | 0.02545 | 29.60 |
| 180 | 0.01755 | 0.02612 | 30.38 |
| 200 | 0.01800 | 0.02679 | 31.16 |
| 250 | 0.01911 | 0.02843 | 33.07 |
| 300 | 0.02018 | 0.03003 | 34.93 |
| 350 | 0.02123 | 0.03160 | 36.75 |
| 400 | 0.02226 | 0.03313 | 38.53 |
| 450 | 0.02327 | 0.03463 | 40.28 |
| 500 | 0.02426 | 0.03611 | 41.99 |
| 600 | 0.02620 | 0.03898 | 45.34 |
| 700 | 0.02807 | 0.04177 | 48.58 |
| 800 | 0.02990 | 0.04449 | 51.74 |
| 1000 | 0.03342 | 0.04973 | 57.84 |
| 1200 | 0.03680 | 0.05477 | 63.69 |
| 1400 | 0.04007 | 0.05963 | 69.35 |
| 1600 | 0.04325 | 0.06436 | 74.85 |
| 1800 | 0.04635 | 0.06898 | 80.23 |
| 2000 | 0.04941 | 0.07353 | 85.51 |
Thermal conductivity units conversion:
british thermal unit(international)/(foot hour degree fahrenheit) (Btu(IT)/(ft h°F), british thermal unit(international)/(inch hour degree fahrenheit) (Btu(IT)/(in h°F), british thermal unit(international)*inch/(square foot*hour*degree fahrenheit) ((Btu(IT) in)/(ft² h°F)), kilocalorie/(meter hour degree celcius) (kcal/(m h°C)), joule/(centimeter second degree kelvin) (J/(cm s K)), watt/(meter degree kelvin) (W/(m°C)),
- 1 Btu(IT)/(ft h°F) = 1/12 Btu(IT)/(in h°F) = 0.08333 Btu(IT)/(in h°F) = 12 Btu(IT)in/(ft2h°F) = 1.488 kcal/(m h°C) = 0.01731 J/(cm s K) = 1.731 W/(m K)
- 1 Btu(IT)/(in h°F) = 12 Btu(IT)/(ft h°F) = 144 Btu(IT)in/(ft2h°F) = 17.858 kcal/(m h°C) = 0.20769 J/(cm s K)= 20.769 W/(m K)
- 1 (Btu(IT) in)/(ft² h°F) = 0.08333 Btu(IT)/(ft h°F) = 0.00694 Btu(IT)/(in h°F) = 0.12401 kcal/(m h°C) = 0.001442 J/(cm s K) = 0.1442 W/(m K)
- 1 J/(cm s K) = 100 W/(m K) = 57.789 Btu(IT)/(ft h°F) = 4.8149 Btu(IT)/(in h°F) = 693.35 (Btu(IT) in)/(ft² h°F) = 85.984 kcal/(m h°C)
- 1 kcal/(m h°C) = 0.6720 Btu(IT)/(ft h°F) = 0.05600 Btu(IT)/(in h°F) = 8.0636 (Btu(IT) in)/(ft2h°F) = 0.01163 J/(cm s K) = 1.163 W/(m K)
- 1 W/(m K) = 0.01 J/(cm s K) = 0.5779 Btu(IT)/(ft h°F) = 0.04815 Btu(IT)/(in h°F) = 6.9335 (Btu(IT) in)/(ft² h°F) = 0.85984 kcal/(m h°C)
• Air Psychrometrics
• Gases and Compressed Air
Air - Humidity Ratio
Air - Prandtl Number
Air - Specific Heat Ratio
Specific Heat Ratio of air at temperatures ranging -40 - 1000 degC (-40 - 1500 degF) at standard atmospheric pressure - Imperial and SI Units.
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Air Conditioning - Cooling of Air and Condensate Generated
Water may condensate when air is cooled in air conditioning systems.
Air Properties - SI Units
Ideal gas properties of air at low pressure - SI units.
Air Properties: Temperature, Pressure & Density Data
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Pressure loss in compressed air pipe lines.
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Humid Air - Heating
Online calculator, figures and table showing thermal conductivity of methane, CH4, at temperatures ranging from -160 to 725 °C (-260 to 1300 °F) at atmospheric and higher pressure - Imperial and SI Units.
Moist Air - Properties
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Moist Air - Weight of Water Vapor
Weight of water vapor in air
Solubility of Air in Water
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
Specific Heat Capacity of Air: Isobaric and Isochoric Heat Capacities at Various Temperatures and Pressures
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
U.S. Standard Atmosphere: Temperature, Pressure, and Air Properties vs. Altitude
Properties of the US standard atmosphere ranging -5000 to 250000 ft altitude.
