Thermal diffusivity is the rate of transfer of heat of a material from the hot side to the cold side - a measure of how quickly a material can absorb heat from its surroundings. It can be calculated by taking the thermal conductivity divided by density and specific heat capacity at constant pressure.
Thermal diffusivity has the SI derived unit of (m²/s) , and is usually denoted α but a, κ, K, and D are also used. The formula is:
α = k / (ρ CP) (1)
k = is thermal conductivity (W/(m·K))
ρ = density (kg/m³)
CP = specific heat capacity (J/(kg·K))
Below, thermal diffusivity for air at varying temperatures and pressures are given in figures and tables.
See also other properties of Air at varying temperature and pressure: Density and specific weight at varying temperature, Density at varying pressure, Diffusion Coefficients for Gases in Air, Prandtl Number, Specific heat at varying temperature and Specific heat at varying pressure, Thermal Conductivity, Properties at gas-liquid equilibrium conditions and Air thermophysical properties at standard conditions and Composition and molecular weight,
as well as thermal diffusivity of nitrogen, propane and water .
Air thermal diffusivity at 1 bara pressure, temperature given as °C or °F:
Air thermal diffusivity at varying temperatures and constant pressures, SI and Imperial units:
Air thermal diffusivity at atmospheric pressure, given in SI and Imperial units:
| Temperature | Thermal diffusivity | Temperature | Thermal diffusivity | |||||
| (K) | (°C) | (×10-6 m2/s) | (m2/h) | (K) | (°F) | (×10-5 ft2/s) | ( ft2/h) | |
| 173.2 | -100 | 7.88 | 0.02837 | 172.0 | -150 | 8.371 | 0.3014 | |
| 223.2 | -50 | 13.02 | 0.04686 | 213.7 | -75 | 12.89 | 0.4640 | |
| 243.2 | -30 | 15.33 | 0.05518 | 227.6 | -50 | 14.55 | 0.5238 | |
| 253.2 | -20 | 16.54 | 0.05953 | 241.5 | -25 | 16.29 | 0.5863 | |
| 263.2 | -10 | 17.78 | 0.06401 | 249.8 | -10 | 17.36 | 0.6251 | |
| 268.2 | -5 | 18.41 | 0.06629 | 255.4 | 0 | 18.09 | 0.6514 | |
| 273.2 | 0 | 19.06 | 0.06860 | 260.9 | 10 | 18.84 | 0.6782 | |
| 278.2 | 5 | 19.71 | 0.07094 | 266.5 | 20 | 19.59 | 0.7053 | |
| 283.2 | 10 | 20.36 | 0.07331 | 283.2 | 50 | 21.92 | 0.7891 | |
| 293.2 | 20 | 21.70 | 0.07813 | 297.0 | 75 | 23.93 | 0.8615 | |
| 298.2 | 25 | 22.39 | 0.08059 | 310.9 | 100 | 26.01 | 0.9363 | |
| 303.2 | 30 | 23.07 | 0.08307 | 324.8 | 125 | 28.15 | 1.013 | |
| 323.2 | 50 | 25.91 | 0.09327 | 338.7 | 150 | 30.34 | 1.092 | |
| 348.2 | 75 | 29.61 | 0.1066 | 366.5 | 200 | 34.92 | 1.257 | |
| 373.2 | 100 | 33.49 | 0.1206 | 394.3 | 250 | 39.71 | 1.430 | |
| 398.2 | 125 | 37.53 | 0.1351 | 422.0 | 300 | 44.71 | 1.610 | |
| 423.2 | 150 | 41.73 | 0.1502 | 449.8 | 350 | 49.91 | 1.797 | |
| 448.2 | 175 | 46.07 | 0.1659 | 477.6 | 400 | 55.30 | 1.991 | |
| 473.2 | 200 | 50.56 | 0.1820 | 505.4 | 450 | 60.86 | 2.191 | |
| 523.2 | 250 | 59.93 | 0.2157 | 533.2 | 500 | 66.59 | 2.397 | |
| 573.2 | 300 | 69.79 | 0.2512 | 588.7 | 600 | 78.52 | 2.827 | |
Air thermal diffusivity at given temperatures and 1, 5, 10 and 20 bara presure:
| Temperature | Thermal diffusivity at given pressures (×10-6 m2/s ) | |||||
| (K) | (°C) | (°F) | 1 bara, 14.5 psia | 5 bara, 72.5 psia | 10 bara, 145 psia | 20 bara, 145 psia |
| 60 | -213 | -352 | 0.0941 | 0.0942 | 0.0944 | 0.0947 |
| 80 | -193 | -316 | 1.59 | 0.0823 | 0.0826 | 0.0834 |
| 100 | -173 | -280 | 2.56 | 0.408 | 0.0643 | 0.0659 |
| 120 | -153 | -244 | 3.79 | 0.684 | 0.293 | 0.0814 |
| 140 | -133 | -208 | 5.21 | 0.983 | 0.455 | 0.189 |
| 180 | -93.2 | -136 | 8.58 | 1.68 | 0.815 | 0.385 |
| 200 | -73.2 | -99.7 | 10.5 | 2.07 | 1.02 | 0.490 |
| 220 | -53.2 | -63.7 | 12.6 | 2.50 | 1.23 | 0.602 |
| 240 | -33.2 | -27.7 | 14.9 | 2.96 | 1.46 | 0.721 |
| 260 | -13.2 | 8.3 | 17.3 | 3.44 | 1.67 | 0.847 |
| 273.2 | 0.0 | 32.0 | 19.0 | 3.78 | 1.86 | 0.940 |
| 280 | 6.9 | 44.3 | 19.9 | 3.96 | 1.97 | 0.979 |
| 288.7 | 15.6 | 60.0 | 21.0 | 4.20 | 2.10 | 1.05 |
| 300 | 26.9 | 80.3 | 22.6 | 4.50 | 2.25 | 1.12 |
| 320 | 46.9 | 116 | 25.4 | 5.07 | 2.53 | 1.26 |
| 340 | 66.9 | 152 | 28.3 | 5.67 | 2.83 | 1.41 |
| 360 | 86.9 | 188 | 31.4 | 6.28 | 3.14 | 1.57 |
| 380 | 107 | 224 | 34.6 | 6.92 | 3.46 | 1.73 |
| 400 | 127 | 260 | 37.9 | 7.58 | 3.79 | 1.90 |
| 500 | 227 | 440 | 55.7 | 11.2 | 5.59 | 2.80 |
| 600 | 327 | 620 | 75.4 | 15.1 | 7.57 | 3.80 |
| 700 | 427 | 800 | 96.8 | 19.4 | 9.71 | 4.88 |
| 800 | 527 | 980 | 119.7 | 24.0 | 12.0 | 6.03 |
| 900 | 627 | 1160 | 144.2 | 28.9 | 14.5 | 7.26 |
| 1000 | 727 | 1340 | 169.6 | 34.1 | 17.1 | 8.57 |
| 1100 | 827 | 1520 | 198.1 | 19.9 | ||
| 1500 | 1227 | 2240 | 326.7 | 32.7 | ||
| 1900 | 1627 | 2960 | 483.7 | 48.5 | ||
• Air Psychrometrics
• Gases and Compressed Air
Air - Humidity Ratio
Air - Prandtl Number
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Air Conditioning - Cooling of Air and Condensate Generated
Water may condensate when air is cooled in air conditioning systems.
Air Properties - SI Units
Ideal gas properties of air at low pressure - SI units.
Air Properties: Temperature, Pressure & Density Data
Pressure loss in compressed air pipe lines.
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Moist Air - Properties
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Moist Air - Weight of Water Vapor
Weight of water vapor in air
Nitrogen - Thermal Diffusivity vs. Temperature and Pressure
Figures and tables showing thermal diffusivity of nitrogen at varying temperarure and pressure, SI and Imperial units.
Solubility of Air in Water
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
Specific Heat Capacity of Air: Isobaric and Isochoric Heat Capacities at Various Temperatures and Pressures
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
