μ = absolute or dynamic viscosity [kg/(m s)], [lb m /(ft h)]
c p = specific heat [J/(kg K)], [Btu/(lb m o F)]
k = thermal conductivity [W/(m K)], [Btu/(h ft 2 o F/ft)]
Below, Prandtl numbers for air at varying temperatures and pressures are given in figures and tables .
See also other properties of Air at varying temperature and pressure: Density and specific weight at varying temperature , Density at varying pressure , Diffusion Coefficients for Gases in Air , Specific heat at varying temperature and Specific heat at varying pressure , Thermal Conductivity , Thermal Diffusivity , Properties at gas-liquid equilibrium conditions and Air thermophysical properties at standard conditions and Composition and molecular weight ,
as well as Prandtl number of Ammonia , Carbon dioxide , Methane , Nitrogen , Propane and Water .
Air Prandtl number at 1 bara pressure, temperature given as °C or °F:
Air Prandtl number at varying temperatures and constant pressures, SI and Imperial units:
Temperature | Pr | Temperature | Pr |
[°C] | [-] | [°F] | [-] |
-100 | 0.734 | -150 | 0.733 |
-50 | 0.720 | -50 | 0.719 |
0 | 0.711 | 0 | 0.714 |
25 | 0.707 | 60 | 0.709 |
50 | 0.705 | 75 | 0.708 |
100 | 0.701 | 100 | 0.706 |
150 | 0.699 | 200 | 0.701 |
200 | 0.698 | 300 | 0.699 |
250 | 0.699 | 400 | 0.698 |
300 | 0.702 | 500 | 0.700 |
Air Prandtl number at given temperatures and 1, 5 10 and 20 bara pressure:
Temperature | Prandtl number at given pressures | |||||
[K] | [°C] | [°F] | 1 bara, 14.5 psia | 5 bara, 72.5 psia | 10 bara, 145 psia | 20 bara, 725 psia |
60 | -213.2 | -351.7 | 4.138 | 4.153 | 4.170 | 4.187 |
80 | -193.2 | -315.7 | 1.7 | 2.252 | 2.259 | 2.269 |
100 | -173.2 | -279.7 | 0.780 | 0.898 | 1.783 | 1.770 |
120 | -153.2 | -243.7 | 0.759 | 0.806 | 0.890 | 1.360 |
140 | -133.2 | -207.7 | 0.747 | 0.773 | 0.812 | 0.923 |
180 | -93.2 | -135.7 | 0.731 | 0.743 | 0.759 | 0.792 |
200 | -73.2 | -99.7 | 0.726 | 0.735 | 0.745 | 0.769 |
220 | -53.2 | -63.7 | 0.721 | 0.728 | 0.736 | 0.754 |
240 | -33.2 | -27.7 | 0.717 | 0.722 | 0.729 | 0.742 |
260 | -13.2 | 8.3 | 0.713 | 0.718 | 0.723 | 0.734 |
273 | 0.0 | 32.0 | 0.711 | 0.715 | 0.720 | 0.729 |
280 | 6.9 | 44.3 | 0.710 | 0.714 | 0.718 | 0.727 |
289 | 15.6 | 60.0 | 0.709 | 0.713 | 0.716 | 0.723 |
300 | 26.9 | 80.3 | 0.707 | 0.711 | 0.714 | 0.722 |
320 | 46.9 | 116.3 | 0.705 | 0.708 | 0.711 | 0.717 |
340 | 66.9 | 152.3 | 0.703 | 0.705 | 0.708 | 0.714 |
360 | 86.9 | 188.3 | 0.701 | 0.703 | 0.706 | 0.711 |
380 | 106.9 | 224.3 | 0.700 | 0.702 | 0.704 | 0.709 |
400 | 126.9 | 260.3 | 0.699 | 0.701 | 0.703 | 0.706 |
500 | 226.9 | 440.3 | 0.698 | 0.700 | 0.701 | 0.703 |
600 | 326.9 | 620.3 | 0.703 | 0.704 | 0.704 | 0.706 |
700 | 426.9 | 800.3 | 0.710 | 0.710 | 0.711 | 0.712 |
800 | 526.9 | 980.3 | 0.717 | 0.718 | 0.718 | 0.719 |
900 | 626.9 | 1160.3 | 0.724 | 0.725 | 0.725 | 0.725 |
1000 | 726.9 | 1340.3 | 0.730 | 0.730 | 0.730 | 0.731 |
1100 | 826.9 | 1520.3 | 0.734 | 0.735 | ||
1500 | 1226.9 | 2240.3 | 0.743 | 0.743 | ||
1900 | 1626.9 | 2960.3 | 0.742 | 0.742 |
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Thermal properties of air at different temperatures - density, viscosity, critical temperature and pressure, triple point, enthalpi and entropi, thermal conductivity and diffusivity and more.
Water may condensate when air is cooled in air conditioning systems.
Ideal gas properties of air at low pressure - SI units.
Pressure loss in compressed air pipe lines.
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Weight of water vapor in air
Maximum distance between PolyPropylene pipes supports.
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
