Absolute humidity is the actual mass of water vapor present in the air water vapor mixture.
Thermodynamic properties of dry air - specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Chemical, Physical and Thermal Properties of Helium - He.
The pressure in a mixture of dry air and water vapor - humid or moist air - can be estimated by using Daltons Law of partial pressures.
Humidity ratio of moist air to humidity ratio of saturated moist air.
Density of moist air vs. pressure ranging 75 - 1000 mmHg.
Dry and wet bulb temperatures, saturation pressure, water vapor weight, specific volume, heat and more.
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Specific humidity of moist air vs. relative humidity, water vapor and air density.
