Piping Systems
American vs. British Piping Standards
US American (ASTM) vs. British (BSi) piping standards - specifications, grades and material descriptions.
ANSI Schedule 40 Steel Pipes - Dimensions
ANSI Schedule 80 Steel Pipes - Dimensions
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipes - Dimensions
ASTM Cross Reference Material Specifications
Cross reference for fittings, flanges, unions and cast and foged valves.
Ball Valves - Flow Coefficients Cv
Flow coefficients - Cv - for typical ball valves - reduced and full bore.
Boiling Fluids - Max Suction Flow Velocities
Recommended max suction flow velocity when pumping boiling fluids.
Boiling Liquids - Max Pumping Flow Velocities
Recommended max flow velocity on the delivery (pressure) side when pumping boiling liquids.
Bronze Flanges - ASME/ANSI 150 lb
Flange diameters, thickness, bolt circles, numbers and diameters of bolts for ASME/ANSI B16.15 - Cast Bronze Threaded Fittings - 150 lb Bronze flanges with plain faces.
Butterfly Valves - Flow Coefficients Cv
Typical flow coefficients - Cv - for butterfly valves.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 1500
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 1500 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 2500
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 2500 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 300
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 300 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 400
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 400 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 600
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 600 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 900
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 900 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon Steel Flanges - Pressure and Temperature Ratings
Maximum ratings for flanges conforming to ISO Standard 2229 dimensions and material specification AST-A-105.
Carbon Steel Pipes - Comparing American & European Standards
Comparing standards of carbon steel pipes from USA, Germany, UK and Sweden.
Cast Iron
The four basic types of cast iron - white iron, gray iron, ductile iron and malleable iron.
Cast Iron Flanges - ASME/ANSI Class 125
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 125 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Cast Iron Flanges - ASME/ANSI Class 25
ASME/ANSI B16.1 - 1998 - Cast Iron Pipe Flanges and Flanged Fittings - Class 25 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Cast Iron Flanges - ASME/ANSI Class 250
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 250 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Content in Horizontal - or Sloped - Cylindrical Tanks or Pipes
Volume of partly filled horizontal or sloped cylindrical tanks or pipes - online calculator.
Cooling Water - Pipe Lines
Sizing cooling water pipe lines - maximum allowable flow, velocity and pressure drops.
Copper Tubes - Heat Losses
Heat loss from uninsulated copper tubes vs. temperature differences between tube and air.
Diaphragm Valves - Diaphragm Materials
Common diaphragm materials and their main properties when used in diaphragm valves.
Download ANSI, American National Standards Institute, Standards
ANSI is a private, not-for-profit, membership organization that acts not as a standards developer, but as a standards coordinating and approval body.
Firefighting Water - Required Volume Flow
Required water for firefighting.
Flow Coefficient Cv vs. Flow Factor Kv
Comparing flow coefficients Cv to flow factors Kv.
Gasket Characteristics
Gaskets are used to make a fluid or gas resistant seal between two surfaces.
Horizontal Pipe Hanger Supports - Spacing and Rod Size
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
Ice Loaded Pipelines
Ice coat weigth on horizontal pipe lines.
Incompressible Flow Calculator
Pipe rating for single phase incompressible flow.
Insulated Copper Tubes - Heat Loss
Heat loss to surrounding air from insulated copper tubes.
Light Oil Pumping - Flow Velocities
Recommended max. flow velocities on the delivery side when pumping light oils.
Light Oil Suction - Flow Velocities
Recommended max. suction flow velocities when pumping light oils.
NDT - Non Destructive Testing
Non-destructive construction testing.
NPS - 'Nominal Pipe Size' and DN - 'Diametre Nominal'
The size of pipes, fittings, flanges and valves are often given in inches as NPS - Nominal Pipe Size, or in metric units as DN - 'Diametre Nominal'.
Draw P&ID diagrams online in the browser with Google Docs.
Pipes - Fractional Equivalents
Fractional vs. decimal inches.
Pipes - Relative Capacity
Relative capacity between larger and smaller pipes.
Pneumatic Powder and Solid Transport Systems
Pneumatic transport systems used to move powder and other solid products.
Pneumatic Transport - Solids and Particle Size
Particle sizes for common products like coal, sand, ash and more.
Pneumatic Transport and Conveying - Carrying Velocities
Recommended air velocity for pneumatic transport of products like cement, coal, flour and more.
Pneumatics - Transport of Solids and Separator Types
Separators used in pneumatic solids transport systems and their minimum particle size.
Reynolds Number
Slurry Transports - Minimum Flow Velocities
Flow velocities in slurry transport systems to avoid settling of solids.
Stainless Steel Pipes - American vs. European Standards
American - US - vs. European - German, British (UK) and Swedish - stainless steel pipe standards.
Steel Pipes - Heat Loss Diagram
Heat loss from steel pipes and tubes - dimensions 1/2 to 12 inches.
Steel Pipes Schedule 40 - Pressure Loss
Water flow and pressure loss in schedule 40 steel pipes - Imperial and SI units - gallons per minute, liters per second and cubic meters per hour.
Straight Through Diaphragm Valves - Flow Coefficients
Flow coefficients - Cv - and flow factors - Kv - for straight through diaphragm valves.
Thermoplastic Pipes - Supporting Distances vs. Temperature
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
Threaded & Socket Welded Steel Fittings - Pressure Classes vs. Schedules
Pressure classes, schedules and weights of pipes for threaded & socket welded fittings.
Valve Selection Guide
Applications guide for selecting valves.
Valve Type Classifications
Categories of valves.
Valves - Specific Services
Valves - Typical Operating Temperatures
Operating temperatures for typical categories of valves - ball valves, butterfly valves and more.
Valves Types - Operating Size Ranges
Types of valves and their typical operating sizes.
Viscous Liquids - Max. Delivery Flow Velocities
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
Viscous Liquids - Max. Suction Flow Velocities
Recommended max. pump suction flow velocity for viscous fluids.
Volume in Horizontal Pipes or Cylindrical Tanks
Liquid content in partly filled horizontal pipes or tanks.
Water - Max. Suction Flow Velocities vs. Pipe Size
Recommended max. water flow velocities on suction sides of pumps.
Water Flow - Max. Delivery Velocities vs. Pipe Size
Recommended maximum flow velocities in water systems on the delivery side of the pump.
Weir Diaphragm Valves - Flow Coefficients and Flow Factors
Typical flow coefficients - Cv - and flow factors - Kv - for weir diaphragm valves.
• Codes and Standards
• Corrosion
• Design Strategies
Piping systems design strategies - documentation, P&ID, flow diagrams - capacities and limits.
• Dimensions
• Fluid Flow and Pressure Loss
• Heat Loss and Insulation
Heat loss from pipes, tubes and tanks - with and without insulation - foam, fiberglass, rockwool and more.
• Pressure Ratings
• Temperature Expansion
Thermal expansion of pipes and tubes - stainless steel, carbon steel, copper, plastics and more.
• Valve Standards
International standards for valves in piping systems.
