Copper Tubes - Heat Losses
Values from the table below can be used to indicate the heat losses from uninsulated copper pipes:
Nominal bore | Heat Loss | ||||||
(W/m) | (Btu/hr ft) | ||||||
Temperature difference (oC) | Temperature difference (oF) | ||||||
(mm) | (inches) | 22 | 38 | 55 | 40 | 68 | 99 |
15 | 1/2 | 21 | 32 | 45 | 22 | 34 | 47 |
22 | 3/4 | 28 | 43 | 60 | 29 | 45 | 53 |
28 | 1 | 34 | 53 | 76 | 36 | 56 | 79 |
35 | 1 1/4 | 41 | 64 | 89 | 43 | 67 | 93 |
42 | 1 1/2 | 47 | 74 | 104 | 49 | 77 | 108 |
54 | 2 | 59 | 93 | 131 | 62 | 97 | 136 |
67 | 2 1/2 | 71 | 111 | 156 | 74 | 116 | 162 |
76 | 3 | 83 | 129 | 181 | 87 | 135 | 189 |
108 | 4 | 107 | 165 | 232 | 111 | 172 | 241 |
- 1 W = 3.4 Btu/hr
- 1 ft (foot) = 0.3048 m
• Heat Loss and Insulation
• Insulation and Heat Loss from Steam and Condesate Pipe Lines
Heat loss from uninsulated and insulated steam and condensate pipes and tanks. Calculate insulation thicknesses.
• Piping Systems
• Water Systems
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Copper Tubes - Heat Carrying Capacities
Hot water heat carrying capacities in copper tubes type L.
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes ASTM B 88 type K.
Insulated Copper Tubes - Heat Loss
Heat loss to surrounding air from insulated copper tubes.
Pipes - Bare Surface Heat Loss
Heat loss vs. surface temperature.
Pipes - Insulated Heat Loss Diagrams
Heat loss (W/m) from 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 10 to 80 mm and temperature differences 20 to 180 degC.
Heat loss (W/ft) diagrams for 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 0.5 to 4 inches and temperature differences 50 to 350 degF.
Pipes and Cylinders - Conductive Heat Loss
Conductive heat losses through cylinder or pipe walls.
Piping - Recommended Insulation Thickness
Recommended insulation thickness for heating systems like hot water and low, medium or high pressure steam systems.
Steam Pipes - Heat Losses
The amount of condensate generated in a steam pipe depends on the heat loss from the pipe to the surroundings.
Steam Pipes - Heat Losses (W/m)
Heat losses from un-insulated steam pipes.
Steel Pipes - Heat Loss Diagram
Heat loss from steel pipes and tubes - dimensions 1/2 to 12 inches.
