Steam Pipes - Heat Losses
The heat loss is a function of the pipe size and insulation quality, the steam temperature (pressure) and the surrounding temperature.
Download and print Steam Pipe Heat Loss diagram
The table below and figure above can be used for estimating heat loss from bare uninsulated horizontal steam pipes - still air conditions - air temperature ranging 50 oF to 70 oF.
Difference between Steam Temperature and Surrounding Air Temperature (oF) | Heat Loss (Btu/h per ft) | |||||||||
Dimension (inches) | ||||||||||
1/2 | 3/4 | 1 | 1 1/4 | 1 1/2 | 2 | 2 1/2 | 3 | 4 | 6 | |
100 | 56 | 68 | 82 | 107 | 113 | 138 | 163 | 194 | 243 | 337 |
120 | 71 | 85 | 104 | 127 | 142 | 175 | 206 | 246 | 308 | 427 |
140 | 86 | 104 | 127 | 155 | 173 | 212 | 251 | 300 | 375 | 521 |
160 | 103 | 125 | 152 | 186 | 213 | 256 | 301 | 360 | 451 | 626 |
180 | 121 | 146 | 176 | 217 | 243 | 297 | 351 | 417 | 522 | 725 |
200 | 139 | 171 | 206 | 251 | 282 | 346 | 408 | 488 | 622 | 850 |
225 | 166 | 199 | 243 | 297 | 334 | 410 | 483 | 578 | 726 | 1009 |
250 | 192 | 233 | 284 | 347 | 389 | 478 | 563 | 674 | 849 | 1180 |
275 | 220 | 266 | 326 | 398 | 447 | 550 | 649 | 778 | 978 | 1360 |
300 | 251 | 304 | 372 | 455 | 510 | 628 | 742 | 888 | 1140 | 1557 |
325 | 285 | 343 | 425 | 520 | 580 | 705 | 843 | 1010 | 1240 | 1730 |
350 | 322 | 388 | 480 | 590 | 660 | 790 | 945 | 1130 | 1358 | 1930 |
- 1 Btu/h per ft = 0.96 W/m
• Heat Loss and Insulation
• Insulation and Heat Loss from Steam and Condesate Pipe Lines
Heat loss from uninsulated and insulated steam and condensate pipes and tanks. Calculate insulation thicknesses.
• Steam and Condensate
Copper Tubes - Heat Losses
Heat loss from uninsulated copper tubes vs. temperature differences between tube and air.
Pipes - Bare Surface Heat Loss
Heat loss vs. surface temperature.
Pipes - Insulated Heat Loss Diagrams
Heat loss (W/m) from 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 10 to 80 mm and temperature differences 20 to 180 degC.
Heat loss (W/ft) diagrams for 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 0.5 to 4 inches and temperature differences 50 to 350 degF.
Pipes and Cylinders - Conductive Heat Loss
Conductive heat losses through cylinder or pipe walls.
Piping - Recommended Insulation Thickness
Recommended insulation thickness for heating systems like hot water and low, medium or high pressure steam systems.
Steam Pipes - Fuel Consumption due to Heat Losses over a Year
Yearly heat loss in amount of coal or oil consumption for insulated and uninsulated steam pipes at different dimensions and operation times.
The amount of condensate generated in a steam pipe depends on the heat loss from the pipe to the surroundings.
Steam Pipes - Heat Losses (W/m)
Heat losses from un-insulated steam pipes.
Steel Pipes - Heat Loss Diagram
Heat loss from steel pipes and tubes - dimensions 1/2 to 12 inches.
