Pipes - Insulated Heat Loss Diagrams
The heat loss diagrams below can be used to indicate the heat loss from insulated pipes at various temperature differences. The diagrams are based on
- metal pipes
- fiber glass insulation with thermal conductivity 0.036 W/(mK)
- outdoor condition with moderate wind 9 m/s
A safety factor of 10% is included.
- indoor location - reduce values with 10%
- mineral wool insulation - increase values with 6%
- rigid cellular polyurethane - reduce values by 30%
- Heat loss diagram (W/m)
Pipe Heat Loss - Insulation thickness 80 mm
- 1 W/m = 0.305 W/ft
- 1 oC = 1.8 oF
Example - Heat Loss from Insulated Pipe Line
100 m of steel pipe with nominal dimension 2 1/2 inches is insulated with 80 mm fiber glass insulation. The temperature of the fluid in the pipe is 90 oC and the ambient temperature outside the pipe is 10 oC.
From the diagram above - 80 mm fiber glass insulation, temperature difference 80 oC and pipe dimension 2 1/2" - the heat loss is approximately 20 W/m.
The heat loss from the whole pipe can be calculated as
(100 m) (20 W/m)
= 2000 W
Pipe Heat Loss - Insulation thickness 50 mm
Pipe Heat Loss - Insulation thickness 40 mm
Pipe Heat Loss - Insulation thickness 30 mm
Pipe Heat Loss - Insulation thickness 25 mm
Pipe Heat Loss - Insulation thickness 20 mm
Pipe Heat Loss - Insulation thickness 10 mm
• Heat Loss and Insulation
• Insulation
• Insulation and Heat Loss from Steam and Condesate Pipe Lines
Heat loss from uninsulated and insulated steam and condensate pipes and tanks. Calculate insulation thicknesses.
• Water Systems
Calcium Silicate Insulation
Thermal conductivity of calcium silicate insulation - temperature and k-values.
Copper Tubes - Heat Losses
Heat loss from uninsulated copper tubes vs. temperature differences between tube and air.
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Fiberglass Insulation
Thermal conductivity of fiberglass insulation - temperature and k-values.
Heat Loss from Oil Filled Tanks and Pipe Lines
Heat loss from insulated and non insulated sheltered and exposed oil tanks and pipes.
Heat Traced Pipes - Wrapping Factor
Wrapping factor when the heat loss from a pipe or tube is higher than the capacity of the heat trace cable.
Hot Water Circulation System - Return Pipes
Hot water can be circulated through a return pipe if it's instantly required at the fixtures.
Insulated Copper Tubes - Heat Loss
Heat loss to surrounding air from insulated copper tubes.
Mineral Wool Insulation
Oil Filled Tanks - Heat Loss
Heat loss from insulated and uninsulated, sheltered and exposed heated oil tanks.
Heat loss (W/ft) diagrams for 1/2 to 6 inches insulated pipes - ranging insulation thickness 0.5 to 4 inches and temperature differences 50 to 350 degF.
Pipes and Cylinders - Conductive Heat Loss
Conductive heat losses through cylinder or pipe walls.
Polyurethane Insulation
Steam Pipes - Heat Losses
The amount of condensate generated in a steam pipe depends on the heat loss from the pipe to the surroundings.
Steam Pipes - Heat Losses (W/m)
Heat losses from un-insulated steam pipes.
Steam Tracing Pipe Lines
Steam tracing of pipe lines can be done to maintain appropriate product temperatures.
Steel Pipes - Heat Loss Diagram
Heat loss from steel pipes and tubes - dimensions 1/2 to 12 inches.
