Polyurethane Insulation
Polyurethane is an organic polymer formed by reacting a polyol (an alcohol with more than two reactive hydroxyl groups per molecule) with a diisocyanate or a polymeric isocyanate in the presence of suitable catalysts and additives.
Polyurethanes are flexible foams used in mattresses, chemical-resistant coatings, adhesives and sealants, insulation for buildings and technical applications like heat exchangers, cooling pipes and much more.
Thermal conductivity vs. temperature are indicated in the charts below:
- T (oC) = 5/9 (T (oF) - 32)
- 1 W/(m K) = 6.935 (Btu in)/(h ft² °F)
• Heat Loss and Insulation
• Insulation
Calcium Silicate Insulation
Thermal conductivity of calcium silicate insulation - temperature and k-values.
Fiberglass Insulation
Thermal conductivity of fiberglass insulation - temperature and k-values.
Heat Transmission Loss through Building Elements
Heat loss through common building elements due to transmission, R-values and U-values - imperial and SI units.
Insulation Materials - Operating Temperature Limits
Temperature limits for commonly used insulation materials.
Mineral Wool Insulation
Perlite Insulation
Pipes - Insulated Heat Loss Diagrams
Heat loss (W/m) from 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 10 to 80 mm and temperature differences 20 to 180 degC.
Heat loss (W/ft) diagrams for 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 0.5 to 4 inches and temperature differences 50 to 350 degF.
Piping - Recommended Insulation Thickness
Recommended insulation thickness for heating systems like hot water and low, medium or high pressure steam systems.
Polyurethane - Chemical Resistance
Chemical resistance of Polyurethane (PUR).
Steel Pipes - Heat Loss Diagram
Heat loss from steel pipes and tubes - dimensions 1/2 to 12 inches.
