Calcium Silicate Insulation
Calcium silicate is used as a safe alternative to asbestos for high temperature insulation materials.
Features of Calcium Silicate insulation board and pipe insulation are
- light weight
- low thermal conductivity
- high temperature and chemical resistance
Calcium Silicate is a rigid, high density material suitable for high temperature applications ranging 250 oF (121 oC) - 1000 oF (540 oC).
Calcium Silicate thermal conductivity related to temperature are indicated in the charts below:
- compressive strength is good
- noncombustible
- T (oC) = 5/9 (T (oF) - 32)
- 1 W/(m K) = 6.935 (Btu in)/(h ft² °F)
• Insulation
Fiberglass Insulation
Thermal conductivity of fiberglass insulation - temperature and k-values.
Insulation Materials - Operating Temperature Limits
Temperature limits for commonly used insulation materials.
Mineral Wool Insulation
Orifices - Natural Gas Capacity
Capacity of natural gas orifices.
Perlite Insulation
Pipes - Insulated Heat Loss Diagrams
Heat loss (W/m) from 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 10 to 80 mm and temperature differences 20 to 180 degC.
Heat loss (W/ft) diagrams for 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 0.5 to 4 inches and temperature differences 50 to 350 degF.
Piping - Recommended Insulation Thickness
Recommended insulation thickness for heating systems like hot water and low, medium or high pressure steam systems.
Polyurethane Insulation
Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
Thermal Conductivity Units Converter
