Fiberglass Insulation
Fiberglass is made of molten glass spun into micro fibers and is one of the most common types of insulation used.
Fiberglass thermal conductivity vs. temperature are indicated in the charts below:
- T(oC) = 5/9[T(oF) - 32]
- 1 W/(m K) = 6.935 (Btu in)/(h ft² °F)
• Insulation
Heat transfer and heat loss from buildings and technical applications - heat transfer coefficients and insulation methods to reduce energy consumption.
Calcium Silicate Insulation
Thermal conductivity of calcium silicate insulation - temperature and k-values.
Insulation Materials - Operating Temperature Limits
Temperature limits for commonly used insulation materials.
Mineral Wool Insulation
Perlite Insulation
Pipes - Insulated Heat Loss Diagrams
Heat loss (W/m) from 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 10 to 80 mm and temperature differences 20 to 180 degC.
Polyurethane Insulation
