Insulation Materials - Operating Temperature Limits
Temperature limits for some commonly used insulation materials:
Insulation MaterialTemperature Range
LowHigh
(oC)(oF)(oC)(oF)
Calcium Silicate -18 0 650 1200
Cellular Glass -260 -450 480 900
Elastomeric foam -55 -70 120 250
Fiberglass -30 -20 540 1000
Mineral Wool, Ceramic fiber 1200 2200
Mineral Wool, Glass 0 32 250 480
Mineral Wool, Stone 0 32 760 1400
Phenolic foam     150 300
Polyisocyanurate, polyiso -180 -290 120 250
Polystyrene -50 -60 75 165
Polyurethane -210 -350 120 250
Vermiculite -272 -459 760 1400
Calcium Silicate Insulation
Non-asbestos Calcium Silicate insulation board and pipe insulation feature with light weight, low thermal conductivity, high temperature and chemical resistance.
Cellular Glass Insulation
Cellular glass insulation is composed of crushed glass combined with a cellulating agent.
These components are mixed, placed in a mold, and then heated to a temperature of approximately 950 oF. During the heating process, the crushed glass turns to a liquid. Decomposition of the cellulating agent will cause the mixture to expand and fill the mold. The mixture creates millions of connected, uniform, closed-cells and form at the end a rigid insulating material.
Cellulose Insulation
Cellulose is made from shredded recycled paper, such as newsprint or cardboard. It's treated with chemicals to make it fire- and insect-resistant, and is applied as loose-fill or wet-sprayed through a machine.
Fiberglass Insulation
Fiberglass is the most common type of insulation. It's made from molten glass spun into microfibers.
Mineral Wool Insulation
Mineral wool is made from molten glass, stone, ceramic fibre or slag that is spun into a fiber-like structure. Inorganic rock or slag are the main components (typically 98%) of stone wool. The remaining 2% organic content is generally a thermosetting resin binder (an adhesive) and a little oil.
Polyurethane insulation
Polyurethane is an organic polymer formed by reacting a polyol (an alcohol with more than two reactive hydroxyl groups per molecule) with a diisocyanate or a polymeric isocyanate in the presence of suitable catalysts and additives.
Polyurethanes are flexible foams used in mattresses, chemical-resistant coatings, adhesives and sealants, insulation for buildings and technical applications like heat exchangers, cooling pipes and much more.
Polystyrene Insulation
Polystyrene is an excellent insulator. It is manufactured in two ways:
  • Extrusion - which results in fine, closed cells, containing a mixture of air and refrigerant gas
  • Molded or expanded - which produces coarse, closed cells containing air
Extruded polystyrene, or XPS, is a closed-cell, thermal plastic material manufactured by a variety of extrusion processes. The main applications of extruded polystyrene insulation are in building insulation and construction in general.
Molded or expanded polystyrene is commonly called beadboard and has a lower R-value than extruded polystyrene.
Polyisocyanurate (polyiso) Insulation
Polyisocyanurate or polyiso is a thermosetting type of plastic, a closed-cell foam that contains a low-conductivity gas in its cells.
Heat Loss and Insulation
Insulation
Insulation and Heat Loss from Steam and Condesate Pipe Lines
Heat loss from uninsulated and insulated steam and condensate pipes and tanks. Calculate insulation thicknesses.
Thermal conductivity of calcium silicate insulation - temperature and k-values.
Clo - Clothing and Thermal Insulation
Clo is used as a measure of clothes thermal insulation.
Conductive Heat Transfer
Duct Wrap Insulation - Thermal Resistance
Heat flow thermal resistance of unfaced and faced duct wrap insulation.
Thermal conductivity of fiberglass insulation - temperature and k-values.
Insulated Copper Tubes - Heat Loss
Heat loss to surrounding air from insulated copper tubes.
Insulation of Cooling Systems
Cooling systems and insulation thickness.
Perlite Insulation
Piping - Recommended Insulation Thickness
Recommended insulation thickness for heating systems like hot water and low, medium or high pressure steam systems.
Polyurethane Insulation
Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
