Piping - Recommended Insulation Thickness
To avoid heat loss and reduced system efficiency - pipe work in heating systems should always be insulated. Very hot systems, like hot water and steam systems should also be insulated to avoid potential personal injuries.
The table below indicates recommended insulation thickness.
| Nominal Pipe Size NPS (inches) | Insulation Thickness (inches)* | |||
| Temperature Range (oC) | ||||
| 50 - 90 | 90 - 120 | 120 - 150 | 150 - 230 | |
| Temperature Range (oF) | ||||
| 120 - 200 | 201 - 250 | 251 - 305 | 306 - 450 | |
| Hot Water | Low Pressure Steam | Medium Pressure Steam | High Pressure Steam | |
| < 1" | 1.0 | 1.5 | 2.0 | 2.5 |
| 1 1/4" - 2" | 1.0 | 1.5 | 2.5 | 2.5 |
| 2 1/2" - 4" | 1.5 | 2.0 | 2.5 | 3.0 |
| 5" - 6" | 1.5 | 2.0 | 3.0 | 3.5 |
| > 8" | 1.5 | 2.0 | 3.0 | 3.5 |
* based on insulation with thermal resistivity in the range 4 - 4.6 ft2 hr oF/ Btu in (typical for mineral wool at room temperature)
- 1 inch = 25.4 mm
• Heat Loss and Insulation
• Insulation
Calcium Silicate Insulation
Thermal conductivity of calcium silicate insulation - temperature and k-values.
Copper Tubes - Heat Losses
Heat loss from uninsulated copper tubes vs. temperature differences between tube and air.
Hot Water Heating System Online Design Application
Insulated Steam Pipes - Condensate Generated
Heat loss from steam pipes generates condensate which must be drained from the system - imperial units.
Insulation Materials - Operating Temperature Limits
Temperature limits for commonly used insulation materials.
Mineral Wool Insulation
Perlite Insulation
Pipes and Cylinders - Conductive Heat Loss
Conductive heat losses through cylinder or pipe walls.
Polyurethane Insulation
Steam Pipes - Heat Losses
The amount of condensate generated in a steam pipe depends on the heat loss from the pipe to the surroundings.
Steam Pipes - Heat Losses (W/m)
Heat losses from un-insulated steam pipes.
