Perlite Insulation
Perlite is a type of volcanic glass that expands four to twenty times its original volume and becomes porous when heated. Perlite is suitable in high temperature applications.
Thermal conductivity vs. temperature are indicated in the charts below:
  • tC = 5/9 (tF - 32)
  • 1 W/(m K) = 6.935 (Btu in)/(h ft² °F)
  • Refractive Index : 1.5
  • Free Moisture : maximum 0.5%
  • pH (of water slurry) : 6.5 - 8.0
  • Specific Gravity : 2.2 - 2.4
  • Bulk Density (loose weight) : depending on the expansion process but usually in the 2-25 lb/ft3 range (32-400 kg/m3)
  • Softening Point : 1600 - 2000 oF (871 - 1093 oC)
  • Fusion Point :  2300 - 2450 oF (1260 - 1343 oC)
  • Specific Heat : 0.2 Btu/lboF (387 J/kgK)
Heat Loss and Insulation
Insulation
Insulation and Heat Loss from Steam and Condesate Pipe Lines
Heat loss from uninsulated and insulated steam and condensate pipes and tanks. Calculate insulation thicknesses.
Calcium Silicate Insulation
Thermal conductivity of calcium silicate insulation - temperature and k-values.
Fiberglass Insulation
Thermal conductivity of fiberglass insulation - temperature and k-values.
Insulation Materials - Operating Temperature Limits
Temperature limits for commonly used insulation materials.
Mineral Wool Insulation
Piping - Recommended Insulation Thickness
Recommended insulation thickness for heating systems like hot water and low, medium or high pressure steam systems.
Polyurethane Insulation
Porosity
Volume not occupied by solid material.
