Water Systems
Hot and cold water service systems - design properties, capacities, sizing and more.
Butterfly Valves - Sizing and Selection
Selecting and sizing butterfly valves for water applications.
Centrifugal Pumps - Capacity Modulation
Modulating pumps to adapt capacities to variable process demands.
Cold Water Dwelling Storage Capacity
Required cold water dwelling storage capacity - commonly used fixtures and types of buildings.
Cold Water Storage per Occupant
Cold water storage for occupants in common types of buildings as factories, hospitals, houses and more
Copper Tubes - Heat Losses
Heat loss from uninsulated copper tubes vs. temperature differences between tube and air.
Copper Tubes - Maximum Water Velocities
Water velocity in a copper tube should not exceed certain limits to avoid erosion.
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Copper Tubes Type K, L and M - Working Pressures vs. Size
Domestic Hot Water Heaters - Sizing
Domestic Hot-Water sizing equations - heating capacity, recovery rate and power supply.
Domestic Hot Water Service Systems - Design Procedures
Design procedures for domestic hot water service systems.
Domestic Service Water Supply Systems
Introduction to general design of domestic service water supply systems - with pressurized or gravity tanks.
Domestic Water Supply - Lime Deposits
Lime deposited vs. temperature and water consumption.
Farm Livestock - Water Consumption
Farming and animals required water supply.
Fixtures Trap Sizes
Recommended drain trap sizes for different types of fixtures
Hose - Water Discharge Volume Flow vs. Pressure
Water discharge through hoses - pressure ranging 10 - 200 psi (0.75 - 14 bar).
Hot and Cold Water Pipe Sizing
Recommended dimensions hot and cold water pipes.
Hot Water Circulation System - Return Pipes
Hot water can be circulated through a return pipe if it's instantly required at the fixtures.
Hot Water Consumption per Occupant
Consumption of hot water per person or occupant.
Hot Water Content in Fixtures
Content of hot water in some common used fixtures - basins, sinks and baths.
Hot Water Storage Tanks - Capacities vs. Dimensions
Dimensions and capacities of hot-water storage tanks.
Hot Water Supply - Fixture Consumption
Design hot water consumption of fixtures - basins, showers, sinks and baths.
Hot Water Supply - Flow Rates to Fixtures
Hot water consumption of some common equipment as basins, sinks, baths and showers.
Impurities in Water Supply Systems
Typiclal limits for impurities in drinking water.
Insulated Copper Tubes - Heat Loss
Heat loss to surrounding air from insulated copper tubes.
Nozzles - Water Discharge Capacities
Discharge capacities of water nozzles.
Open Horizontal Pipes - Discharge Length vs. Volume Flow
Discharge length vs. volume flow from water filled horizontal pipes.
Draw P&ID diagrams online in the browser with Google Docs.
Pipes - Insulated Heat Loss Diagrams
Heat loss (W/m) from 1/2 to 6 inches insulated pipes - ranging insulation thickness 10 to 80 mm and temperature differences 20 to 180 oC.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow Diagrams
Friction loss (psi/100 ft) and velocity for water flow in plastic PVC pipe schedule 40.
Reynolds Number
Stainless Steel Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels.
Steel Pipe Flanges for Waterworks Services
Trap Size vs. Fixture Units
No. of fixture units and required trap size.
Vertical Pipes - Discharge Height vs. Volume Flow
Volume flow and discharge height from vertical water pipes.
Definitions, online calculator and figures and tables with water properties like density, specific weight and thermal expansion coefficient of liquid water at temperatures ranging 0 to 360°C (32 to 680°F).
Water - Dynamic (Absolute) and Kinematic Viscosity vs. Temperature and Pressure
Water - Heat of Vaporization vs. Temperature
Water - Human Activity and Consumption
Activity and average water consumption
Ionization constant (= dissociation constant = self-ionization constant = ion product = autoprotolysis constant ) of water and heavy water, given as function of temperature (°C and °F) in figures and tables.
Water - Max. Suction Flow Velocities vs. Pipe Size
Recommended max. water flow velocities on suction sides of pumps.
Water - Prandtl Number vs. Temperature and Pressure
Figures and tables with Prandtl Number of liquid and gaseous water at varying temperarure and pressure, SI and Imperial units.
Water - Saturation Pressure vs. Temperature
Water - Specific Heat vs. Temperature
Water Boiling Points at Higher Pressures
Water Control Valves - Kv Calculation
Designing water process control valves and their Kv values.
Water Distribution Pipes - Materials
Materials used in water distribution pipes.
Water Flow - Max. Delivery Velocities vs. Pipe Size
Recommended maximum flow velocities in water systems on the delivery side of the pump.
Water Hammer
Rapidly closing or opening valves - or starting stopping pumps - may cause pressure transients in pipelines known as surge or water hammers.
Water Service Pipe Lines
Water service pipe lines extends from the potable water source to the interior of buildings.
Water Supply - Calculating Demand
Calculating expected demand for water supply service lines.
Water Supply Fixture Units - WSFU vs. GPM and Liters/sec
Converting WSFU - Water Supply Fixture Units - to GPM.
Water Supply Lines - Sizing
Sizing water supply service and distribution lines based on Water Supply Fixture Units (WSFU).
Water Supply Public Buildings
Required water supply to public buildings.
Water Supply vs. Fixture Water Requirements
Supply requirements for common fixtures.
Water Systems - Maximum Flow Velocities
Water velocities in pipes and tubes should not exceed certain limits.
Yard Fixtures - Water Consumption
Water consumption in garden fixtures.
