Required Water Supply to Public Buildings
Typical required water supply to public buildings:
- 1 gpm =6.30888×10-5 m3/s = 0.227 m3/h
• Water Systems
Domestic Hot Water Service Systems - Design Procedures
Design procedures for domestic hot water service systems.
Domestic Service Water Supply Systems
Introduction to general design of domestic service water supply systems - with pressurized or gravity tanks.
Domestic Water Supply - Lime Deposits
Lime deposited vs. temperature and water consumption.
Fixture Water Consumption and Required Water Supply
Supply requirements for common fixtures.
Hot and Cold Water Pipes Sizing
Recommended dimensions hot and cold water pipes.
Calculating expected demand for water supply service lines.
Water Supply - Cross-Contamination Control
It is fundamental to keep the potable water in the water supply systems uncontaminated.
Water Supply Fixture Units - WSFU vs. GPM and Liters/sec
Converting WSFU - Water Supply Fixture Units - to GPM.
Water Supply Lines - Sizing
Sizing water supply service and distribution lines based on Water Supply Fixture Units (WSFU).
Water Supply Systems - Impurity Limits
Typiclal limits for impurities in drinking water.
