A water supply pipe line should be sized according expected demand and not the total theoretical demand from all fixtures at the same time. Due to intermittent use of the fixtures it may be difficult to predict a realistic demand but the values below are relevant for water supply lines in applications like homes, offices, nursing homes etc.
| Copper Pipe Size DN (mm) | Total Maximum Theoretical Demand Summarized (liter/s) | Maximum Expected Demand (liter/s) |
| 12 | 0.2 | 0.2 |
| 15 | 0.8 | 0.4 |
| 18 | 1.6 | 0.5 |
| 22 | 4.0 | 0.6 |
| 28 | 15 | 1.1 |
| 35 | 30 | 1.8 |
| 42 | 65 | 2.8 |
| 54 | 130 | 4.5 |
- 1 in = 25.4 mm
• Water Systems
ASTM B88M - Seamless Copper Water Tubes - Metric Dimensions
Water and gas copper tubes according ASTM B88M - type K, L and M - metric units.
Cold Water Dwellings - Storage Capacities
Required cold water dwelling storage capacity - commonly used fixtures and types of buildings.
Domestic Service Water Supply Systems
Introduction to general design of domestic service water supply systems - with pressurized or gravity tanks.
Domestic Water Supply - Lime Deposits
Lime deposited vs. temperature and water consumption.
Hot and Cold Water Pipes Sizing
Recommended dimensions hot and cold water pipes.
Required Water Supply to Public Buildings
Water consumption and supply to public buildings.
Water Distribution Pipes - Materials
Materials used in water distribution pipes.
Calculating expected demand for water supply service lines.
Water Supply - Cross-Contamination Control
It is fundamental to keep the potable water in the water supply systems uncontaminated.
Water Supply Fixture Units - WSFU vs. GPM and Liters/sec
Converting WSFU - Water Supply Fixture Units - to GPM.
Water Supply Lines - Sizing
Sizing water supply service and distribution lines based on Water Supply Fixture Units (WSFU).
Water Supply Systems - Impurity Limits
Typiclal limits for impurities in drinking water.
Water Systems - Maximum Flow Velocities
Water velocities in pipes and tubes should not exceed certain limits.
