Nominal Pipe Size
(in)
Outside Diameter
(in)
Wall Thickness
(in)
Inside Diameter
(in)
Working Pressure
(psi at 73 oF)
Weight
(lb/ft)
1/2 0.800 0.089 0.622 100 0.08
0.762 0.070 0.622 75 0.06
3/4 1.060 0.118 0.824 100 0.15
0.994 0.085 0.824 75 0.10
1 1.359 0.155 1.049 100 0.23
1.265 0.108 1.049 75 0.17
1 1/4 1.772 0.196 1.380 100 0.40
1.666 0.143 1.380 75 0.28
1 1/2 2.070 0.1230 1.610 100 0.55
1.942 0.166 1.610 75 0.39
2 2.657 0.295 2.067 100 0.90
2.495 0.214 2.067 75 0.64
  • PE - Polyethylene
Dimensions of Pipes and Tubes
Bending PE Pipes
Bending PE pipe calculator.
Domestic Service Water Supply Systems
Introduction to general design of domestic service water supply systems - with pressurized or gravity tanks.
ISO 4437 - PE Pipes for Gaseous Fuels Supply - Dimensions
Water Distribution Pipes - Materials
Materials used in water distribution pipes.
Water Service Pipe Lines
Water service pipe lines extends from the potable water source to the interior of buildings.
Calculating expected demand for water supply service lines.
Water Supply Lines - Sizing
Sizing water supply service and distribution lines based on Water Supply Fixture Units (WSFU).
Water Supply Public Buildings
Required water supply to public buildings.
Yard Fixtures - Water Consumption
Water consumption in garden fixtures.
