Water Service Pipe Lines
A "water-service" pipe line extends from the potable water source to the interior of a building. Inside the building the "water-service" pipe becomes a "water-distribution" pipe.
A water service pipe must be rated for the pressure produced by the water source and in the service line by pumps or static differences.
- it is common to rate water service lines for more than 160 psi (11 bar) and temperatures below aprox. 75 oF (25 oF)
Commonly used materials in water service pipe lines are
- Cast iron pipe (ductile pipe) - used in large water mains
- PE - Polyethylene
- PVC - Polyvinyl Chloride
- PB - Polybutylene
- Asbestos cement pipe
Other commonly approved and rarely used materials are
- ABS - Acrylonitrile Butadiene Styrene
- Brass pipe
- Copper tube - can be used as service lines without joints. Primarily used as water distribution pipes.
- CPVC - Chlorinated Polyvinyl Chloride
- Galvanized Steel
Water Service Pipes
Materials used in water service pipes according U.S. standards.
Piping Material | US Standards |
Acrylonitrile butadiene styrene (ABS) plastic pipe | ASTM D1527; ASTM D2282 |
Chlorinated polyvinyl chloride (CPVC) plastic pipe | ASTM D2846; ASTM F441; ASTM F442; CSA B137.6 |
Chlorinated polyvinyl chloride/aluminum/chlorinated polyvinyl chloride (CPVC/AL/CPVC) | ASTM F2855Copper or copper-alloy pipe ASTM B42; ASTM B302 |
Copper or copper-alloy tubing (Type K, WK, L, WL, M or WM) | ASTM B75; ASTM B88; ASTM B251; ASTM B447 |
Cross-linked polyethylene (PEX) plastic pipe and tubingASTM F876; | AWWA C904; CSA B137.5 |
Cross-linked polyethylene/aluminum/cross-linked polyethylene (PEX-AL-PEX) pipe | ASTM F1281; ASTM F2262; CSA B137.10 |
Cross-linked polyethylene/aluminum/high-density polyethylene (PEX-AL-HDPE) | ASTM F1986 |
Ductile iron water pipe | AWWA C151/A21.51; AWWA C115/A21.15 |
Galvanized steel pipe | ASTM A53 |
Polyethylene (PE) plastic pipe | ASTM D2239; ASTM D3035; AWWA C901; CSA B137.11 |
Polyethylene (PE) plastic tubing | ASTM D2737; AWWA C901; CSA B137.1 |
Polyethylene/aluminum/polethylene (PE-AL-PE) pipe | ASTM F1282; CSA B137.9 |
Polyethylene of raised temperature (PE-RT) plastic tubing | ASTM F2769; CSA B137.18 |
Polypropylene (PP) plastic pipe or tubing | ASTM F2389; CSA B137.11 |
Polyvinyl chloride (PVC) plastic pipe | ASTM D1785; ASTM D2241; ASTM D2672; CSA B137.3 |
Stainless steel pipe (Type 304/304L) | ASTM A312; ASTM A778 |
Stainless steel pipe (Type 316/316L) | ASTM A312; ASTM A778 |
• Water Systems
Domestic Service Water Supply Systems
Introduction to general design of domestic service water supply systems - with pressurized or gravity tanks.
Domestic Water Supply - Lime Deposits
Lime deposited vs. temperature and water consumption.
Hot and Cold Water Pipes Sizing
Recommended dimensions hot and cold water pipes.
Water Distribution Pipes - Materials
Materials used in water distribution pipes.
Calculating expected demand for water supply service lines.
Water Supply - Cross-Contamination Control
It is fundamental to keep the potable water in the water supply systems uncontaminated.
Water Supply Lines - Sizing
Sizing water supply service and distribution lines based on Water Supply Fixture Units (WSFU).
