This application can be used to design Water Supply Systems.
How to Use
- Make a sketch of your system - something similar to the default sketch below. Custom drawings can be linked to the application - any global (http://..) or local (file://..) url should work
- Tag the sections and add them to the hierarchical application structure below (modify or reset the default system)
- Add input data - flow, preliminary dimensions, lengths, elevations, minor coefficients and so on for each section
- Modify the dimensions to achieve reasonable values for velocities and pressure losses
- Save the data file to your computer/network
- dimensions, copper, pvc, pe
- minor loss coefficients, viscosity, density, roughness
• Water Systems
Hot and cold water service systems - design properties, capacities, sizing and more.
ASTM B88 - Seamless Copper Water Tubes - Dimensions
Dimensions of CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
ASTM F876 - PEX Tube - Dimensions
Dimensions of PEX tubes.
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
BS 7291 - Thermoplastics Pipes for Hot and Cold Water - Dimensions
Dimensions of thermoplastic pipes - PEX and PB according BS 7291.
Cold Water Dwelling Storage Capacity
Required cold water dwelling storage capacity - commonly used fixtures and types of buildings.
Cold Water Storage per Occupant
Cold water storage for occupants in common types of buildings as factories, hospitals, houses and more
Copper Tubes - Equivalent Length Pressure Loss in Fittings and Valves
Copper tube fittings and equivalent lengths - in feets of straight tube.
Copper Tubes - Maximum Water Velocities
Water velocity in a copper tube should not exceed certain limits to avoid erosion.
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes ASTM B 88 type K.
CPVC Pipes - Hanger Spacing
Maximum distance between CPVC pipe supports.
Design of Hot Water Heating Systems
Calculate gravity and forced circulating hot water heating systems.
Domestic Hot Water Heaters - Sizing
Domestic Hot-Water sizing equations - heating capacity, recovery rate and power supply.
Domestic Hot Water Service Systems - Design Procedures
Design procedures for domestic hot water service systems.
Domestic Service Water Supply Systems
Introduction to general design of domestic service water supply systems - with pressurized or gravity tanks.
Domestic Water Supply - Lime Deposits
Lime deposited vs. temperature and water consumption.
EN 1452 - Unplasticized Poly Vinyl Chloride (PVC-U) - Dimensions
Dimensions of PVC-U pipe according EN 1452.
Farm Livestock - Water Consumption
Farming and animals required water supply.
Fittings and Minor Pressure Loss
Minor pressure loss with fittings in piping heating systems.
Hazen-Williams Friction Loss Equation - calculating Head Loss in Water Pipes
Hose - Water Discharge Volume Flow vs. Pressure
Water discharge through hoses - pressure ranging 10 - 200 psi (0.75 - 14 bar).
Hoses - Pressure Loss vs. Water Flow
Pressure loss in hoses due to water flow and friction.
Hot and Cold Water Pipe Sizing
Recommended dimensions hot and cold water pipes.
Hot Water Consumption per Occupant
Consumption of hot water per person or occupant.
Hot Water Storage Tanks - Capacities vs. Dimensions
Dimensions and capacities of hot-water storage tanks.
Hot Water Supply - Fixture Consumption
Design hot water consumption of fixtures - basins, showers, sinks and baths.
Hot Water Supply - Flow Rates to Fixtures
Hot water consumption of some common equipment as basins, sinks, baths and showers.
Impurities in Water Supply Systems
Typiclal limits for impurities in drinking water.
Legionella
The Legionella Pneumophila bacterium thrives in water supply systems and air conditioning systems - and may cause the Legionnairs disease.
Plumbing Codes
Plumbing or sanitation codes are a set of rules and regulations imposed by cities, counties or states.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow Diagrams
Friction loss (psi/100 ft) and velocity for water flow in plastic PVC pipe schedule 40.
Water - Human Activity and Consumption
Activity and average water consumption
Water Distribution Pipes - Materials
Materials used in water distribution pipes.
Water Flow in Tubes - Reynolds Number
Reynolds number for clean cold water flow.
Water Service Pipe Lines
Water service pipe lines extends from the potable water source to the interior of buildings.
Water Supply - Calculating Demand
Calculating expected demand for water supply service lines.
Water Supply - Cross-Contamination Control
It is fundamental to keep the potable water in the water supply systems uncontaminated.
Water Supply Fixture Units - WSFU vs. GPM and Liters/sec
Converting WSFU - Water Supply Fixture Units - to GPM.
Water Supply Lines - Sizing
Sizing water supply service and distribution lines based on Water Supply Fixture Units (WSFU).
Water Supply Public Buildings
Required water supply to public buildings.
Water Supply vs. Fixture Water Requirements
Supply requirements for common fixtures.
Water Systems - Maximum Flow Velocities
Water velocities in pipes and tubes should not exceed certain limits.
Yard Fixtures - Water Consumption
Water consumption in garden fixtures.
