PVC Pipes Schedule 40 - Friction Loss vs. Water Flow Diagrams
Friction loss for water flow through plastic schedule 40 PVC pipe:
The calculation is based on the Hazen-Williams Equation with a Hazen-Williams coefficient c = 140.
Velocities between 7 to 10 feet per second are common. In general velocities above 5 feet per second should be avoided.
  • 1 gal (US)/min =6.30888×10-5 m3/s = 0.0227 m3/h = 0.06309 dm3(litre)/s = 2.228×10-3 ft3/s = 0.1337 ft3/min
  • 1 ft/s = 0.3048 m/s
  • 1 psi (lb/in2) = 6,894.8 Pa (N/m2) = 6.895×10-3 N/mm2 = 6.895×10-2 bar = 27.71 in H2O at 61 oF (16.7 oC) = 703.1 mm H2O at 61 oF (16.7 oC) = 2.0416 in mercury at 61 oF (16.7 oC) = 51.8 mm mercury at 61 oF (16.7 oC) = 703.6 kg/m2 = 2.307 Ft. H2O
Water Systems
Dimensions of CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
Friction Loss in Steel, Copper and Plastic Pipes
Friction head loss (ft/100 ft) vs. water flow in steel, copper and PVC plastic pipes.
Hazen-Williams Water Flow Formula: Head Loss, Data, Charts & Calculator
Hot and Cold Water Pipes Sizing
Recommended dimensions hot and cold water pipes.
Lined Pipes - Pressure Loss vs. Water Flow
Pressure drop diagrams for PTFE, PP, PFA and PVDF lined pipes.
Plastic Pipes - Friction Head Loss vs. Water Flow
PVC - Polyvinyl Chloride Pipes - Supports
Distance between PVC pipe supports.
PVC Pipes - Equivalent Length and Pressure Loss in Fittings
Minor loss in PVC and CPVC fittings expressed as equivalent length of straight pipe.
Water flow in thermoplastic PVC and CPVC pipes Schedule 40 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
PVC Pipes Schedule 80 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 80 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
Thermoplastic Pipes - Support Distance vs. Temperature
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
Water Systems - Maximum Flow Velocities
Water velocities in pipes and tubes should not exceed certain limits.
