Maximum operating and required minimum bursting pressures at 73 oF (23 oC) for PVC pipe fittings according ASTM D1785 "Standard Specification for Poly Vinyl Chloride (PVC) Plastic Pipes Schedules 40 and 80 are indicated in the diagram and table below:
Nominal Pipe Size
(inches)
Required Minimum Burst Pressure
(psi)
Maximum Operating Pressure
(psi)
Schedule 401)Schedule 802)Schedule 40Schedule 80
1/2 1910 2720 358 509
3/4 1540 2200 289 413
1 1440 2020 270 378
1 1/4 1180 1660 221 312
1 1/2 1060 1510 198 282
2 890 1290 166 243
2 1/2 870 1360 182 255
3 840 1200 158 225
4 710 1110 133 194
5 620 1040 117 173
6 560 930 106 167
8 500 890 93 148
10 450 790 84 140
12 420 600 79 137
  1. ASTM D2466 - 06 Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Pipe Fittings, Schedule 40
  2. ASTM D2467-04e1 Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Pipe Fittings, Schedule 80
  • 1 psi (lb/in2) = 6,894.8 Pa (N/m2)
  • 1 inch = 25.4 mm
Note! The maximum operating pressures derates with temperature. At the maximum operating temperature for PVC - 140 oF (60 oC) - the strength is derated to approximately 20% of the strength at 73 oF (23 oC).
Be aware that maximum operating pressures varies with the fittings design. Consult the manufacturing data.
Pressure Ratings of Pipes and Fittings
Aluminum Tubing - Allowable Pressures
Allowable pressure for aluminum tubes.
ASTM D2241 - Poly(Vinyl Chloride) (PVC) Pressure-Rated Pipe (SDR Series) - Dimensions
Dimensions of PVC pipe SDR series.
ASTM D2665 - Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Drain, Waste, and Vent Pipe and Fittings - Dimensions
PVC drain, waste, and vent pipe dimensions.
ASTM D2729 - Poly(Vinyl Chloride) (PVC) Sewer Pipe - Dimensions
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end.
Dimensions of CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
ASTM D3034 PSM PVC Sewer PIpe - Dimensions
Dimensions of PSM PVC sewer pipe.
CPVC Pipes - Hanger Spacing
Maximum distance between CPVC pipe supports.
CPVC Tubes - Pressure and Temperature Ratings
CTS (Copper Tube Sized) CPVC (Chlorinated Poly Vinyl Chloride) tubes temperature and pressure ratings.
CTS (Copper Tube Sized) and CPVC Tubes - Friction Loss vs. Water Flow
Volume flow and pressure loss in CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
EN 1452 - Unplasticized Poly Vinyl Chloride (PVC-U) - Dimensions
Dimensions of PVC-U pipe according EN 1452.
EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes with structured walls according EN 1453.
ISO 11922 - Thermoplastics Pipes for the Conveyance of Fluids - Dimensions
ISO 161 - Thermoplastics Pipes - Dimensions
Dimensions of thermoplastic pipes according ISO 161.
Plastics - Recycling Codes and Labeling
Symbol codes and labeling used for recycling plastic products like bottles, containers and packagin.
PVC Pipes - Equivalent Length and Pressure Loss in Fittings
Minor loss in PVC and CPVC fittings expressed as equivalent length of straight pipe.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 40 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow Diagrams
Friction loss (psi/100 ft) and velocity for water flow in plastic PVC pipe schedule 40.
PVC Pipes Schedule 80 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 80 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
Thermoplastic Pipes - Support Distance vs. Temperature
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
Water Hammer
Rapidly closing or openingĀ valves - or starting stopping pumps - may cause pressure transients in pipelines known as surge or water hammer.
