ASTM D3034 PSM PVC Sewer PIpe - Dimensions
Dimensions of PVC pipes according ASTM D3034 Standard Specification for Type PSM Poly(Vinyl Chloride) (PVC) Sewer Pipe and Fittings.
Nominal Pipe Size
(in)
Average Outside Diameter
(in)
Minimum Wall Thickness (in)
SDR 41SDR 35SDR 26SDR 23.5
3 3.250 0.093 0.125 0.138
4 4.215 0.120 0.162 0.178
6 6.275 0.153 0.180 0.241 0.265
8 8.400 0.205 0.240 0.323
9 9.440 0.230
10 10.500 0.256 0.300 0.404
12 12.500 0.305 0.360 0.481
15 15.300 0.375 0.437 0.588
For sizes 1 1/4" and larger ASTM D2665 for DWV pipe is comparable to ASTM D1785 Schedule 40.
Dimensions
ASTM D2661 - Acrylonitrile-Butadiene-Styrene (ABS) Schedule 40 Plastic Drain, Waste, and Vent Pipe and Fittings
Nominal pipe size, outside diameter, thickness and weight.
Dimensions of PVC pipes according EN 1401.
EN 1451 - Polypropylene (PP) Plastics Piping Systems for Soil and Waste Discharge - Dimensions
Plastic piping systems for soil and waste discharge (low and high temperature) within the building structure.
EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes with structured walls according EN 1453.
PVC - Polyvinyl Chloride Pipes - Supports
Distance between PVC pipe supports.
Sewage Sludge - Viscosities
Viscosity of sewage sludge vs. content of solids.
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
