Dimensions of PVC pipes according EN 1401 Plastics piping systems for non-pressure underground drainage and sewerage - Unplasticized poly(vinylchloride) (PVC-U) - Part 1: Specifications for pipes, fittings and the system:
Nominal Size
DN/OD
(mm)
Nominal Outside Diameter
(mm)
Mean Outside Diameter (mm)
minmax
110 110 110.0 110.3
125 125 125.0 125.3
160 160 160.0 160.4
200 200 200.0 200.5
250 250 250.0 250.5
315 315 315.0 315.6
400 400 400.0 400.7
500 500 500.0 500.9
630 630 630.0 631.1
800 800 800.0 801.3
1000 1000 1000.0 1001.6
Dimensions of Pipes and Tubes
ASTM D2661 - Acrylonitrile-Butadiene-Styrene (ABS) Schedule 40 Plastic Drain, Waste, and Vent Pipe and Fittings
Nominal pipe size, outside diameter, thickness and weight.
ASTM D3034 PSM PVC Sewer PIpe - Dimensions
Dimensions of PSM PVC sewer pipe.
EN 1451 - Polypropylene (PP) Plastics Piping Systems for Soil and Waste Discharge - Dimensions
Plastic piping systems for soil and waste discharge (low and high temperature) within the building structure.
EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes with structured walls according EN 1453.
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
Underground Pipes - Earth Pressure
Pressure acting on underground pipes due to weight of soil and transport.
