Thermoplastic Pipes - Strength Derating vs. Temperature
Thermoplastic materials loose strength to pressure and tension with increasing temperature. The table below can be used as a guide to common thermoplastics and their derated strength with temperature. Manufacturing data should always be consulted.
Derating Factor
TemperaturePVDFCPVCPVCPBPEXPE
(oC)(oF)
21 70 1.0 1.0 1.0 1.0 1.0 1.0
27 80 0.9 1.0 0.9 1.0 0.9 0.9
32 90 0.9 0.9 0.8 0.9 0.9 0.9
38 100 0.8 0.8 0.6 0.9 0.9 0.8
43 110 0.8 0.8 0.5 0.8 0.8 0.8
49 120 0.7 0.7 0.4 0.8 0.8 0.7
54 130 0.7 0.6 0.3 0.7 0.8 0.5
60 140 0.6 0.5 0.2 0.7 0.7 0.4
66 150 0.6 0.5 1) 0.7 0.7 0.2
71 160 0.5 0.4 1) 0.6 0.7 1)
82 180 0.5 0.3 1) 0.5 0.6 1)
93 200 0.4 0.2 1) 0.4 0.5 1)
104 220 0.4 1) 1) 1) 1) 1)
121 250 0.4 1) 1) 1) 1) 1)
138 280 0.3 1) 1) 1) 1) 1)
1) The thermoplastic is not resistant for long term service at this temperature. Operating conditions should be avoided.
  • PVDF - PolyVinylidene Fluoride
  • CPVC - Chlorinated Polyvinyl Chloride
  • PVC - Polyvinyl Chloride
  • PB - Polybutylene
  • PEX - Cross Linked Polyethylene
  • PE - Polyethylene
Plastic Pipes Temperature Derating Diagram
Example - Higher Temperature and Reduced Strength
If the operating pressure for a 6" Schedule 80 CPVC pipe is 167 psi, the maximum operating pressure at 150 oF (66 oC) is reduced to
(167 psi) 0.5
    = 83.5 psi
Material Properties
Pressure Ratings of Pipes and Fittings
ASTM D3034 PSM PVC Sewer PIpe - Dimensions
Dimensions of PSM PVC sewer pipe.
ASTM F876 - PEX Tube - Dimensions
Dimensions of PEX tubes.
BS 7291 - Thermoplastics Pipes for Hot and Cold Water - Dimensions
Dimensions of thermoplastic pipes - PEX and PB according BS 7291.
CPVC Tubes - Pressure and Temperature Ratings
CTS (Copper Tube Sized) CPVC (Chlorinated Poly Vinyl Chloride) tubes temperature and pressure ratings.
Dimensions of PVC pipes according EN 1401.
EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes with structured walls according EN 1453.
ISO 11922 - Thermoplastics Pipes for the Conveyance of Fluids - Dimensions
ISO 4437 - PE Pipes for Gaseous Fuels Supply - Dimensions
Plastics - Recycling Codes and Labeling
Symbol codes and labeling used for recycling plastic products like bottles, containers and packagin.
Steel Pipes - De-Rating vs. Temperature
Temperature derating factor for steel pipes.
