Nominal pipe size, outside diameter, thickness and weight.
Friction head loss (ft/100 ft) vs. water flow in steel, copper and PVC plastic pipes.
Dimensions of thermoplastic pipes according ISO 161.
Weight of polyethylene pipes - metric units.
Distance between PVC pipe supports.
Water flow in thermoplastic PVC and CPVC pipes Schedule 40 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
Increased temperatures derates the strength of thermoplastic piping materials.
