Expansion coefficients that can be used to calculate temperature expansion of pipes and tubes - are indicated in the table below:
| Material | Expansion Coefficients | |
| 10-6 in/in oF | 10-6m/m oC | |
| Aluminum | 12.8 | 23.1 |
| Carbon Steel | 6.5 | 11.7 |
| Cast Iron | 5.9 | 10.6 |
| Copper | 9.3 | 16.8 |
| Stainless Steel | 9.9 | 17.8 |
| ABS Acrylonitrile butadiene styrene | 35.0 | 63.0 |
| HDPE High density polyethylene | 67.0 | 120.0 |
| PE Polyethylene | 83.0 | 150.0 |
| CPVC Chlorinated polyvinyl chloride | 44.0 | 79.0 |
| PVC Polyvinyl chloride | 28.0 | 50.4 |
- in/in oF = 1200 in/100ft oF = 1.8 m/moC
Note! The higher expansion coefficients for plastic materials makes plastic pipes and tubes extremely sensitive to temperature changes. Always pay attention to plastic pipes and tubes when temperature varies.
Example - Thermal Expansion of a PVC Pipe
A PVC pipe with length 6 m is heated from 0 oC to 60 oC.
Expansion of the pipe can be calculated as
dl = (50.4×10-6 m/m oC) (6 m) ((60 oC) - (0 oC))
= 0.018 m
= 1.8 cm
• Piping Systems
• Temperature Expansion
• Thermodynamics
ASTM B43 - Seamless Red Brass Pipes - Dimensions
Standard sizes specification for seamless red brass pipes.
ASTM D2241 - Poly(Vinyl Chloride) (PVC) Pressure-Rated Pipe (SDR Series) - Dimensions
Dimensions of PVC pipe SDR series.
ASTM D2665 - Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Drain, Waste, and Vent Pipe and Fittings - Dimensions
PVC drain, waste, and vent pipe dimensions.
ASTM D2729 - Poly(Vinyl Chloride) (PVC) Sewer Pipe - Dimensions
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end.
ASTM D3034 PSM PVC Sewer PIpe - Dimensions
Dimensions of PSM PVC sewer pipe.
ASTM F876 - PEX Tube - Dimensions
Dimensions of PEX tubes.
Calculate ring (or pipe) diameter expansion or contraction when temperature changes.
Dimensions of PVC pipes according EN 1401.
EN 1452 - Unplasticized Poly Vinyl Chloride (PVC-U) - Dimensions
Dimensions of PVC-U pipe according EN 1452.
EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes with structured walls according EN 1453.
Hot Water Heating System Online Design Application
ISO 11922 - Thermoplastics Pipes for the Conveyance of Fluids - Dimensions
ISO 161 - Thermoplastics Pipes - Dimensions
Dimensions of thermoplastic pipes according ISO 161.
ISO 4437 - PE Pipes for Gaseous Fuels Supply - Dimensions
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Linear Thermal Expansion: Formula, Coefficients & Calculator
Piping Materials - Temperature Heat Expansion and Cooling Contraction
Expansion and contraction when cast iron, carbon and carbon molybdenum steel, wrought iron, copper, brass and aluminum pipes are heated or cooled.
Shrink-Fits Assembly
Assembly temperatures for shrink-fits.
Solids - Volume Temperature Expansion Coefficients
Cubical expansion coefficients for solids.
Steam Pipes - Thermal Expansion
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Steel Pipes Expansion Loops - Design and Calculation
Steel pipe expansion loops and their importance in managing thermal expansion, and how to design and size them effectively. Key considerations, calculations, and installation tips to prevent stress and damage in piping systems.
Thermal Expansion of Steam Pipes - (inches)
Expansion of steam pipes heated from room temperature to operation temperature.
