Linear Thermal Expansion Coefficients of Materials
When an object is heated or cooled, its length change by an amount proportional to the original length and the change in temperature.
Thermal expansion coefficients for some common materials:
| Product | Linear Temperature Expansion Coefficient - α - (10-6m/(m °C)) |
| ABS (Acrylonitrile butadiene styrene) thermoplastic | 72 - 108 |
| ABS -glass fiber-reinforced | 31 |
| Acetal - glass fiber-reinforced | 39 |
| Acetals | 85 - 110 |
| Acrylic | 68 - 75 |
| ALLVAR Alloy 30 (negative thermal expansion) | -30 |
| Alumina (aluminium oxide, Al2O3) | 8.1 |
| Aluminum | 23 |
| Aluminum alloys | 21 - 24 |
| Aluminum nitride | 5.3 |
| Amber | 50 - 60 |
| Antimonial lead (hard lead) | 26.5 |
| Antimony | 9 - 11 |
| Arsenic | 4.7 |
| Bakelite, bleached | 22 |
| Barium | 20.6 |
| Barium ferrite | 10 |
| Benzocyclobutene | 42 |
| Beryllium | 12 |
| Bismuth | 13 - 13.5 |
| Boron | 5 |
| Brass | 18 - 19 |
| Brick masonry | 5 |
| Bronze | 17.5 - 18 |
| Cadmium | 30 |
| Calcium | 22.3 |
| Caoutchouc | 66 - 69 |
| Cast Iron Gray | 10.8 |
| Celluloid | 100 |
| Cellulose acetate (CA) | 130 |
| Cellulose acetate butynate (CAB) | 96 - 171 |
| Cellulose nitrate (CN) | 80 - 120 |
| Cement, Portland | 11 |
| Cerium | 5.2 |
| Chlorinated polyether | 80 |
| Chlorinated polyvinylchloride (CPVC) | 63 - 66 |
| Chromium | 6 - 7 |
| Clay tile structure | 5.9 |
| Cobalt | 12 |
| Concrete | 13 - 14 |
| Concrete structure | 9.8 |
| Constantan | 15.2 - 18.8 |
| Copper | 16 - 16.7 |
| Copper, Beryllium 25 | 17.8 |
| Corundum, sintered | 6.5 |
| Cupronickel 30% (constantan) | 16.2 |
| Diamond (Carbon) | 1.1 - 1.3 |
| Duralumin | 23 |
| Dysprosium | 9.9 |
| Ebonite | 70 |
| Epoxy - glass fiber reinforced | 36 |
| Epoxy, cast resins & compounds, unfilled | 45 - 65 |
| Erbium | 12.2 |
| Ethylene ethyl acrylate (EEA) | 205 |
| Ethylene vinyl acetate (EVA) | 180 |
| Europium | 35 |
| Fluoroethylene propylene (FEP) | 135 |
| Fluorspar, CaF2 | 19.5 |
| Gadolinium | 9 |
| German silver | 18.4 |
| Germanium | 6.1 |
| Glass, hard | 5.9 |
| Glass, plate | 9.0 |
| Glass, Pyrex | 4.0 |
| Gold | 14.2 |
| Gold - copper | 15.5 |
| Gold - platinum | 15.2 |
| Granite | 7.9 - 8.4 |
| Graphite, pure (Carbon) | 4 -8 |
| Gunmetal | 18 |
| Gutta percha | 198 |
| Hafnium | 5.9 |
| Hard alloy K20 | 6 |
| Hastelloy C | 11.3 |
| Holmium | 11.2 |
| Ice, 0 oC water | 51 |
| Inconel | 11.5 - 12.6 |
| Indium | 33 |
| Invar | 1.5 |
| Iridium | 6.4 |
| Iron, cast | 10.4 - 11 |
| Iron, forged | 11.3 |
| Iron, pure | 12.0 |
| Kapton | 20 |
| Lanthanum | 12.1 |
| Lead | 29 |
| Limestone | 8 |
| Lithium | 46 |
| Lutetium | 9.9 |
| Macor | 9.3 |
| Magnalium | 23.8 |
| Magnesium | 25 - 26.9 |
| Magnesium alloy AZ31B | 26 |
| Manganese | 22 |
| Manganin | 18.1 |
| Marble | 5.5 - 14.1 |
| Masonry, brick | 4.7 - 9.0 |
| Mercury | 61 |
| Mica | 3 |
| Molybdenum | 5 |
| Monel metal | 13.5 |
| Mortar | 7.3 - 13.5 |
| Neodymium | 9.6 |
| Nickel | 13.0 |
| Niobium (Columbium) | 7 |
| Nylon, general purpose | 50 - 90 |
| Nylon, glass fiber reinforced | 23 |
| Nylon, Type 11, molding and extruding compound | 100 |
| Nylon, Type 12, molding and extruding compound | 80.5 |
| Nylon, Type 6, cast | 85 |
| Nylon, Type 6/6, molding compound | 80 |
| Oak, perpendicular to the grain | 54 |
| Osmium | 5 - 6 |
| Palladium | 11.8 |
| Paraffin | 106 - 480 |
| Phenolic resin without fillers | 60 - 80 |
| Phosphor bronze | 16.7 |
| Plaster | 17 |
| Plastics | 40 - 120 |
| Platinum | 9 |
| Plutonium | 47 - 54 |
| Polyacrylonitrile | 70 |
| Polyallomer | 92 |
| Polyamide (PA) | 110 |
| Polybutylene (PB) | 130 - 139 |
| Polycarbonate (PC) | 65 - 70 |
| Polycarbonate - glass fiber-reinforced | 21.5 |
| Polyester | 124 |
| Polyester - glass fiber-reinforced | 25 |
| Polyethylene (PE) | 108 - 200 |
| Polyethylene (PE) - High Molecular Weight | 108 |
| Polyethylene terephthalate (PET) | 59.4 |
| Polyphenylene | 54 |
| Polyphenylene - glass fiber-reinforced | 36 |
| Polypropylene (PP), unfilled | 72 - 90 |
| Polypropylene - glass fiber-reinforced | 32 |
| Polystyrene (PS) | 70 |
| Polysulfone (PSO) | 55 - 60 |
| Polytetrafluorethylene (PTFE) | 112 - 135 |
| Polyurethane (PUR), rigid | 57.6 |
| Polyvinyl chloride (PVC) | 54 - 110 |
| Polyvinylidene fluoride (PVDF) | 128 - 140 |
| Porcelain, Industrial | 4 |
| Potassium | 83 |
| Praseodymium | 6.7 |
| Promethium | 11 |
| Quartz, fused | 0.55 |
| Quartz, mineral | 8 - 14 |
| Rhenium | 6.7 |
| Rhodium | 8 |
| Rock salt | 40.4 |
| Rubber, hard | 80 |
| Rubidium | 90 |
| Ruthenium | 9.1 |
| Samarium | 12.7 |
| Sandstone | 11.6 |
| Sapphire | 5.3 |
| Scandium | 10.2 |
| Selenium | 37 |
| Silicon | 3 - 5 |
| Silicon Carbide | 2.77 |
| Silver | 19 - 19.7 |
| Sitall | 0.15 |
| Slate | 10 |
| Sodium | 70 |
| Solder lead - tin, 50% - 50% | 25 |
| Speculum metal | 19.3 |
| Steatite | 8.5 |
| Steel | 10.8 - 12.5 |
| Steel Stainless Austenitic (304) | 17.3 |
| Steel Stainless Austenitic (310) | 14.4 |
| Steel Stainless Austenitic (316) | 16.0 |
| Steel Stainless Ferritic (410) | 9.9 |
| Strontium | 22.5 |
| Tantalum | 6.5 |
| Tellurium | 36.9 |
| Terbium | 10.3 |
| Terne | 11.6 |
| Thallium | 29.9 |
| Thorium | 12 |
| Thulium | 13.3 |
| Tin | 20 - 23 |
| Titanium | 8.5 - 9 |
| Topas | 5 - 8 |
| Tungsten | 4.5 |
| Uranium | 13.4 |
| Vanadium | 8 |
| Vinyl Ester | 16 - 22 |
| Vulcanite | 63.6 |
| Wax | 2 - 15 |
| Wedgwood ware | 8.9 |
| Wood, across (perpendicular) to grain | 30 |
| Wood, fir | 3.7 |
| Wood, parallel to grain | 3 |
| Wood, pine | 5 |
| Ytterbium | 26.3 |
| Yttrium | 10.6 |
| Zinc | 30 - 35 |
| Zirconium | 5.7 |
- 10-6 m/moC = 1 μm/moC
- m/m = meter per meter, in/in = inches per inches
Most values for temperature 25 oC (77 oF). The span in the values may be caused by the variation in the materials themselves - or by the variation in the sources used.
- tK = tC + 273.16
- tR = tF + 459.67
- 1 in (inch) = 25.4 mm
- 1 ft (foot) = 0.3048 m
• Temperature Expansion
• Thermodynamics
ABS Pipes - Pressure Ratings
Pressure ratings of ABS 1208, ABS 1210, ABS 1316 and ABS 2112.
ASTM D2729 - Poly(Vinyl Chloride) (PVC) Sewer Pipe - Dimensions
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end.
ASTM F2389 Pressure-rated Polypropylene (PP) - Dimensions
Dimensions of pressure rated PP pipes according ASTM F2389.
Bimetallic Strips
Heat and bending of bimetallic strips.
Calculate ring (or pipe) diameter expansion or contraction when temperature changes.
Copper Tubes - Expansion Loop Capacity
Capacity of copper tubes expansion loops.
Elastomers Properties
Operating-temperature ranges for rubbers and elastomers
Epoxy Pipes - Support Spacing
Support spacing for reinforced Epoxy fiberglass pipes.
Linear Thermal Expansion: Formula, Coefficients & Calculator
Liquids - Volumetric Expansion Coefficients
Volumetric - or cubical - expansion coefficients for common liquids.
Piping Materials - Temperature Heat Expansion and Cooling Contraction
Expansion and contraction when cast iron, carbon and carbon molybdenum steel, wrought iron, copper, brass and aluminum pipes are heated or cooled.
PP - PolyPropylene Pipes - Support Spacing
Maximum distance between PolyPropylene pipes supports.
Shrink-Fits Assembly
Assembly temperatures for shrink-fits.
Solids - Volume Temperature Expansion Coefficients
Cubical expansion coefficients for solids.
Steam Pipes - Thermal Expansion
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Steel Pipes Expansion Loops - Design and Calculation
Steel pipe expansion loops and their importance in managing thermal expansion, and how to design and size them effectively. Key considerations, calculations, and installation tips to prevent stress and damage in piping systems.
Thermal Expansion of Steam Pipes - (inches)
Expansion of steam pipes heated from room temperature to operation temperature.
