Copper Tubes - Expansion Loop Capacity
Expansion loop capacities of copper tubes type K are indicated in the chart below.
Piping should be pre-stressed when anchored to minimize the stress in the system under normal operating conditions.
• Temperature Expansion
Thermal expansion of pipes and tubes - stainless steel, carbon steel, copper, plastics and more.
ASTM B302 - Threadless Copper Pipes - Dimensions
ASTM B42 - Seamless Copper Pipes - Dimensions
ASTM B837 - Seamless Copper Tubes for Natural Gas and Liquified Petroleum - Dimensions
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes ASTM B 88 type K.
Copper Tubes Type K, L and M - Working Pressures vs. Size
Pressfit Pipes - Supports
Maximum distance between pressfit pipe supports.
Steel Pipes - Thermal Expansion Loops
Calculating and sizing steel pipe thermal expansion loops.
Thermal Expansion - Linear Expansion Coefficients
Linear temperature expansion coefficients for common materials like aluminum, copper, glass, iron and many more.
