ASTM B42 - Seamless Copper Pipes - Dimensions
Seamless copper pipe according ASTM B42 Standard Specification for Seamless Copper Pipe, Standard Sizes:
Regular
ASTM B42 - Seamless Copper Pipes - Dimensions Regular
Nominal Pipe Size
(in)
Outside Diameter
(in)
Wall Thichness
(in))
Weight
(lb/ft)
1/8 0.405 0.062 0.259
1/4 0.540 0.082 0.457
3/8 0.675 0.090 0.641
1/2 0.840 0.107 0.955
3/4 1.050 0.114 1.30
1 1.315 0.126 1.82
1 1/4 1.660 0.146 2.69
1 1/2 1.900 0.150 3.20
2 2.375 0.156 4.22
2 1/2 2.875 0.187 6.12
3 3.500 0.219 8.76
3 1/2 4.000 0.250 11.4
4 4.500 0.250 12.9
5 5.562 0.250 16.2
6 6.625 0.250 19.4
8 8.625 0.312 31.6
10 10.750 0.365 46.2
12 12.750 0.375 56.5
Extra Strong
ASTM B42 - Seamless Copper Pipes - Dimensions - Strong
Nominal Pipe Size
(in)
Outside Diameter
(in))
Wall Thichness
(in))
Weight
(lb/ft)
1/8 0.405 0.100 0.371
1/4 0.540 0.123 0.625
3/8 0.675 0.127 0.847
1/2 0.840 0.149 1.25
3/4 1.050 0.157 1.71
1 1.315 0.182 2.51
1 1/4 1.660 0.194 3.46
1 1/2 1.900 0.203 4.19
2 2.375 0.221 5.80
2 1/2 2.875 0.280 8.85
3 3.500 0.304 11.8
3 1/2 4.000 0.321 14.4
4 4.500 0.341 17.3
5 5.562 0.375 23.7
6 6.625 0.437 32.9
8 8.625 0.500 49.5
10 10.750 0.500 62.4
Dimensions of Pipes and Tubes
ASTM B280 Copper Tube for Air Conditioning and Refrigeration (ACR) - Dimensions and Working Pressures
Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
ASTM B302 - Threadless Copper Pipes - Dimensions
ASTM B306 Copper Tubes for Drain, Waste and Vent - Dimensions and Working Pressures
ASTM B837 - Seamless Copper Tubes for Natural Gas and Liquified Petroleum - Dimensions
ASTM B88 - Seamless Copper Water Tubes - Dimensions
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Copper and Copper Alloy Pipes - Temperature Ranges
Bending copper pipe and tube temperatures.
Copper Tubes - Equivalent Length Pressure Loss in Fittings and Valves
Copper tube fittings and equivalent lengths - in feets of straight tube.
Copper Tubes - Expansion Loop Capacity
Capacity of copper tubes expansion loops.
Copper Tubes - Heat Carrying Capacities
Hot water heat carrying capacities in copper tubes type L.
Copper Tubes - Maximum Water Velocities
Water velocity in a copper tube should not exceed certain limits to avoid erosion.
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Copper Tubes Supports
Maximum space between supports aand clips for copper tubes.
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes ASTM B 88 type K.
Copper Tubes Type K, L and M - Working Pressures vs. Size
Friction Loss in Steel, Copper and Plastic Pipes
Friction head loss (ft/100 ft) vs. water flow in steel, copper and PVC plastic pipes.
Horizontal Pipe Hanger Supports - Spacing and Rod Size
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
LPG Pipes - Pressure Loss vs. Gas Flow
Resistance and pressure loss in liquid LPG pipes.
