LPG Pipes - Pressure Loss vs. Gas Flow
Resistance in LPG pipelines expressed as feet of head of liquid LPG-gas per 100 feet pipeline - and pressure drop expressed as kPa per 100 m pipeline - are indicated in the diagrams below. The diagrams are made for steel pipes schedule 40.
Resistance - feet of head of Liquid LPG per 100 feet pipeline vs. gpm
Pressure Drop - kPa per 100 meter pipeline vs. l/s
- 1 gpm = 0.075 l/s
- 1 ft head = 3.0 kPa
• Fluid Flow and Pressure Loss
ASTM B302 - Threadless Copper Pipes - Dimensions
ASTM B42 - Seamless Copper Pipes - Dimensions
ASTM B837 - Seamless Copper Tubes for Natural Gas and Liquified Petroleum - Dimensions
Energy Content in common Energy Sources
Heating fuels and their energy content.
Gas Pipes - Approved Materials
Materials approved for gas pipes.
Gases - Gross and Net Heat Values
Gross heat and net heat values for gases like hydrogen, methane and more.
LPG - Liquefied Petroleum Gas
LPG or Liquefied Petroleum Gas.
LPG Tanks - Relief Valves Capacities
Required capacities of relief valves on LPG vaporizers and tanks.
Propane - Vapor Pressure vs. Temperature
Vapor pressure vs. temperature.
Propane Butane Mixture - Evaporation Pressure
Propane Gas - Sizing of Pipe Lines
Propane Gas Piping - Low Pressure Capacity vs. Size
Sizing of low pressure propane gas pipe lines - Imperial units.
