ρ = m / V (1)
γ = m g / V
= ρ g (2)
Tabulated values of propane density and specific weight at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Online Propane Density Calculator
The calculator below can be used to estimate the density and specific weight of propane at given temperature and atmospheric pressure. (Boiling point of propane is -42.2°C / -44°F, and thus, propane is present as liquid below this temperature)
See also other properties of Propane at varying temperature and pressure : Dynamic and Kinematic Viscosity, Prandtl number, Specific heat (heat capacity), Thermal conductivity and Thermal diffusivity, and Thermophysical properties at standard conditions, as well as density and specific weight of acetone, air, ammonia, argon, benzene, butane, carbon dioxide, carbon monoxide, ethane, ethanol, ethylene, helium, hydrogen, methane, methanol, nitrogen, oxygen, pentane, toluene and water .
Density and specific weight of liquid propane at varying temperature and the gas-liquid equilibrium pressure, SI and Imperial units:
Density of gaseous propane at varying temperature and pressure, SI and Imperial units:
Density of liquid and supercritical propane at varying temperature and pressure, SI and Imperial units:
The density of liquid propane is nearly the same for all pressures up to 100 bara and 50 °C (100°F), and the density of the liquid at equilibrium pressure can be used for most practical purposes.
Density and specific weight of propane at given temperatures and pressures:
| (K) | (°C) | (°F) | (MPa) | (bara) | (psia) | (mol/dm3) | (g/l), (kg/m3) | (lbm/ft3) | (sl/ft3) | (N/m3) | (lbf/ft3) | |
| Liquid | 85.53 | -187.68 | -305.82 | 1.7E-10 | 1.7E-09 | 2.5E-08 | 16.63 | 733.1 | 45.77 | 1.422 | 7189 | 45.8 |
| 100 | -173 | -280 | 2.5E-08 | 2.5E-07 | 3.7E-06 | 16.29 | 718.2 | 44.83 | 1.393 | 7043 | 44.8 | |
| 130 | -143 | -226 | 1.8E-05 | 0.000176 | 0.00255 | 15.60 | 687.7 | 42.93 | 1.334 | 6744 | 42.9 | |
| 160 | -113 | -172 | 0.000850 | 0.00850 | 0.1233 | 14.90 | 657.2 | 41.03 | 1.275 | 6445 | 41.0 | |
| 190 | -83.2 | -118 | 0.01055 | 0.1055 | 1.530 | 14.20 | 626.0 | 39.08 | 1.215 | 6139 | 39.1 | |
| 220 | -53.2 | -63.7 | 0.06058 | 0.6058 | 8.787 | 13.46 | 593.5 | 37.05 | 1.152 | 5820 | 37.0 | |
| 250 | -23.2 | -9.7 | 0.2180 | 2.180 | 31.62 | 12.66 | 558.4 | 34.86 | 1.083 | 5476 | 34.9 | |
| 280 | 6.9 | 44.3 | 0.5817 | 5.817 | 84.37 | 11.78 | 519.2 | 32.41 | 1.007 | 5092 | 32.4 | |
| 310 | 36.9 | 98.3 | 1.273 | 12.73 | 184.6 | 10.73 | 473.0 | 29.53 | 0.9177 | 4638 | 29.5 | |
| 320 | 46.9 | 116 | 1.599 | 15.99 | 231.9 | 10.32 | 454.9 | 28.40 | 0.8827 | 4461 | 28.4 | |
| 340 | 66.9 | 152 | 2.432 | 24.32 | 352.7 | 9.340 | 411.9 | 25.71 | 0.7991 | 4039 | 25.7 | |
| 355 | 81.9 | 179 | 3.243 | 32.43 | 470.4 | 8.316 | 366.7 | 22.89 | 0.7115 | 3596 | 22.9 | |
| 360 | 86.9 | 188 | 3.555 | 35.55 | 515.6 | 7.838 | 345.6 | 21.58 | 0.6706 | 3389 | 21.6 | |
| 369.83 | 96.68 | 206.02 | 4.248 | 42.48 | 616.1 | 5.000 | 220.5 | 13.76 | 0.4278 | 2162 | 13.8 | |
| Gas, saturated | 85.53 | -187.68 | -305.82 | 1.7E-10 | 1.7E-09 | 2.5E-08 | 2.49E-10 | 1.10E-08 | 6.87E-10 | 2.13E-11 | 1.1E-07 | 6.9E-10 |
| 100 | -173 | -280 | 2.5E-08 | 2.5E-07 | 3.7E-06 | 3.05E-08 | 1.34E-06 | 8.39E-08 | 2.61E-09 | 1.3E-05 | 8.4E-08 | |
| 130 | -143 | -226 | 1.8E-05 | 0.000176 | 0.00255 | 1.63E-05 | 7.18E-04 | 4.48E-05 | 1.39E-06 | 0.0070 | 4.5E-05 | |
| 160 | -113 | -172 | 0.000850 | 0.00850 | 0.1233 | 0.00064 | 0.02819 | 0.002 | 5.47E-05 | 0.276 | 0.0018 | |
| 190 | -83.2 | -118 | 0.01055 | 0.1055 | 1.530 | 0.00672 | 0.2964 | 0.01850 | 5.75E-04 | 2.91 | 0.0185 | |
| 220 | -53.2 | -63.7 | 0.06058 | 0.6058 | 8.787 | 0.03397 | 1.498 | 0.09352 | 0.00291 | 14.7 | 0.094 | |
| 250 | -23.2 | -9.7 | 0.2180 | 2.180 | 31.62 | 0.1120 | 4.936 | 0.3082 | 0.00958 | 48.4 | 0.308 | |
| 280 | 6.9 | 44.3 | 0.5817 | 5.817 | 84.37 | 0.2850 | 12.57 | 0.7845 | 0.02438 | 123 | 0.784 | |
| 310 | 36.9 | 98.3 | 1.273 | 12.73 | 184.6 | 0.6323 | 27.88 | 1.741 | 0.05410 | 273 | 1.74 | |
| 320 | 46.9 | 116 | 1.599 | 15.99 | 231.9 | 0.8105 | 35.74 | 2.231 | 0.06935 | 350 | 2.23 | |
| 340 | 66.9 | 152 | 2.432 | 24.32 | 352.7 | 1.336 | 58.92 | 3.678 | 0.1143 | 578 | 3.68 | |
| 355 | 81.9 | 179 | 3.243 | 32.43 | 470.4 | 2.025 | 89.30 | 5.575 | 0.1733 | 876 | 5.58 | |
| 360 | 86.9 | 188 | 3.555 | 35.55 | 515.6 | 2.390 | 105.4 | 6.580 | 0.2045 | 1034 | 6.58 | |
| Liquid | 85.53 | -187.62 | -305.72 | 0.1 | 1 | 14.5 | 16.63 | 733.1 | 45.77 | 1.422 | 7189 | 45.8 |
| 100 | -173 | -280 | 0.1 | 1 | 14.5 | 16.29 | 718.2 | 44.84 | 1.394 | 7043 | 44.8 | |
| 120 | -153 | -244 | 0.10 | 1 | 14.5 | 15.83 | 697.8 | 43.56 | 1.354 | 6843 | 43.6 | |
| 140 | -133 | -208 | 0.10 | 1 | 14.5 | 15.37 | 677.6 | 42.30 | 1.315 | 6645 | 42.3 | |
| 160 | -113 | -172 | 0.10 | 1 | 14.5 | 14.91 | 657.3 | 41.03 | 1.275 | 6446 | 41.0 | |
| 180 | -93.2 | -136 | 0.10 | 1 | 14.5 | 14.44 | 636.7 | 39.75 | 1.235 | 6244 | 39.7 | |
| 200 | -73.2 | -99.7 | 0.10 | 1 | 14.5 | 13.96 | 615.5 | 38.42 | 1.194 | 6036 | 38.4 | |
| 220 | -53.2 | -63.7 | 0.10 | 1 | 14.5 | 13.46 | 593.5 | 37.05 | 1.152 | 5820 | 37.1 | |
| 230.74 | -42.41 | -44.34 | 0.10 | 1 | 14.5 | 13.18 | 581.2 | 36.28 | 1.128 | 5700 | 36.3 | |
| Gas | 230.74 | -42.41 | -44.34 | 0.1 | 1 | 14.5 | 0.05408 | 2.385 | 0.1489 | 0.00463 | 23.4 | 0.149 |
| 240 | -33.2 | -27.7 | 0.1 | 1 | 14.5 | 0.05180 | 2.284 | 0.1426 | 0.00443 | 22.4 | 0.143 | |
| 260 | -13.2 | 8.3 | 0.1 | 1 | 14.5 | 0.04744 | 2.092 | 0.1306 | 0.00406 | 20.5 | 0.131 | |
| 280 | 6.9 | 44.3 | 0.1 | 1 | 14.5 | 0.04382 | 1.932 | 0.1206 | 0.00375 | 18.9 | 0.121 | |
| 300 | 26.9 | 80.3 | 0.1 | 1 | 14.5 | 0.04073 | 1.796 | 0.1121 | 0.00348 | 17.6 | 0.112 | |
| 320 | 46.9 | 116 | 0.1 | 1 | 14.5 | 0.03808 | 1.679 | 0.1048 | 0.00326 | 16.5 | 0.105 | |
| 340 | 66.9 | 152 | 0.1 | 1 | 14.5 | 0.03574 | 1.576 | 0.09839 | 0.00306 | 15.5 | 0.0984 | |
| 360 | 86.9 | 188 | 0.1 | 1 | 14.5 | 0.03370 | 1.486 | 0.09277 | 0.00288 | 14.6 | 0.0928 | |
| 400 | 127 | 260 | 0.1 | 1 | 14.5 | 0.03026 | 1.334 | 0.08328 | 0.00259 | 13.1 | 0.0833 | |
| 500 | 227 | 440 | 0.1 | 1 | 14.5 | 0.02413 | 1.064 | 0.06642 | 0.00206 | 10.4 | 0.0664 | |
| 600 | 327 | 620 | 0.1 | 1 | 14.5 | 0.02008 | 0.8852 | 0.05526 | 0.00172 | 8.68 | 0.0553 | |
| 700 | 427 | 800 | 0.1 | 1 | 14.5 | 0.01719 | 0.7581 | 0.04733 | 0.00147 | 7.43 | 0.0473 | |
| 800 | 527 | 980 | 0.1 | 1 | 14.5 | 0.01504 | 0.6631 | 0.04140 | 0.00129 | 6.50 | 0.0414 | |
| 900 | 627 | 1160 | 0.1 | 1 | 14.5 | 0.01336 | 0.5892 | 0.03678 | 0.00114 | 5.78 | 0.0368 | |
| 1000 | 727 | 1340 | 0.1 | 1 | 14.5 | 0.01202 | 0.5302 | 0.03310 | 0.00103 | 5.20 | 0.0331 | |
| Liquid | 85.62 | -187.53 | -305.55 | 1 | 10 | 145 | 16.63 | 733.3 | 45.78 | 1.423 | 7191 | 45.8 |
| 100 | -173 | -280 | 1 | 10 | 145 | 16.30 | 718.5 | 44.86 | 1.394 | 7046 | 44.9 | |
| 120 | -153 | -244 | 1 | 10 | 145 | 15.83 | 698.2 | 43.59 | 1.355 | 6847 | 43.6 | |
| 140 | -133 | -208 | 1 | 10 | 145 | 15.38 | 678.1 | 42.33 | 1.316 | 6650 | 42.3 | |
| 160 | -113 | -172 | 1 | 10 | 145 | 14.92 | 657.8 | 41.07 | 1.276 | 6451 | 41.1 | |
| 180 | -93.2 | -136 | 1 | 10 | 145 | 14.45 | 637.3 | 39.79 | 1.237 | 6250 | 39.8 | |
| 200 | -73.2 | -99.7 | 1 | 10 | 145 | 13.97 | 616.2 | 38.47 | 1.196 | 6043 | 38.5 | |
| 220 | -53.2 | -63.7 | 1 | 10 | 145 | 13.48 | 594.4 | 37.11 | 1.153 | 5829 | 37.1 | |
| 240 | -33.2 | -27.7 | 1 | 10 | 145 | 12.96 | 571.5 | 35.68 | 1.109 | 5605 | 35.7 | |
| 260 | -13.2 | 8.3 | 1 | 10 | 145 | 12.41 | 547.0 | 34.15 | 1.061 | 5364 | 34.1 | |
| 280 | 6.9 | 44.3 | 1 | 10 | 145 | 11.80 | 520.1 | 32.47 | 1.009 | 5100 | 32.5 | |
| 300.09 | 26.94 | 80.49 | 1 | 10 | 145 | 11.10 | 489.3 | 30.55 | 0.9494 | 4799 | 30.5 | |
| Gas | 300.09 | 26.94 | 80.49 | 1 | 10 | 145 | 0.4915 | 21.67 | 1.353 | 0.04205 | 213 | 1.35 |
| 320 | 46.9 | 116 | 1 | 10 | 145 | 0.4386 | 19.34 | 1.207 | 0.03753 | 190 | 1.21 | |
| 340 | 66.9 | 152 | 1 | 10 | 145 | 0.3994 | 17.61 | 1.099 | 0.03417 | 173 | 1.10 | |
| 360 | 86.9 | 188 | 1 | 10 | 145 | 0.3685 | 16.25 | 1.014 | 0.03153 | 159 | 1.01 | |
| 400 | 127 | 260 | 1 | 10 | 145 | 0.3215 | 14.17 | 0.8849 | 0.02750 | 139 | 0.885 | |
| 500 | 227 | 440 | 1 | 10 | 145 | 0.2478 | 10.92 | 0.6820 | 0.02120 | 107 | 0.682 | |
| 600 | 327 | 620 | 1 | 10 | 145 | 0.2033 | 8.964 | 0.5596 | 0.01739 | 87.9 | 0.560 | |
| 700 | 427 | 800 | 1 | 10 | 145 | 0.1729 | 7.623 | 0.4759 | 0.01479 | 74.8 | 0.476 | |
| 800 | 527 | 980 | 1 | 10 | 145 | 0.1506 | 6.641 | 0.4146 | 0.01289 | 65.1 | 0.415 | |
| 900 | 627 | 1160 | 1 | 10 | 145 | 0.1336 | 5.889 | 0.3676 | 0.01143 | 57.8 | 0.368 | |
| 1000 | 727 | 1340 | 1 | 10 | 145 | 0.1200 | 5.292 | 0.3304 | 0.01027 | 51.9 | 0.330 | |
| Liquid | 100 | -173 | -280 | 5 | 50 | 725 | 16.33 | 719.9 | 44.94 | 1.397 | 7060 | 44.9 |
| 200 | -73.2 | -99.7 | 5 | 50 | 725 | 14.05 | 619.4 | 38.67 | 1.202 | 6074 | 38.7 | |
| 300 | 26.9 | 80.3 | 5 | 50 | 725 | 11.36 | 501.0 | 31.28 | 0.9722 | 4914 | 31.3 | |
| 310 | 36.9 | 98.3 | 5 | 50 | 725 | 10.73 | 487.0 | 30.40 | 0.9449 | 4776 | 30.4 | |
| 320 | 46.9 | 116 | 5 | 50 | 725 | 10.66 | 470.0 | 29.34 | 0.9120 | 4609 | 29.3 | |
| 340 | 66.9 | 152 | 5 | 50 | 725 | 9.340 | 435.0 | 27.16 | 0.8440 | 4266 | 27.2 | |
| 355 | 81.9 | 179 | 5 | 50 | 725 | 8.316 | 400.0 | 24.97 | 0.7761 | 3923 | 25.0 | |
| 400 | 127 | 260 | 5 | 50 | 725 | 2.545 | 112.2 | 7.005 | 0.2177 | 1100 | 7.01 | |
| 500 | 227 | 440 | 5 | 50 | 725 | 1.406 | 61.99 | 3.870 | 0.1203 | 608 | 3.87 | |
| Liquid | 100 | -173 | -280 | 10 | 100 | 1450 | 16.37 | 721.6 | 45.05 | 1.400 | 7076 | 45.0 |
| 120 | -153 | -244 | 10 | 100 | 1450 | 15.92 | 701.8 | 43.81 | 1.362 | 6882 | 43.8 | |
| 140 | -133 | -208 | 10 | 100 | 1450 | 15.47 | 682.2 | 42.59 | 1.324 | 6690 | 42.6 | |
| 160 | -113 | -172 | 10 | 100 | 1450 | 15.03 | 662.7 | 41.37 | 1.286 | 6499 | 41.4 | |
| 180 | -93.2 | -136 | 10 | 100 | 1450 | 14.58 | 643.1 | 40.15 | 1.248 | 6307 | 40.1 | |
| 200 | -73.2 | -99.7 | 10 | 100 | 1450 | 14.13 | 623.2 | 38.91 | 1.209 | 6112 | 38.9 | |
| 220 | -53.2 | -63.7 | 10 | 100 | 1450 | 13.67 | 602.8 | 37.63 | 1.170 | 5911 | 37.6 | |
| 240 | -33.2 | -27.7 | 10 | 100 | 1450 | 13.20 | 581.9 | 36.33 | 1.129 | 5706 | 36.3 | |
| 260 | -13.2 | 8.3 | 10 | 100 | 1450 | 12.70 | 560.1 | 34.97 | 1.087 | 5493 | 35.0 | |
| 280 | 6.9 | 44.3 | 10 | 100 | 1450 | 12.18 | 537.1 | 33.53 | 1.042 | 5267 | 33.5 | |
| 300 | 26.9 | 80.3 | 10 | 100 | 1450 | 11.63 | 512.7 | 32.01 | 0.9948 | 5028 | 32.0 | |
| 320 | 46.9 | 116 | 10 | 100 | 1450 | 11.02 | 486.1 | 30.35 | 0.9432 | 4767 | 30.3 | |
| 340 | 66.9 | 152 | 10 | 100 | 1450 | 10.36 | 456.7 | 28.51 | 0.8861 | 4479 | 28.5 | |
| 360 | 86.9 | 188 | 10 | 100 | 1450 | 9.598 | 423.2 | 26.42 | 0.8211 | 4150 | 26.4 | |
| Supercritical phase |
400 | 127 | 260 | 10 | 100 | 1450 | 7.586 | 334.5 | 20.88 | 0.6490 | 3280 | 20.9 |
| 500 | 227 | 440 | 10 | 100 | 1450 | 3.249 | 143.3 | 8.946 | 0.2780 | 1405 | 8.95 | |
| 600 | 327 | 620 | 10 | 100 | 1450 | 2.246 | 99.02 | 6.182 | 0.1921 | 971 | 6.18 | |
| 700 | 427 | 800 | 10 | 100 | 1450 | 1.788 | 78.82 | 4.921 | 0.1529 | 773 | 4.92 | |
| 800 | 527 | 980 | 10 | 100 | 1450 | 1.507 | 66.46 | 4.149 | 0.1290 | 652 | 4.15 | |
| 900 | 627 | 1160 | 10 | 100 | 1450 | 1.313 | 57.89 | 3.614 | 0.1123 | 568 | 3.61 | |
| 1000 | 727 | 1340 | 10 | 100 | 1450 | 1.168 | 51.49 | 3.214 | 0.09991 | 505 | 3.21 | |
| Liquid | 100 | -173 | -280 | 50 | 500 | 7250 | 16.64 | 733.9 | 45.82 | 1.424 | 7197 | 45.8 |
| 200 | -73.2 | -99.7 | 50 | 500 | 7250 | 14.70 | 648.0 | 40.45 | 1.257 | 6355 | 40.5 | |
| 300 | 26.9 | 80.3 | 50 | 500 | 7250 | 12.85 | 566.6 | 35.37 | 1.099 | 5557 | 35.4 | |
400 | 127 | 260 | 50 | 500 | 7250 | 11.04 | 486.9 | 30.40 | 0.9448 | 4775 | 30.4 |
| 500 | 227 | 440 | 50 | 500 | 7250 | 9.353 | 412.4 | 25.75 | 0.8002 | 4044 | 25.7 | |
| Liquid | 100 | -173 | -280 | 100 | 1000 | 14500 | 16.95 | 747.2 | 46.65 | 1.450 | 7328 | 46.6 |
| 200 | -73.2 | -100 | 100 | 1000 | 14500 | 15.22 | 671.2 | 41.90 | 1.302 | 6582 | 41.9 | |
| 300 | 26.9 | 80.3 | 100 | 1000 | 14500 | 13.70 | 604.1 | 37.71 | 1.172 | 5924 | 37.7 | |
400 | 127 | 260 | 100 | 1000 | 14500 | 12.33 | 543.7 | 33.94 | 1.055 | 5332 | 33.9 |
| 500 | 227 | 440 | 100 | 1000 | 14500 | 11.11 | 490.1 | 30.59 | 0.9509 | 4806 | 30.6 | |
• Densities
• Thermodynamics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Density Converter
Fuel Gases - Flame Temperatures
Adiabatic flame temperatures for common fuel gases - propane, butane, acetylene and more - in air or oxygen atmospheres.
Fuels - Combustion Air and Flue Gases
Combustion air and flue gas for common fuels - coke, oil, wood, natural gas and more.
Hydrocarbons - Vapor Pressures
Vapor pressure vs. temperature for propane, n-butane, n-heptane and n-pentane hydrocarbons.
LPG Pipes - Pressure Loss vs. Gas Flow
Resistance and pressure loss in liquid LPG pipes.
Mass vs Weight
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Propane - Latent Heat of Vaporization vs. Temperature
Latent heat with vaporized propane.
Propane - Thermal Diffusivity vs. Temperature and Pressure
Propane - Vapor Pressure vs. Temperature
Vapor pressure vs. temperature.
Propane Air Mixture
Energy content and specific gravity of propane air mixtures.
Propane Butane Mixture - Evaporation Pressure
Propane Gas - Sizing of Pipe Lines
Propane Gas Piping - Low Pressure Capacity vs. Size
Sizing of low pressure propane gas pipe lines - Imperial units.
Refrigerants - Color Codes
Common refrigerants and their color codes.
